Logik LOG32lw782
    Re: Logik LOG32lw782
    Originally posted by multimeter View Post
    pin 12 +5v
    pin 10,11 +3.3v
    pin 1,2,3 +5v
    are you seeing any voltage on those?
    pin 12 +5v yes 5.2v
    pin 10,11 +3.3v yes 3.3v
    pin 1,2,3 +5v nothing this is on pl805 the one marked in blue
      check all your +v pins to cold ground,you want to be seeing hundreds of kohm,a few ohms will indicate a short on that rail.
      ive had those 2 diodes just to the right on that big yellow transformer(the ones with the metal support upstands) fail a couple of times,maybee worth a check,just pull one leg and diode test them
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        You have pressed the little side on/off button right? Without that, standby light is OFF.
          will diodes now and report back
            a toshiba regza caught me out on that one!,large switch to the left,but standby button on the other side of the tv!!,it worked when i pressed it
            it most likely wouldnt have when they filled them with crappy oem boards further on..
              ok just checked diodes on ohm the readings danced around the on the one just said 1
                did you pull one leg of each diode and test and read both ways??part number of the diodes?
                  had a couple like that with rocker switches lol, i cannot see any separate switches anywhere
                    did you pull one leg of each diode and test?part number of the diodes?
                    yes disconnected from circuit board. diode stps sl60 chn729. changes leads around and got 1.97ohms
                      use the diode test on yr dmm,forward voltage should be around 0.19v thats at 5.26ma test voltage
                      and they are shottky diodes,so you will have a little reverse when testing
                        forward voltage read nothing reverse nothing again not sure if i am doing it right, could be that they are shorted
                          can you post a picture of your multimeter so we can make sure you have it on the right settings etc.
                            yep
                              diode is the one before 200 ohms try testing them on that setting
                                yep tried that got nothing just stays on 1 rather than 00.0 when both probes are connected
                                  if your getting that when reversing probes,your diodes are open,00.0 on ohm setting will indicate a dead short
                                    ok reversed it and got 160 on diode setting.
                                    when i try on ohms i get 1 reverse it and get 1.98ohms
                                      ok reversed it and got 160 ohms
                                      right,so dmm set to diode test one way your getting a reading reverse your not?
                                        getting a reading on reverse and nothing when i put red lead on the cathode end
                                          sorry my fault again been reading diode wrong lol dmm set on diode i get 164, reverse it i get 1. sorry guys my mistake
