Philips 37" tv wont power on 37PFL662D/05
  • ssit
    • Jan 2014
    • 4
    • United Kingdom
    Morning gents and ladies,
    Hope everyone is well today? This is my first post on here (apart from the obligatory welcome post).
    Im having some puzzling issues with a Philips 37" tv that wont power on. The model number is 37PFL662D/05.
    I started having an issue with vertical lines showing on the screen after circa 30 minutes usage and decided to swap the video processing board. However since then the TV wont power on. Just to try and get this issue dealt with.. I purchased a new power board (both parts are eBay purchases but sold as tested and working from reputable buyers) but not the TV will not power on.
    I have tried the video board in another TV that takes the same board and it works fine.
    Ive ran a multimeter at the power in and its reading 230v but other than that I am stumped.
    I just cant see two power boards being faulty?
    Anyone got any ideas? Could it be the way everything connected? Could the power button be faulty? Or am I missing the point entirely?
    If anyone needs any more images or information please let me know
  • selldoor
    Slow Learner
    • 7870
    Re: Philips 37" tv wont power on 37PFL662D/05
    hi - power button could be faulty or not plugged in?
    Tried remote?
    Please post good clear pictures of your board s( decide which ps you want to troubleshoot) and one of the back of the set all connected up.
    Sounds like the main board is not sending signal to ps to switch on but
    cant see how what you have done would cause that.
    • vinceroger69
      • Mar 2012
      • 6714
      as selldoor says some good pictures will help us to point out places to test etc.
      • ssit
        • Jan 2014
        • 4
        • United Kingdom
        Hi Guys,
        Thanks for the replies, I have now attached some images for you.
        Anything else I can do to assist with the troubleshooting please let me know.
        Regards
          Your original fault is NOT related to main board or power board, but to the LCD panel failing. Tab bonds fault, may or may not be fixable. Tried putting both original boards back in?
          • ssit
            • Jan 2014
            • 4
            • United Kingdom
            Hi Tom66,
            Thanks for the reply, I have just put the original board back in and now the unit powers up fine (spose that warrants a refund from the ebay power board!) however now the LCD appears to be totally black, no picture or menus, but the backlight is active (if I tap on the screen I can see the backlight is working)
            Regards
            • Destroyer-Br
              [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
              by Destroyer-Br
              I'm working on an Acer Nitro 5 unit with the following specs:
              • Motherboard: LA-J871P Rev: 1B
              • Model: Acer AN515-55-59MT
              • S/N: NHQ7JAL00403906A973400
              • SNID: 03902728734
              Initial Issue
              The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
              After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
              04-17-2025, 08:18 PM
            • spantor
              Activate power board Philips 40PFH40009/88 tv
              by spantor
              Hello partners.
              Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
              The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
              02-11-2024, 05:07 PM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
              by sam_sam_sam
              After all of...
              07-13-2024, 08:14 PM
