Sony Bravia KDL-32XBR4 324046whc6lv2.2 TCON fix
  • Juanbim01
    • Aug 2016
    • Puerto rico
    Re: Sony Bravia KDL-32XBR4 324046whc6lv2.2 TCON fix
    I also would like to thank you guys for the information. Although I'm not a technician, following your instructions, I was able to get the TV fixed no cost. I was able to pull out the T-com and took it to a friend who is a technician and has all the tools. When I explained the problem to him, he told me that by his experience, that was not the problem. He checked the resistor and it was Ok but he change it anyhow, as I asked him.
    When I put back thevT-com with basically no hopes at all, Voila!!!, PROBLEM FIXED!
    Save a lot of bucks thanks to all of you!
    Thanks again!
      Thanks again!
      That is good news, may be you should tell your friend to join BADCAPS.NET.
      • SSB
        • Jan 2017
        Fantastic thread guys. My Bravia is displaying the same vertical line symptoms have taken out the tcon 324046WHC6LV2.2 and located RT36 (gosh, it is tiny!). Next step will be to get it replaced... I'll let you know how I get on.
        • krazyspank
          • Feb 2018
          • usa
          Thanks for the fix ! worked perfect!
          • Velocet
            • May 2018
            Thanks to this thread another TV is resurrected from the dead
            • rajeev93
              • Apr 2021
              • INDIA
              #26
              I also have same problem of multicolor vertical lines on my sony Bravia KLV-32D300A whose T con board is 324046whc6lv2.2. But the Resistor RT36 is showing ok 9.1Kohm.
              Can anybody tell what could be the other problem.
              Rajeev
              • nomoresonys
                • 12276
                • U.S.
                #27
                Not exactly sure rajeev, did you read post 21, it is strange that his tested ok but apparently was bad, unless there was some kind of testing error.
                • nomoresonys
                  • 12276
                  • U.S.
                  #28
                  Could try reseating and or cleaning the contacts of the tcon ribbon and lvds cables with some isoprophyl alcohol, carefully as they can be delicate. Youtube is your friend for how to videos.
                  • x_orange90_x
                    Sony Bravia KD-50X690E blown resistor
                    by x_orange90_x
                    I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
                    The power supply is 715G8413-P01-001-0H2S...
                    07-16-2024, 06:53 AM
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • swrb898
                    Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                    by swrb898
                    What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                    Problem:
                    Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                    My troubleshooting got me this far:
                    With the left-hand TCON to bottom-board ribbon cable...
                    12-28-2021, 08:12 PM
                  • iglitare
                    Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                    by iglitare
                    i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                    Backlight seems to work, Sound (Setup menu after reset) works.
                    If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                    Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                    With my small knowledge i would think at least the cables are good.
                    Can this happen because of a bad tcon board?
                    Or is it always a bad/shorted...
                    09-04-2025, 07:13 AM
                  • PopsCaps
                    Sony Bravia KDL-40V2500 that will not power on
                    by PopsCaps
                    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                    I do not hear any sound and I cannot see any backlight.
                    I have tried disconnecting every cable on each board one at a time to see if anything changes.
                    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                    03-25-2025, 11:23 AM
