How to choose replacement resistors
  • ChrisV
    • Dec 2013
    • 66
    Hey guys. I've recently purchased a replacement Y-Main board for a Vizio VP50 HDTV10A. This is the 2nd Vizio that I've been able to repair by repairing the power supply and then replacing the Y-Main and buffer boards. Although it felt good to see the TV's up and running, it would be much more fulfilling to repair the broken Y-Main. I've carefully inspected the board and found 2 burnt resistors. After checking all of the other resistors, there were several others that were out of the tolerance. In fact, only 2 of them on the board were good. I spent some time researching and understanding the color coding system and was able to determine that the 2 resistors in the photo are a 10ohm resistor.
    What I don't understand is how to determine the correct wattage. I made a trip to Radio Shack and they had some 1/4W 10 Ohm resistors but they were physically smaller in size. I have a few different resistors and don't want to buy the wrong ones.
    Any advice for a NOOB?
  • Ltank
    • Jun 2013
    • 776
    Re: How to choose replacement resistors
    Red Black Black is 20 Ohms Gold for 5%. Appears to be Flame proof 2 watt resistors,
    hard to tell phsical size to be more accurate
      Usually those resistors fail if there is a short on the buffer board.
      • LLLlllou
        • May 2011
        • 201
        Definitely 20ohm 5%, looks flameproof, impossible to tell wattage with so little to go by, but definitely way over 1/4 watt.
        OP, how'd ya get 10ohms out of red black black gold?
        First and second color:
        Black=0
        Brown=1
        Red=2
        Orange=3
        Yellow=4
        Green=5
        Blue=6
        Violet=7
        Grey=8
        White=9
        Third color (multiplier):
        Silver=.01
        Gold=x.1
        Black=x1
        Brown=x10
        Red=x100
        Orange=x1000
        Yellow=x10000
        Green=x100000
        Blue=x1M
        Fourth color (tolerance):
        none=20%
        Silver=10%
        Gold=5%
        (Red=2 Black=0) = 20 x Black=x1 = 20 ohms
          It looks like they are connected in parallel, the top ends of both resistors are connected to the large copper plain, the bottom end of both resistors has copper trace connected to the both resistors. One looks damaged. You should lift one end up and take the measurement.
          • ChrisV
            • Dec 2013
            • 66
            Black=0
            Brown=1
            Red=2
            Orange=3
            Yellow=4
            Green=5
            Blue=6
            Violet=7
            Grey=8
            White=9
            Silver=.01
            Gold=x.1
            Black=x1
            Brown=x10
            Red=x100
            Orange=x1000
            Yellow=x10000
            Green=x100000
            Blue=x1M
            none=20%
            Silver=10%
            Gold=5%
            I guess that picture is a little deceiving. The colors are Brown black black gold.
            The brown color on the first band would indicate a 1 for the first digit. I've attached a better photo. The resistor is about 12mm long
            Last edited by ChrisV; 01-11-2014, 09:52 PM. Reason: Added the length of the resistor
            • ChrisV
              • Dec 2013
              • 66
              Yes. They are in parallel. I've removed them from the circuit to measure them. My main concern is understanding how to order resistors after I've determined the resistance value. Just not sure about everything else. I have a few more resistors to replace and want to get it right on the first order.
              Thank you for the reply!
              • ChrisV
                • Dec 2013
                • 66
                Thank you for the reply. How can you see that they are 2 watt flame proof?
                • ChrisV
                  • Dec 2013
                  • 66
                  Both buffer boards were shorted out. Trying to determine the cause of failure.....
                  There were 10 blown capacitors on the power supply of this TV. Do you think the failed power supply caused erratic voltage to the Y-Main, which caused the buffer boards to short out? The shorted out buffer boards ultimately fried the resistors on the Y-Main???
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Physical size and that matte green colour indicates wattage and flame-proof types. One pictured would be a 2W Metal-Film Flameproof, 10 ohm, 5% tolerance.
                    They are probably there--designed to fail-- in the event of a circuit failure elsewhere to protect against possible fire and other damage, basically doubling as a fuse--Such resistors are often marked on schematics with a 'Hazard' symbol, a ! in a triangle....
                    Often, they are used in the source connection of MOSFETS for current-monitoring in PSU's etc, so should always be replaced with exactly the same value--and type!
                    TELEFIX
                    • ChrisV
                      • Dec 2013
                      • 66
                      Thank you for the answers. That tells me everything I need to know to replace these.
                      • ChrisV
                        • Dec 2013
                        • 66
                        Sorry. I thought I had this figured out. I'm checking all of the resistors on this board. This one has me stumped. It's a 5 band resistor. The #3 gold band in the resistor is confusing me. Any thoughts on the ohm rating?
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          i think that's an inductior, not a resistor
                          Follow the white rabbit.
                            I say 1 Ohm flame proof MOX resistor. Just measure it.
                            • selldoor
                              Slow Learner
                              • 7870
                              Why dont you just test it and see what your meter comes up with?
                              EDIT
                              I agree with budm
                              see here test for 5 reports as 4 =1 ohm
                              http://www.hobby-hour.com/electronic...calculator.php
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                if it is its only 2% tolerance, which seems odd for a telly.
                                • ChrisV
                                  • Dec 2013
                                  • 66
                                  It measures @ 1.2ohms. According to chart, the tolerance is 2%. So the upper limit would be 1.05 ohms. Is that correct. This is outside of the tolerance and should be replaced?
                                  Thank you guys so much for the replies.
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    i would say its ok.
                                      That is probably sensing current resistor connected to the Source pin of the MOSFET so they use 2% instead of 5% for more accurate current sensing.
                                      You have to add your meter probe wires resistance to the value of the resistor you are measuring.
                                      • LLLlllou
                                        • May 2011
                                        • 201
                                        "A picture is worth a thousand words" - my ASS!
                                        First pictures you posted show the first band as RED, second pic is definitely brown. Just goes to show, you can't believe every thing you see. :0
                                        As Dennis Rodman once said to Carmen Electra after her finding him in bed with another woman - "are you gonna believe me, or you're lying eyes?"
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • lolich112
                                          How to find out what resistors i need as a replacement?
                                          by lolich112
                                          Hey,
                                          I have a Palit GTX 750 StormX with 2 gigs. on the backside right above the pcie connectors there are multiple conponents (See in the pics). I suppose those are resistors or capacitors. 2 of them broke of and now I need 2 replacements. I looked arround for some schematics but couldn“t find any. Someone have an idea how to identify those?
                                          Thanks in advance!...
                                          09-03-2023, 01:37 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • the_rem
                                          Unknown transformer : how to find a good replacement part ?
                                          by the_rem
                                          Hello guys,
                                          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                          04-23-2025, 01:48 AM
                                        • brightest_z
                                          Hot Air Blew Away Resistors Near Bios
                                          by brightest_z
                                          Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
                                          Does anyone with more knowledge, and experience than I, know if this is the case?
                                          12-11-2024, 08:34 PM
