Does anybody know what causes and is there a way to fix or check for the issue I have the TV set upside down at this moment.
Samsung frame horizontal lines
Panel short or TCON board issues. Not sure if frame TV has tcon board, I've seen a few of these on marketplace with similar issue. Or damage to screen. I've never actually had one though so I can't say for sure -
Yea generally the tcon board is part of the main board. Definitely possible. Expensive TV so I can understand wanting to fix it. If you can't diagnose, that would likely be the part to change. Shop jimmy will do free returns minus shipping costs back and forth.
I still would guess it's the panel, but I'm no expert yet.Comment
I mean it should recognize the one connect box. Those clips are important because it keeps the main board grounded properly. It's potentially possibly you got a bad main board from them.
I'd still think panel issue but not recognizing the one connect box is a mystery. Does the old one recognize it?
In the end those one connect boxes and cables can be sold on eBay for like$300 some timesComment
Wanted to post an update had it working except for maybe one minor data line, the left side LED lights quit I’m not putting any more time into this. Not worth the effort now with the light being out. So I have a mainboard, power board, RF board Wi-Fi board, connect box, connect box cable, remote stand ,wall mount. Maybe I’ll find something down the road to put all this with who knows but thank y’all for your help.Comment
Sell them on eBay. Chances are extremely low you'll find a good panel tv like that. I live in Tampa and I've yet to see even one good panel frame TV. Sell em off! And get 5 yr warranty through Costco. Haha we tried thoughWanted to post an update had it working except for maybe one minor data line, the left side LED lights quit I’m not putting any more time into this. Not worth the effort now with the light being out. So I have a mainboard, power board, RF board Wi-Fi board, connect box, connect box cable, remote stand ,wall mount. Maybe I’ll find something down the road to put all this with who knows but thank y’all for your help.Comment
by noipiI have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
by IhandyrepairHi guys
I just started fixing 4k TV few months ago. so I am still learning a lot
I got this tv from friend complaint is ghosting or horizontal lines on image.
never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
then it started to show the ghosting white image.
I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
it has 3 thin small boards at the bottom of the... -
by RubenlilyHello,
First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
I'm no expert but I've done the tape... -
by x_orange90_xI posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went... -
by arctorhi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...2 Photos
- Loading...
