Logik LOG32lw782
  • joehezzer
    • Jul 2012
    • 251
    • England
    Logik LOG32lw782
    Hi all ok so i picked up a logik lcd screen the other week, no power so checked all the fuses etc nothing so i found a cheap working psu for and bought it, the problem i have is i fitted new second hand new board and it is still not doing anything at all
    the problem is i am not sure what to check on this set cheers in advance
  • joehezzer
    • Jul 2012
    • 251
    • England
    Re: Logik LOG32lw782
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      id be checking for dry joints,this psu suffers badly with them big time !
      also they suffer with bad caps.
      change the output caps with panasonic fc/fm series,it should fix it.
      thats all ive had to do on these psu's
      i think they are g luxon,caps yuck..
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • joehezzer
        • Jul 2012
        • 251
        • England
        its supposed to be a working psu, will re solder some of the joints on it
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          seriously resolder them joints,ive found about 10-20 cold joints on these
          • joehezzer
            • Jul 2012
            • 251
            • England
            will get on it now will report my progress is it pretty common with this set then
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              yes ,these are used in a lot of generic tv's,they really are a pile of crap
              • joehezzer
                • Jul 2012
                • 251
                • England
                Are there any test points on these sets
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  i cant remember exactly ,ive only ever had to replace caps,and redo joints ,every time on this psu,this normally fixes them
                  • joehezzer
                    • Jul 2012
                    • 251
                    • England
                    It should be a working psu it was tested before dispatch.
                    • multimeter
                      • Jan 2011
                      • 739
                      • united kingdom
                      yes it SHOULD be working,many a time i have done this ,and tested psu and it hasnt worked,there is no way of knowing if the tests have been done,the advert is usually...
                      power supply taken from a broken screen tv...blah blah,you get the picture
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        yeah lol
                        • joehezzer
                          • Jul 2012
                          • 251
                          • England
                          ok so i have taken the main avi board off to find one of the caps joints looks rough
                          there does not seem to be a copper to solder the cap to
                          sorry about the pick thats about as close to it i can get.
                          • multimeter
                            • Jan 2011
                            • 739
                            • united kingdom
                            dont forget the psu!
                            on that capacitor with no pad around it,scratch some of the silkscreen off,you may find some copper underneath to solder too.
                            or run a jumper wire to the cap pads next to it,to the correct pad - to - or + to +,
                            • joehezzer
                              • Jul 2012
                              • 251
                              • England
                              will try that
                              • joehezzer
                                • Jul 2012
                                • 251
                                • England
                                ok all soldered up looks ok
                                • multimeter
                                  • Jan 2011
                                  • 739
                                  • united kingdom
                                  re-fit ,and power up to see what happens
                                  • joehezzer
                                    • Jul 2012
                                    • 251
                                    • England
                                    nothing although when i put plug into my white extension lead you can see a blue/flash spark at that particular plug, everything is telling me its the psu as there is no power, no standby light nothing
                                    • multimeter
                                      • Jan 2011
                                      • 739
                                      • united kingdom
                                      id be concentrating on the power supply,joints +output caps if that is the case.
                                      • joehezzer
                                        • Jul 2012
                                        • 251
                                        • England
                                        thats the only thing i can think of.
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • acedogblast
                                          Power supply for main amp blows fuses after replacing filter caps.
                                          by acedogblast
                                          Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                                          I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                                          I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                                          02-27-2023, 05:11 PM
                                        • Sik_6ty_Sixx
                                          HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                          by Sik_6ty_Sixx
                                          So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                          02-18-2025, 05:06 AM
                                        • MrzPdlch
                                          Blown fuses on Gigabyte GTX 980TI 6GB
                                          by MrzPdlch
                                          Hey everyone,
                                          I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                                          Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                                          Find some pictures of the actual GPU together with a picture of how it should look like.
                                          I also wonder whther it might be a problem that there...
                                          03-10-2024, 04:14 PM
