Insignia LCD TV NS-L32Q-10A screen blinking...
  • selldoor
    Slow Learner
    • 7870
    Re: Insignia LCD TV NS-L32Q-10A screen blinking...
    Are those (on) voltages when the set has gone into dark mode?
    Have you got a known source dvd playing or pc input?
    When it is dark can you see a very dark image on screen - perhaps with a flashlight
    on the screen at an angle.
    We are going to need pictures please post one of the back of the set and one of each board - must be clear in focus. Use manage attachments jpg less than 3mb
    • thro
      • Jul 2014
      • 6
      1) Yes
      2) No, cannot choose an input source, nothing on screen
      3) Can't see anything.
      Added pics.
      • selldoor
        Slow Learner
        • 7870
        when it says please wait how long is that displayed.
        maybe it is searching for a source which is why I asked for one to be connected.
        Did your friend say what might have happened - went off while on? didnt come on? Power surge? lightning?
        • thro
          • Jul 2014
          • 6
          It stays on for 2 seconds. I connected a DVD player and no change. He said turned it on, no picture but had sound.
          • thro
            • Jul 2014
            • 6
            Any ideas?
            • selldoor
              Slow Learner
              • 7870
              #26
              Does it still have sound?
              On the inverter board test the secondary windings on each of the small transformers
              No power to boards meter on ohms 2000
              • thro
                • Jul 2014
                • 6
                no sound, OL on transformers.
                I get no voltage at CN8802 (connector from power board) on the inverter board. What should it be?
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  Well that is jolly lucky for you - You see where is says DANGER high voltage
                  - It really means it.
                  You are either on the wrong pins on the small transformers or need a higher scale on the meter - is there a part number on the transformers
                  use it to look up the pinout.
                  • thro
                    • Jul 2014
                    • 6
                    part # 80GL32T-14-DN
                    DARFON 6518A 921115Z
                    I could not find any info on the transformers. I tried every pin combo only reading besides OL was 000.6 ohm on middle and 4 pin using a fluke 87.
                    • valvashon
                      Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                      by valvashon
                      For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                      History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                      01-04-2024, 01:44 PM
                    • cloo
                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                      by cloo
                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                      After doing a factory reset this problem was gone and the picture was back to...
                      01-06-2025, 06:02 AM
                    • EazyBone
                      Un50cu7000 2 blink oddity *partially solved
                      by EazyBone
                      I write this to maybe help another with this TV.
                      So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                      The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                      03-18-2024, 10:24 PM
                    • x_orange90_x
                      by x_orange90_x
                      01-29-2025, 09:24 PM
                    • YasaCh
                      Sony kdl 40p5500 red light keeps blinking 3 times
                      by YasaCh
                      Hello...
                      my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                      i opened the back cover no sign of damage on the powery suply or motherboard
                      when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                      another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                      07-07-2025, 11:53 AM
