Logik LOG32lw782
  • joehezzer
    • Jul 2012
    • 251
    • England
    #81
    Re: Logik LOG32lw782
    Originally posted by multimeter
    pin 12 +5v
    pin 10,11 +3.3v
    pin 1,2,3 +5v
    are you seeing any voltage on those?
    pin 12 +5v yes 5.2v
    pin 10,11 +3.3v yes 3.3v
    pin 1,2,3 +5v nothing this is on pl805 the one marked in blue
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      #82
      check all your +v pins to cold ground,you want to be seeing hundreds of kohm,a few ohms will indicate a short on that rail.
      ive had those 2 diodes just to the right on that big yellow transformer(the ones with the metal support upstands) fail a couple of times,maybee worth a check,just pull one leg and diode test them
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        You have pressed the little side on/off button right? Without that, standby light is OFF.
        • joehezzer
          • Jul 2012
          • 251
          • England
          #84
          will diodes now and report back
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            #85
            a toshiba regza caught me out on that one!,large switch to the left,but standby button on the other side of the tv!!,it worked when i pressed it
            it most likely wouldnt have when they filled them with crappy oem boards further on..
            • joehezzer
              • Jul 2012
              • 251
              • England
              #86
              ok just checked diodes on ohm the readings danced around the on the one just said 1
              • multimeter
                • Jan 2011
                • 739
                • united kingdom
                #87
                did you pull one leg of each diode and test and read both ways??part number of the diodes?
                • joehezzer
                  • Jul 2012
                  • 251
                  • England
                  #88
                  had a couple like that with rocker switches lol, i cannot see any separate switches anywhere
                  • joehezzer
                    • Jul 2012
                    • 251
                    • England
                    #89
                    did you pull one leg of each diode and test?part number of the diodes?
                    yes disconnected from circuit board. diode stps sl60 chn729. changes leads around and got 1.97ohms
                    • multimeter
                      • Jan 2011
                      • 739
                      • united kingdom
                      #90
                      use the diode test on yr dmm,forward voltage should be around 0.19v thats at 5.26ma test voltage
                      and they are shottky diodes,so you will have a little reverse when testing
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        #91
                        forward voltage read nothing reverse nothing again not sure if i am doing it right, could be that they are shorted
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #92
                          can you post a picture of your multimeter so we can make sure you have it on the right settings etc.
                          • joehezzer
                            • Jul 2012
                            • 251
                            • England
                            #93
                            yep
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #94
                              diode is the one before 200 ohms try testing them on that setting
                              • joehezzer
                                • Jul 2012
                                • 251
                                • England
                                #95
                                yep tried that got nothing just stays on 1 rather than 00.0 when both probes are connected
                                • multimeter
                                  • Jan 2011
                                  • 739
                                  • united kingdom
                                  #96
                                  if your getting that when reversing probes,your diodes are open,00.0 on ohm setting will indicate a dead short
                                  • joehezzer
                                    • Jul 2012
                                    • 251
                                    • England
                                    #97
                                    ok reversed it and got 160 on diode setting.
                                    when i try on ohms i get 1 reverse it and get 1.98ohms
                                    • multimeter
                                      • Jan 2011
                                      • 739
                                      • united kingdom
                                      #98
                                      ok reversed it and got 160 ohms
                                      right,so dmm set to diode test one way your getting a reading reverse your not?
                                      • joehezzer
                                        • Jul 2012
                                        • 251
                                        • England
                                        #99
                                        getting a reading on reverse and nothing when i put red lead on the cathode end
                                        • joehezzer
                                          • Jul 2012
                                          • 251
                                          • England
                                          #100
                                          sorry my fault again been reading diode wrong lol dmm set on diode i get 164, reverse it i get 1. sorry guys my mistake
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • acedogblast
                                            Power supply for main amp blows fuses after replacing filter caps.
                                            by acedogblast
                                            Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                                            I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                                            I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                                            02-27-2023, 05:11 PM
                                          • Sik_6ty_Sixx
                                            HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                            by Sik_6ty_Sixx
                                            So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                            02-18-2025, 05:06 AM
                                          • MrzPdlch
                                            Blown fuses on Gigabyte GTX 980TI 6GB
                                            by MrzPdlch
                                            Hey everyone,
                                            I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                                            Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                                            Find some pictures of the actual GPU together with a picture of how it should look like.
                                            I also wonder whther it might be a problem that there...
                                            03-10-2024, 04:14 PM
