Panasonic Plasma TC-P50GT30 7 blinks SC board shorted
  • ERICSSON89
    • Oct 2014
    • 46
    • NIGERIA
    #41
    Re: Panasonic Plasma TC-P50GT30 7 blinks SC board shorted
    hello everyone.
    I'm here to learn and I'm a student. please can anyone tell me about this SC BOARD, SU/SD? and what are they?
    any feedback would be nice.
    • myfastgti
      • Aug 2014
      • 32
      Thanks tw, I've ordered new SD board and will report back next 3 days.
      • myfastgti
        • Aug 2014
        • 32
        Finally I got the SD board and to my surprise the new board is shorted too. I've ordered new buffer chips from China and will wait to arrive and try not to rip off the tracks while removing the shorted chip.
        • myfastgti
          • Aug 2014
          • 32
          Hi Guys, wanted to give a quick update. Yesterday I got another SD board from the same seller at no extra charge, installed right away and the TV is alive, never thought I would see this day again.
          Just wanted to thank everyone who have helped me in diagnosing the problem especially TW and Alastair for your valuable time and great efforts in sharing the information and troubleshooting guide.
          Another TV saved from going into recycle. And TW you're right about not to replace the buffer chips cause they are glued to PCB and I ripped two tacks from my old board.
          • CoinCoin88
            • Nov 2014
            • 32
            • France
            #45
            Hi guys,
            Newcomer here. Domed by the infamous 7 blinks last Tuesday while watching Star Wars. No need to say I was pissed. As a good friend of mine is into video business (more like furnishing complete sets for TV or cinema). I asked him for help. While his tech was at it I rapidly found about the sc (and possible su/sd) defects. Today he told me exactly the same thing, and that he was trying to find a good deal because the complete sc board is around 200 euros. Bummer... (It's a p50gt30).
            I took the tv apart at his shop thinking that I'd inspect the board myself, since it's most likely blown mosfets. However my electronic skills are a little rusty.
            For now I have only the sc board with me, the rest is at his shop.
            My question: can I start troubleshooting the board while it's disconnected from everything else? So far I see a short between the two legs of sc2 and most of the igbt appear shorted (rfn10, rjp30h2a, rfn20, 30f131, daf30a)... That seems to represent a lot of this board, so I'm wondering if I'm doing things right. I'm planning to troubleshoot using sc50 and isolation of su/sad this week end or next Monday, but can I start with the sc board on its own or studying it while disconnected brings nothing?
            Thanks for your help!
            • tw2005
              • Oct 2011
              • 6458
              Originally posted by CoinCoin88
              Hi guys,
              If SC2 is shorted , don't bother with the SC50 isolation test. what's the point, you've also found shorted components.
              Also for info
              RFN10, RFN20,DAF30A are diodes and a good chance
              the shorted IBTs RJP30H2A, 30F131 may be contributing to them showing short.
              There are repair kits although hard to be sure they will cover every part blown.
              And test the buffers for shorts, beware of loose screws on the Sc and SS boards and or arcing/poor earth.
              • CoinCoin88
                • Nov 2014
                • 32
                • France
                #47
                Ok so basically I'm heading in the right direction, at least for now. I'll try to lift the pins of these shorted igbt, and see it it fixes the short in sc2. If it does, I'll just replace them and proved afterwards with isolation tests. Coil your confirm that it's the right approach ?
                Thanks for your help, I've read a couple posts on this board and you always seem to come up with valuable intel!!
                Edit: to test the buffers, should I refer to this post (https://www.badcaps.net/forum/showpo...0&postcount=15) ? As far as I understand, these measurements are taken on sd/su, not sc (or is it the "next step" after replacing shorted igbts on sc?)
                • tw2005
                  • Oct 2011
                  • 6458
                  That chart is for the series before so I'm not 100% if the pinouts are the same. There's a chance there is guide for 2011 models already in this thread. You could as a quick test put the meter in diode mode and put one on the gnd plates and slide the other slowly along the face of the ribbon connectors looking for shorts or get the manual and identify the labels in that chart and compare to the pinout on the Sd/Su boards and do the resistance tests.
                  I think the guide has an alternate method but I think the first challenge is repairing the SC. might be handy posting up the part number of the SC.
                  With the legs on those transistors I assume you'll heat the solder and gently lift the lags? Try not to get too much heat into the pads or they'll lift off the board.
                  • CoinCoin88
                    • Nov 2014
                    • 32
                    • France
                    #49
                    Yep I'll use a blade to life them slightly and see if sc2 is still shorted. I'll check in the 2011 guide if there's a way to test the buffers. First things first, let's see after lifting the shorted igbt legs if sc2 is still shorted.
                    • tw2005
                      • Oct 2011
                      • 6458
                      manual from Brazil with good detail for part numbers
                      • tw2005
                        • Oct 2011
                        • 6458
                        It's not just a matter of clearing the short at Sc2, you need to go over it entirely and maybe do a fair bit of searching to see if there have been successful repairs here, and also check out the kits for an idea what bit to check.
                        not going to be able to help much with this board not having repaired or seen one but a few have done S30 boards so the cct will be similar and I'd expect you'll get some input from them if you're patient.
                        • tw2005
                          • Oct 2011
                          • 6458
                          this may help a little
                          • CoinCoin88
                            • Nov 2014
                            • 32
                            • France
                            #53
                            Well i'venlifted one pin for each shorted igbt and i stil see sc2 shorted. This doesn't soundtrack so good...
                            • tw2005
                              • Oct 2011
                              • 6458
                              Quite often those IGBTs short across all 3 terminals. You'll need to lift both legs.
                              If the leg lifted is short to either of the othe 2, you may as well remove the whole thing. keep a note of what was where,
                              • tw2005
                                • Oct 2011
                                • 6458
                                What is the board number of the SC? TNPA5335BG? or ?
                                • CoinCoin88
                                  • Nov 2014
                                  • 32
                                  • France
                                  #56
                                  Tnpa5335ag
                                  • CoinCoin88
                                    • Nov 2014
                                    • 32
                                    • France
                                    #57
                                    As for lifting both legs, I've been trying for the past hour. Not sure why but solder at pin 3 never melts whereas there's no problem for the first one.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      what wattage iron? Since they have no heatsinks it's possible the size of the copper land is drawing the heat away? What are the location numbers of the parts?
                                      I guess you've used fresh leaded solder to assist in heat transfer?
                                      I think 40w would be at least what you'd need
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        I bet it's the emitter on the 30F131 that won't heat up. looking at what it's soldered too , massive copper lands, might even need more than 40w. If you don't have the right iron if you keep trying you may damage the board trying too hard.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          This is a kit worth studying, also shows FET driver Ic and pnp/npn dual transistor. that the 2 tiny SMD parts shown. Does have a DAF30 diode so expect that may be short on your board
                                          http://www.ebay.co.uk/itm/PANASONIC-...item232f6e5265
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                          • Yanleb
                                            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                            by Yanleb
                                            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                            D608, good
                                            D618 RF101L4S, good (See warning 1 below)
                                            D619 RF101L4S, good (See warning 1 below)
                                            D865 RF101L4S, shorted (See warning 1 below)
                                            IC464 Inverter HA MC74HC1G14, shorted...
                                            03-09-2020, 12:00 AM
                                          • nick31
                                            Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
                                            by nick31
                                            My Oct 2012 panny plasma quit working yesterday.
                                            It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
                                            Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
                                            I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
                                            04-21-2021, 09:56 AM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
