Back light problem
+ More Options
Posts
  • snipersquad100
    • Nov 2013
    • 297
    • uk
    Back light problem
    HI I've got an ALBA LCD32880HDF in with a back light going off after 30 secs or so. voltages are a bit of a problem as their not marked on the pcb. When it starts up im getting a 24v, 12v, 5.3v, 3.3volts when the back light goes off the 24v drops to 18v. So im not sure if I have a PSU or an inverter problem or something else.
    thanks
  • snipersquad100
    • Nov 2013
    • 297
    • uk
    Re: Back light problem
    anyone
      Good clear pictures of the back of the TV and the boards so we can see what we are dealing with?
      • snipersquad100
        • Nov 2013
        • 297
        • uk
        here's some pics
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Pictures are nor really clear enough - need to be able to read the component numbers on the boards. When it is on can you tell if any bulbs are out (one corner dimmer etc.)
          We also need a pic of the inverter board and possibly the Tcon.
            I need good clear pictures of that power supply/inverter board combo top and bottom side. That high voltage inverter transformer is not likely to be running from 24V power supply but more likely from the PFC Voltage booster circuit that supplies about 380~400VDC to drive that transformer through MOSFETs. I cannot tell until I get to see better pictures to figure out how this board works.
            • snipersquad100
              • Nov 2013
              • 297
              • uk
              Sorry had to use flash as its dark. If you need better ones I'll have to take em in the morning. Thanks
              • snipersquad100
                • Nov 2013
                • 297
                • uk
                  Did you take the screen apart?
                  Pictures of the bottom side of the power supply board? I need to be able to see good clear pictures of the components on the bottom side of power supply board to see how the inverter transformer being driven.
                  This is going to be tough, there are so many pins on the power supply/inverter board connector that goes back to the main board.
                  • snipersquad100
                    • Nov 2013
                    • 297
                    • uk
                    yes screen is apart, give me have hour to do the underside of the pcb.
                    yes this is a tuff one, Ive never worked on a psu/inv combo b4. if I could be sure its the psu/inv and not the back light or something else id buy a new board.
                      I am not sure if the 17IPS10-2 SCH is close to your -03 or not, but it may help.
                      I download this from TOM66 website.
                        This PSU uses 150V for backlight inverter. I would check what this does when fault occurs.
                        • snipersquad100
                          • Nov 2013
                          • 297
                          • uk
                          Hope you can piece it together.
                          • snipersquad100
                            • Nov 2013
                            • 297
                            • uk
                            where do I prob for the 150v?
                              We don't need board layouts at the moment with, uh... "schematics" (if you could call Vestel's attempt one.) Check 150V. Across C164, I think.... (schematic completely unclear.)
                              • snipersquad100
                                • Nov 2013
                                • 297
                                • uk
                                Ok will do. Any more pics needed b4 I put it back together.
                                  Should be OK for now.
                                  • snipersquad100
                                    • Nov 2013
                                    • 297
                                    • uk
                                    I cant see c164 to save my life, on that schematic its a 220uf/200v should stand out like a sor thumb.
                                    • snipersquad100
                                      • Nov 2013
                                      • 297
                                      • uk
                                      this board is vestel 17IPS10-3 the schematic is 10-2.
                                      wait just found c164 and its unpopulated cap.
                                      • snipersquad100
                                        • Nov 2013
                                        • 297
                                        • uk
                                        is it worth getting the reading across the pads.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • boyebaran
                                          hisense 65k560 back light problem
                                          by boyebaran
                                          hi to all
                                          tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                                          in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                                          please advise me tnx
                                          05-20-2025, 07:11 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • multimesut
                                          Dell 2007FPB Yellow Light Problem
                                          by multimesut
                                          Hello friends,
                                          A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                                          11-13-2024, 07:00 AM
                                        • Tom_x
                                          HP Omen15 dc0001nh keyboard light problem
                                          by Tom_x
                                          Hi
                                          I have this HP laptop, board: DA0G3DMBCE0 rev:E
                                          The keyboard light only work, when i connect ac power supply(without battery), until the screen come with cmos checksum error. After this point light can't switch on. The first 5-6 seconds i can switch on/off light with FN+F4. When booing on, i can't switch on.
                                          Keyb light controller Y59116, i think working, because receive i2c commands the firsr 5 seconds
                                          I know schematic doesn't exist for this board
                                          Someone know similar board, that use this rgb keyboard light controller?
                                          regards
                                          04-05-2023, 10:32 AM
