KDL-40W5810 flashing red 14 times
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Hi, I have this Sony Bravia kdl-40w5810, When powered on a red light flashes 14 times then a pause then keeps repeating this process, I found a post saying it ment it was a faulty T-Con so i replaced it with one i bought online but still i have the same problem, Anyone know what the fault could be??
    Re: KDL-40W5810 flashing red 14 times
    Is the T-CON getting the 12VDC at the SMD fuse on the T-CON board?
    • Easky15
      • Sep 2013
      • 285
      • Ireland
      How do i test that?? Sorry I'm new to TV repairing so still learning.
        Post good clear picture of the T-CON board, especially around he connector that goes to the main board, there will be small SMD fuse close by. You do have digital meter, right?
        • Easky15
          • Sep 2013
          • 285
          • Ireland
          Yes i have a multimeter but its not very good, Hopefully it's good enough for the job, Didnt wanna splash out on the best of everything just yet as i'm only learning still but if it's an essential then ill get one, I'll include a pic of it,
            OK, make sure the mount the board in place without the cover for now, there is F1 (WHITE) fuse on the left side by the small white connector.
            Turn the TV ON, then set meter to DCV, Black probe on the metal chassis, red probe on each end of the fuse at a time, you should see around 12vdc on either end of the fuse with ref. to the chassis ground.
            • Easky15
              • Sep 2013
              • 285
              • Ireland
              It's showing as 1.15dcv.... I tested the meter on a dc12v adapter and it read 11.8 so the meter seems to be working fine..
              • tibimakai
                • Jan 2012
                • 3680
                At each end?
                • Easky15
                  • Sep 2013
                  • 285
                  • Ireland
                  Originally posted by tibimakai
                  At each end?
                  Sorry should have specified that, Yeah same 1.15v DC each end..
                    Well, that is one of the problem. if you trace out that end of the fuse to the other board that the wires go to, then you can see what yo have at the connector on the other board.
                    Can we see the pictures of the whole back side of the TV so we can see how they are connected? The power may have come from the connector on the right side of the board, I can see one big power trace there.
                    LCD panel number? So we can look up the spec sheet and the pinout of this T-CON board.
                    • Easky15
                      • Sep 2013
                      • 285
                      • Ireland
                      Hope these help.. These are all the cables that were in the tv when i got it but i get loads of them and sometimes they have been opened and had boards missing, Shouldnt there be a cable goin from the white connector on the t-con labled CON3 to the power board where its labled CN6151 or does the T-con get power from the cable coming from the main board, Again sorry if these are dumb questions, Still learning.. :-)
                      • Easky15
                        • Sep 2013
                        • 285
                        • Ireland
                        Sorry for wasting everyones time, I found another bravia 37 inch and removed the cable going from the power board to the t-con, tv now works fine, Thanks again everyone at BadCaps.net.. ;-)
                          Glad to hear. The cable that goes to CN6151 (4-pin) on the power board?
                          • Easky15
                            • Sep 2013
                            • 285
                            • Ireland
                            Yeah mate, that cable, put it in then it fired up straight away but the old T-con is faulty so thankfully i didnt buy it for nothing and waste money,
                            • STKR123
                              Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                              by STKR123
                              As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                              I wonder if re-flashing the BIOS might be of any use here.
                              As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                              There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                              11-03-2024, 06:58 AM
                            • esqmooo
                              HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                              by esqmooo
                              Hello everyone.
                              This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                              Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                              Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                              I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                              03-11-2025, 03:57 PM
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • reessi
                              HP 14-CE0523SA (14-CE0000 Series) - DC / Charge LED Flashing 5 Times White!
                              by reessi
                              DA0G7AMB6D1 REV.D Board:
                              A strange fault occured while I was calibrating the battery. This battery had not been used for a while.
                              Previously to calibrating the DC/Charge LED operated normally:
                              Off when no charger,
                              Solid Orange while charging with Charger,
                              Solid White when 100% Full with charger.
                              I charged to 100% then left it playing a long youtube video,
                              as expected the guage was wrong and it just cut off before reaching the low percent where it would sleep.
                              It wouldn't power on so I plugged charger expecting to...
                              07-06-2023, 09:59 AM
