MacBook A1989. Stuck in DFU and won't turn on!
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    MacBook A1989. does not work with dfu. Stuck in DFU and won't turn on!
    20 volts and 0.00 amperes
    Does anyone have any suggestions?
    It's possible that the problem is in the EFI (BIOS),
    who has the EFI ROM file please share
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    • mon2
      • 14673
      Carefully measure the voltage to ground of ppbus_g3h at the fuse at the output of the isl chip.
      • PITERPENY
        • Jul 2023
        • 461
        • Ukraine
        ppbus_g3h​=12.31v
        • PITERPENY
          • Jul 2023
          • 461
          • Ukraine
          does this board switch to 20 volts without a battery connected?
          • mon2
            • 14673
            It may not - check Tim's YT videos (TCRS). I cannot recall which models of these craptops are requiring a battery to boot. He specifically noted this exact comment but not sure of which model. After you find out, continue to post the details here.
            https://www.youtube.com/@TCRSCircuit
            • PITERPENY
              • Jul 2023
              • 461
              • Ukraine
              I’ll answer my own question above: should it be 20 when the board is removed, yes it should be!
              • PITERPENY
                • Jul 2023
                • 461
                • Ukraine
                Well, I bought the same donor board and moved T2 to my board and the Mac was restored to DFU and the Mac started working! but the video on the built-in display is not displayed only on the external one! any ideas ?
                • mon2
                  • 14673
                  Interesting. You have more courage than I on transplanting the T2.
                  Check the LID status. I believe there is a mux chip that steers the video signals to the lcd or external sink. Check the mux sel pin voltage.
                  • PITERPENY
                    • Jul 2023
                    • 461
                    • Ukraine
                    I rearrange T2 a lot (this is the same as CD3215), the main thing is to have lower heating so as not to disturb the RAM layer. and also losing an unlocked working T2 is a crime))). I'm not good at diagnosing, but I'm not bad at soldering chips! I can give you a masterclass)))
                    • PITERPENY
                      • Jul 2023
                      • 461
                      • Ukraine
                      LID_OPEN_RIGHT=1.796V
                      LID_OPEN_LEFT=1.796V
                      PP1V8_SLPS2R=1.8V
                      IPD_LID_OPEN=1.8V
                      SMC_LID_RIGHT=1.8V
                      SMC_LID_LEFT=1.8V
                      • PITERPENY
                        • Jul 2023
                        • 461
                        • Ukraine
                        EDP_INT_AUX_N = short circuit
                        you need to replace the processor (this is more difficult than replacing T2))
                        • mon2
                          • 14673
                          On your board, EDP_INT_AUX_N is shorted or just making a comment?
                          • PITERPENY
                            • Jul 2023
                            • 461
                            • Ukraine
                            EDP_INT_AUX_N​ in diode mode it should be 0.271(something like that) I have 0.000🥵
                            • mon2
                              • 14673
                              Ouch
                              macbook pro a1989 power on but black screen - Badcaps
                              • PITERPENY
                                • Jul 2023
                                • 461
                                • Ukraine
                                it won't stop me
                                • PITERPENY
                                  • Jul 2023
                                  • 461
                                  • Ukraine
                                  After rummaging in the box I found the same board without T2, after checking the CPU it was alive and I decided that I would transfer T2 and SSD from the board with a bad CPU. but that’s not the case, the board on the dfu displays an error 4014 or 4042! hmmm(
                                  • mon2
                                    • 14673
                                    Be sure there is not a thermal fault on the board.
                                    https://youtube.com/shorts/ZfJK6OUMmt4?feature=shared
                                    • bilel
                                      • Mar 2019
                                      • 31
                                      T2 CHIP CAN'T RESTORE BY OTHER PC NEED INTERNET WIFI TO UPDATE
                                      • PITERPENY
                                        • Jul 2023
                                        • 461
                                        • Ukraine
                                        please be more detailed! help us inexperienced)
                                        • MyronViegas
                                          MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
                                          by MyronViegas
                                          Hey guys,
                                          I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
                                          Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
                                          10-06-2025, 08:45 AM
                                        • martyjelen
                                          Macbook A1989 - 820-00850-A Won't turn on - stuck at 5V/5mA
                                          by martyjelen
                                          I need help with Macbook A1989. It stuck at 5V / 5mA.
                                          I already do some measurements https://logi.wiki/index.php/CD3215_Bootup_Sequence
                                          PP20V_USBC_XB_VBUS - 5V
                                          PP3V3_UPC_XB_LDO - 3V
                                          PP1V8_UPC_XB_LDOA - 1.8V
                                          PP1V8_UPC_XB_LDOD -1.8V
                                          PP1V1_UPC_XB_LDO_BMC - 0V
                                          It's the same on all CD3215. There is no signs of corrosion or something like that.
                                          What should I check?
                                          Thanks for help.
                                          Martin
                                          05-11-2023, 02:38 AM
                                        • nosinformatica
                                          Macbook Pro 13'' - A1989 stuck at 5v
                                          by nosinformatica
                                          Preface : My primary job it's not repairing logic board, so please excuse me.
                                          The Macbook A1989 is stuck at 5v at 0.3A on three usb-c port, and in one port no absorption, so the incriminated chip may be the CD3125.
                                          I'have read that these mac have two CD3125 in daisy chain.
                                          How can i confirm my diagnose before reballing it? Someone have experience with this issue?...
                                          09-29-2023, 06:29 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • Bmet
                                          MacBook Pro 13 inch A2238 M2 stuck on 5V
                                          by Bmet
                                          I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                                          04-02-2025, 05:02 PM
