Problem with a Panasonic TH-42PZ80b
    Re: Problem with a Panasonic TH-42PZ80b
    Yep i did aha the two codes that are on the SC board is T TXNSC1RLTB the other one i have on their is 16060803272
      No TNPA number? It's written next to ORDER NO. It's possible you'll have to flip the board upside down to read off the TNPA number; Panasonic sometimes print it there for some reason.
        Yeah i got the seven blinks then i disconnected the sc2 and sc20 and then the green light flashed for about 3 secs then the light stayed green so it means the SC Board is gone?
          Your diagnosis would appear to be correct. Meanwhile, I believe your part is TNPA4410. Please confirm.
          You can get it cheap from here:-
          http://www.ebay.co.uk/itm/TXNSC1RLTB...item2c6d9fd824
          But I prefer to order from these guys, their returns policy is good, for an extra fiver. I had a dud part from them before, and they let me keep it and sent me a new one (which worked.) Can't fault that:-
          http://www.ebay.co.uk/itm/42-PANASON...item460f0237a6
          http://www.ebay.co.uk/itm/42-PANASON...item416f015a5f
            Thank you tom!
              Do let us know if it fixes the set!
                It still doesnt work
                  Is the fault code the same? All connections OK?
                    ive double checked to make sure i have connected everything and it still blinks 7 red lights
                      Is that with the buffer boards in place?
                        thats with all the boards connected
                          If you go back to the isolated SC does it power on normally?
                          It is possible you got a defective board, though I could not be sure.
                            I went through the guide again and i didn't get the 7 blinking lights and a picture came up and ill attach it at the bottom and so i reconnect the SD board like it said and it went bang and i said ahh crap and now i get the 7 blinking lights so i take it i will need to replace the SD board now Thanks Laurence
                              Did you make a connection change with the set powered up?
                                What do you mean?
                                  The only way I can see such a bang happening was if connections were changed while the set was still turned on, i.e. plugged into AC?
                                    Yeah i made sure the isolating crocodile clips wasnt touching anything and yeah AC
                                      So, the TV -was- powered up and you connected the buffer while it was powered up?
                                        I disconnected it all like it said on the guide then it didn't get the 7 blinks so i reconnected the SD board and then it went bang the TV powered down so i unplugged it checked it then plugged it back in and got 7 lights
                                          Yes that is what I am getting at. Damage like that can occur when you disconnect and reconnect stuff while live. All connection changes must be made with power off. But since you have still got distorted image on the top it might just be a case of replacing that damaged buffer.
