Problem with a Panasonic TH-42PZ80b
  • laurence1023
    • Nov 2013
    • 23
    #41
    Re: Problem with a Panasonic TH-42PZ80b
    would you be able to link me to one that ill need and is that it or do i need a SD board as well
      Just an SD board, I think. The part number (TNPA...) is written on it.
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
      • hugocarmo
        Panasonic TX-24A1UN CRT Sound and Input problem.
        by hugocarmo
        Hi.
        I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
        It is imaculate inside, almost no dust or debris inside.
        The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
        So I started to look for a service manual, I found one, and started from the beginning.
        Most of the times the caps are the problem so I orderer all the caps for all boards,...
        04-26-2025, 07:45 PM
      • renech
        panasonic TH-42PC77U plasma television half screen problem
        by renech
        hello,
        I hope someone on this forum can assist me.
        I have a panasonic TH-42PC77U plasma television.
        the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
        i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
        I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
        I have read some posts that suggest the problem is related to the boards on the left...
        12-12-2022, 06:53 PM
      • Vebririon
        panasonic TX-P50V10E 6 blink led problem
        by Vebririon
        I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
        Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
        I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
        05-17-2025, 10:16 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
