Problem with a Panasonic TH-42PZ80b
  • laurence1023
    • Nov 2013
    • 23
    • United Kingdom
    Re: Problem with a Panasonic TH-42PZ80b
    Yep i did aha the two codes that are on the SC board is T TXNSC1RLTB the other one i have on their is 16060803272
      No TNPA number? It's written next to ORDER NO. It's possible you'll have to flip the board upside down to read off the TNPA number; Panasonic sometimes print it there for some reason.
      • laurence1023
        • Nov 2013
        • 23
        • United Kingdom
        Yeah i got the seven blinks then i disconnected the sc2 and sc20 and then the green light flashed for about 3 secs then the light stayed green so it means the SC Board is gone?
          Your diagnosis would appear to be correct. Meanwhile, I believe your part is TNPA4410. Please confirm.
          You can get it cheap from here:-
          http://www.ebay.co.uk/itm/TXNSC1RLTB...item2c6d9fd824
          But I prefer to order from these guys, their returns policy is good, for an extra fiver. I had a dud part from them before, and they let me keep it and sent me a new one (which worked.) Can't fault that:-
          http://www.ebay.co.uk/itm/42-PANASON...item460f0237a6
          http://www.ebay.co.uk/itm/42-PANASON...item416f015a5f
          • laurence1023
            • Nov 2013
            • 23
            • United Kingdom
            Thank you tom!
              Do let us know if it fixes the set!
              • laurence1023
                • Nov 2013
                • 23
                • United Kingdom
                #27
                It still doesnt work
                  Is the fault code the same? All connections OK?
                  • laurence1023
                    • Nov 2013
                    • 23
                    • United Kingdom
                    #29
                    ive double checked to make sure i have connected everything and it still blinks 7 red lights
                      Is that with the buffer boards in place?
                      • laurence1023
                        • Nov 2013
                        • 23
                        • United Kingdom
                        #31
                        thats with all the boards connected
                          If you go back to the isolated SC does it power on normally?
                          It is possible you got a defective board, though I could not be sure.
                          • laurence1023
                            • Nov 2013
                            • 23
                            • United Kingdom
                            #33
                            I went through the guide again and i didn't get the 7 blinking lights and a picture came up and ill attach it at the bottom and so i reconnect the SD board like it said and it went bang and i said ahh crap and now i get the 7 blinking lights so i take it i will need to replace the SD board now Thanks Laurence
                              Did you make a connection change with the set powered up?
                              • laurence1023
                                • Nov 2013
                                • 23
                                • United Kingdom
                                #35
                                What do you mean?
                                  The only way I can see such a bang happening was if connections were changed while the set was still turned on, i.e. plugged into AC?
                                  • laurence1023
                                    • Nov 2013
                                    • 23
                                    • United Kingdom
                                    #37
                                    Yeah i made sure the isolating crocodile clips wasnt touching anything and yeah AC
                                      So, the TV -was- powered up and you connected the buffer while it was powered up?
                                      • laurence1023
                                        • Nov 2013
                                        • 23
                                        • United Kingdom
                                        #39
                                        I disconnected it all like it said on the guide then it didn't get the 7 blinks so i reconnected the SD board and then it went bang the TV powered down so i unplugged it checked it then plugged it back in and got 7 lights
                                          Yes that is what I am getting at. Damage like that can occur when you disconnect and reconnect stuff while live. All connection changes must be made with power off. But since you have still got distorted image on the top it might just be a case of replacing that damaged buffer.
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
                                          • hugocarmo
                                            Panasonic TX-24A1UN CRT Sound and Input problem.
                                            by hugocarmo
                                            Hi.
                                            I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                                            It is imaculate inside, almost no dust or debris inside.
                                            The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                                            So I started to look for a service manual, I found one, and started from the beginning.
                                            Most of the times the caps are the problem so I orderer all the caps for all boards,...
                                            04-26-2025, 07:45 PM
                                          • renech
                                            panasonic TH-42PC77U plasma television half screen problem
                                            by renech
                                            hello,
                                            I hope someone on this forum can assist me.
                                            I have a panasonic TH-42PC77U plasma television.
                                            the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                            i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                            I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                            I have read some posts that suggest the problem is related to the boards on the left...
                                            12-12-2022, 06:53 PM
                                          • Vebririon
                                            panasonic TX-P50V10E 6 blink led problem
                                            by Vebririon
                                            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                            05-17-2025, 10:16 AM
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
