Samsung SyncMaster LD220HD HDTV/Monitor - no power on
  • oddbodd
    • Mar 2013
    • 121
    Re: Samsung SyncMaster LD220HD HDTV/Monitor - no power on
    OK, thanks.
    I'd better start reading up...
    • oddbodd
      • Mar 2013
      • 121
      Test results...
      [still with F301 still disconnected]
      IC5003
      ƆII -> line 1 of the IC [A backward C and 2 vertical lines]
      1117 -> line 2 of the IC
      0945FG -> line 3 of the IC
      pin 1. = 0.001
      pin 2. = 0.001
      pin 3. = 0.001
      IC1009
      17-33 -> line 2 of the IC
      0944DG -> line 3 of the IC
      pin 1. = 0.001
      pin 2. = 1.2 to 2.0
      pin 3. = 1.8 to 3.3
      IC1001
      78 M0 9A -> line 1 of the IC
      KW 9A -> line 2 of the IC [the W might be V]
      pin 1. = 0.001
      pin 2. = 0.001
      pin 3. = 0.001
      Back side...
      IC2004
      0942FG -> line 3 of the IC
      pin 1. = 0.000
      pin 2. = 0.000
      pin 3. = 0.001
        When you say "1.2 to 2.0" and "1.8 to 3.3" do you mean the readings are jumping?
        • oddbodd
          • Mar 2013
          • 121
          Yes, they fluctuate quite quickly.
            Well, that is a problem. Are you sure the suffix is -33? If so, need to trace where that fluctuating 1.8~3.3V is coming from.
            • oddbodd
              • Mar 2013
              • 121
              Yes, it's 17-33.
              • oddbodd
                • Mar 2013
                • 121
                Does that mean it's toast?
                • oddbodd
                  • Mar 2013
                  • 121
                  Any suggestions?
                    I would consider replacing that regulator, but if that fails, you would probably need a schematic to trace the circuit and figure out what might cause this fault.
                    • oddbodd
                      • Mar 2013
                      • 121
                      Google doesn't bring up much relating to voltage regulators marked 17-33 0944DG. Does the 0944DG just relate to the assembly date etc?
                      Any suggestions for a suitable replacement? Otherwise, will any 1117 3.3v regulator be OK?
                      I've not found a schematic for the board so far, either.
                        It's a short code for a 1117-3.3V type. Package format is SOT223.
                        • oddbodd
                          • Mar 2013
                          • 121
                          OK, thanks.
                          I've just been looking on ebay, and it looks more like TO-252, which is a square format, rather than rectangular.
                          Like this one.
                            See post 7 for link to Digikey:
                            https://www.badcaps.net/forum/showth...999#post300999
                            • oddbodd
                              • Mar 2013
                              • 121
                              OK, NCP1117ST33T3G, that's SOT-233... so do they comes in both square and rectangular formats?
                              I'm not sure whether the rectangular one would fit.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #55
                                Unles the ebay link you gave is misleading that NCP1117ST33T3G has to be wrong it has 3 legs plus tab
                                Digikey have this one LD1117DT33TR
                                If you are near any of the outlets, rs online have dpak 1117 3.3v - may be worth checking them out
                                Depending on whether you can collect or delivery charges you could get one of these from
                                cpc see here : http://cpc.farnell.com/texas-instrum...k-3/dp/SC10562
                                they had a cheaper one but is out of stock but I think they have free delivery and no handling charge even for small
                                orders so even a more expensive one may work out cheaper overall. Check the physical size before you order.
                                • oddbodd
                                  • Mar 2013
                                  • 121
                                  OK, thanks.
                                  I'll check out the LD1117DT33TR.
                                  • oddbodd
                                    • Mar 2013
                                    • 121
                                    I've ordered that one from cpc.farnell.
                                    78p, free delivery.
                                    • oddbodd
                                      • Mar 2013
                                      • 121
                                      It was a real pain to get the old one off.
                                      Is it just the 2 pins that need resoldering onto the board?
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        #59
                                        Usually its the Two outer pins and the Tab - was the tab soldered on the old one?
                                        • oddbodd
                                          • Mar 2013
                                          • 121
                                          I think so. It was stuck fast to the board, and when I finally got some movement, I had to lever it off of the tab side.
                                          I'll add a dab of solder to the tab.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • mrtek
                                            Samsung UN43NU6950FXZA No power
                                            by mrtek
                                            Hi
                                            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                            Main fuse = OK
                                            Back light LED = OK. Power them with aux power source
                                            LED output = OK 156V
                                            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                            Yesterday, 08:06 PM
                                          • Journey11
                                            Samsung TV won't turn on ... keeps cycling the power relay on & off
                                            by Journey11
                                            Hi All,
                                            First time posting here ... my name is Kevin but my friends call me Journey.
                                            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                            07-04-2024, 02:44 PM
