Sony KDL-37M4000 NEED new tcon to screen cables
  • high-tech
    • Sep 2010
    • 197
    Hello guys I got a sony 37" that the screen cables are bad, they seem to get torn when the screen flexes like moving the tv around ect.
    Anybody know where I can buy a pair of these ribbon cables?
  • Rick
    • Aug 2010
    Re: Sony KDL-37M4000 NEED new tcon to screen cables
    your panel is bad
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Rick - care to elaborate on that?
      • freakaftr8
        • Oct 2012
        • 3743
        If the cables you speak of are the one that are fused into the panel then no.... The panel is no longer usable and the tv is scrap. The Panel costs more than the tv is worth.
        It's an uunfortunate outcome to lcd tv's. Everything else is usually repairable or replaceable except the actual screen.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          you can buy certain ribbon cables on ebay once you know the spacing (pitch) etc unless as above post there bonded to the screen.
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • alltvrepairs
            Lg TCon test pins for screen test
            by alltvrepairs
            i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
            Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
            Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
            Appreciate your help....
            06-13-2025, 06:33 AM
          • iglitare
            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
            by iglitare
            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
            Backlight seems to work, Sound (Setup menu after reset) works.
            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
            With my small knowledge i would think at least the cables are good.
            Can this happen because of a bad tcon board?
            Or is it always a bad/shorted...
            09-04-2025, 07:13 AM
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
