kdl-52w4100 6 blink error issue need help
  • jettboat
    • Nov 2012
    • 63
    I tested the screen seems to be ok it shows up while a bright lights directed at it, also did resistor to ground to remove the 6 blink inv err, still get no back light . The problem seems to be with power supply 395 pfc volts supplying the inverter boards is only 8.5 not enough to supply the inverters properly? I tested components on both inverter boards and power supply. They all seem good. I would like to at least get it narrowed down to the individual board that's at fault. I have fixed 60 or so lcd & plasmas mostly to component level but this ones frying my brain. Anyone with incite/help on this model? I do have access to o-scope, signal generator etc. I have the basic multi meter, esr, variable 15vdc ps at home. Its my first time posting pic hope there ok from my phone.
  • jettboat
    • Nov 2012
    • 63
    Re: kdl-52w4100 6 blink error issue need help
    I forgot to add that I get all voltages @ back light on 1.82v, dimmer 1.71v and all other connections seem good how printed on the boards, but pfc's 395v going to the inverter boards being very low. I have the service manual also, It states the inverter boards are the issue but, I find no problems on them at all. Was thinking of removing the pfc connectors then inject the 395v into them to see if there ok but I can't do this until Monday @ school & if its wise to do this or not?
      Are you getting only 8.5V at those two large 450VDC cap also?
      Service manual:
      http://elektrotanya.com/?q=showresul...oria=&kat2=all
      • jettboat
        • Nov 2012
        • 63
        yes that's all
        • jettboat
          • Nov 2012
          • 63
          Whoops! I was using the wrong ground. I do get 392 @ the pfc output now I need to make sure I didn't test wrong on other things.
            OK, that's better. Training manual for EX1 chassis.
            • jettboat
              • Nov 2012
              • 63
              Thanks budm I had the manual already but it made me look at it again. Looking at the manual it is pointing me toward the main board, the inv err is normally high I thought it was supposed to be low like the bal err, whoops. I'm also only getting 1.8 for bl on and it should be 3.3vdc. after testing all the other inverter circuits and they were good had me lost. time to order a new board, I will update if it is good to go with a new one.
              • jettboat
                • Nov 2012
                • 63
                Well the training manual lead me wrong its not the main bu board. I'm going to have to test the output of the inverters going to the balancer boards Monday. The trouble shooting flow chart was wrong! go figure well guess if it was easy every body would do it. lol On to the Panasonic sc repair for now.
                • jettboat
                  • Nov 2012
                  • 63
                  Ok here was the issue a 16v 100mf cap was shorted (odd) on the d5 inverter board tied to a IC on the back as there's only a couple caps there they all looked good, replace them all & another TV was saved.
                    Glad to hear it is fixed.
                    • cheeky2
                      Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                      by cheeky2
                      For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                      See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                      01-08-2024, 05:56 AM
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      🛠 Original Issue
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • cloo
                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                      by cloo
                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                      After doing a factory reset this problem was gone and the picture was back to...
                      01-06-2025, 06:02 AM
                    • ugamazing
                      by ugamazing
                      12-17-2024, 07:05 PM
                    • eccerr0r
                      inverter H tree driver imbalance in an AC inverter
                      by eccerr0r
                      My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                      11-16-2025, 12:34 PM
