Vizio GV47LFHDTV10A No Picture No Sound Fix
    Re: Vizio GV47LFHDTV10A No Picture No Sound Fix
    Originally posted by bleed4me
    As soon as I get home I can get that for you... This wouldn't be about amp rating on that ic would it?
    No, I just want to make sure it is not heavy load on the output pin is causing low output Voltage.
    • bleed4me
      • Nov 2015
      • 122
      Just checked the resistance, 90.2
        OK, that is fine, nothing <10 Ohms range.
        • bleed4me
          • Nov 2015
          • 122
          Well parts came in and just finished installing those lil guys. TV powers on as it should with backlight and will now turn off without having to unplug it. I am not sure what is going on with the hdmi ports, plugged in a chromecast and I get nothing on either port. Could it be a setting or are those hdmi ports toast? I did try a dvd player hooked up via rca cables and the picture looks great. The speakers are not plugged in and I wouldnt imagine that interfering with the hdmi ports or am I wrong?
            So I am curious about the DCV readings now on those two new ICs.
            So do you know the history of this TV? It might have been hit by the surge which usually also come through the HDMI ports.
            • bleed4me
              • Nov 2015
              • 122
              I never get a straight answer to the tvs story when I pick them up. I mostly just get "oh it just stopped working". This TV was no different so sadly I have no story to tell. So if it was a surge does it typically ruin the HDMI port itself or is it the board that faults out? As soon as I get home I will most definitely get you the voltage readings.
                You can check and see if the HDMI chips get the Voltage to them or look for damaged chips.
                • bleed4me
                  • Nov 2015
                  • 122
                  Well budm you were right they are tricky to solder. Got the voltage readings like you asked and it appears I need to revisit DU4
                  DU4
                  pin 1-0
                  pin 2-0
                  pin3 - 3.32
                  U5
                  pin 1-.71
                  pin 2- 1.97
                  pin 3- 3.33
                  You think that could be the cause of the hdmi issue?
                  • bleed4me
                    • Nov 2015
                    • 122
                    After revisiting DU4 TV now FULLY works as it should. HDMI all work as they should now, new voltages
                    DU4
                    pin 1- 0
                    pin 2-1.25
                    pin 3- 3.3
                    Just want to say a huge thanks to all that chimed in expecially nicktv and budm, couldnt have done it without you. Your knowledge and patience is much appreciated. Learned a great deal with this tv and I have you guys and this forum to thank for that.
                      Glad to hear that the TV is working.
                      • Nick's Tvs
                        • Jan 2014
                        • 621
                        Bleed4me,
                        Don't thank me, I only gave you basic info at first. All that more technical advice was from budm.
                        I am glad to hear that you got the set fixed and working however!
                        • Electronic Handyman
                          • Apr 2016
                          • 58
                          I have the same model GV47LFHDTV10A that has a damaged main board.Anybody have the actual schematic for it?I can only find trouble shooting charts for and I need a true schematic that shows me what parts connect to what.Also if you've the schematic for the audio board and anything else it would be much appreciated.I've had the set sitting in storage so I can give the actual board part numbers but I'd love to fix it.Thank you in advance
                          • Miragui
                            • Sep 2016
                            • 14
                            • Venezuela
                            #73
                            Hi I just registered to thank the members in this thread.
                            It helped me fix my TV, it had the same symptoms no picture an no sound, checked all the voltage regulators and fuses and U4 was bust. Luckily I could source one from and old Xbox360 DVD drive PCB I had laying around.
                              Thanks for the report on what you found bad.
                              • Maverick67
                                • Mar 2018
                                Hey I just found this same TV. Someone had put it curbside and I figured why not take a look. Found this thread and dug around. Yup Blown fuse. Up and running now. Thanks for the help.
                                • ggil44
                                  Vizio M65-E0 No Picture, No Sound
                                  by ggil44
                                  Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                  09-03-2024, 08:30 PM
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • TR103
                                  by TR103
                                  - it keeps rebooting
                                  01-22-2025, 04:12 PM
                                • Mgiffune
                                  by Mgiffune
                                  I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                  I ordered a supposedly β€˜new' Tcon board this time, and
                                  06-09-2024, 10:28 AM
                                • Ierwin
                                  by Ierwin
                                  05-13-2025, 03:31 PM
