My First Oscilloscope
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Hello everyone. I just bought my first oscilloscope. It's a Hitachi V-1065A DC-100MHz 2 Channels 40W oscilloscope. Seeing how I'm going to use it to try and fix TVs I thought this would be the right place to post. It doesn't come with any cables, I've never used one before. I ordered it through E-bay. The link to it is http://www.ebay.com/itm/261258262152...84.m1497.l2649
    It doesn't appear to come with any cables. What types of probes should I buy for it? Also, does anyone have any good reading material on how to operate one of these things? If it turns out I bought the wrong one for fixing TVs, I could always resell it. I did a little research and someone said that a 100MHz one would be ideal for TV repairs.
    One last question, what exactly do I do with it when I get it? I know they show sin waves and stuff, but what exactly are they for? Reading clock-pulses and stuff like that? Thanks.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: My First Oscilloscope
    You really need to understand what characteristic waveforms that you expect
    to see in the various areas of the equipment you are fault finding. No simple way to explain this in detail.
    There are inexpensive 100MHz 10:1 probes on eBay which should be ok for most measurements but they tend to be less durable and their voltage rating cant be trusted. Try to measure Horizontal deflection waveforms in a CRT TV and you might damage the probe and oscilloscope.
    To safely take measurements in this area, you need a 100:1 probe rated at 2Kv or more.
    I like to use genuine HP probes like 10071A. They never fail but the plastic cord covering goes stiff after 10 years of use.
    Try searching for "how an oscilloscope works"
    • Spork Schivago
      • Mar 2012
      • 4734
      Okay, thank you. Just so I understand this correctly, I can use an HP probe with a Hitachi oscilloscope? And can I use the 100:1 probe rated at 2Kv or more for most of the measurements as well? Or do I need to use the 10:1 for most measurements and the 100:1 probe for areas like the Horizontal deflection waveforms?
      Come tomorrow I will check youtube for videos on how oscilloscopes work. I read some wheres there's a 2+ hour video on there that explains everything about them. I definitely don't want to ruin it when I get it in the mail.
      • rievax_60
        • May 2012
        • 897
        • australia
        The brand of probe doesn't matter.
        You can use the 100:1 probe for most other measurements also but it may be a little clumsy because of its likely larger size and the 100:1 attenuation will be problem when measuring small signals.
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          Good Luck...
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            Try this video out, Hope you have unlimited internet its a long one.
            Liberating magic smoke one part at a time
            • RON_CET
              • 217
              Here's pdf of owners manual for your Scope,Note!!! you might want to use a Isolation transformer when your working on CRT TV chassis which are consider HOT chassis before connection of any test equipment or you could severely damage your equipment the TV and yourself,you can Google (using isolation transformer for HOT or Live chassis) to read more.
              Ron Driver,BSEE,CET,ISCET,NESDA
              • Spork Schivago
                • Mar 2012
                • 4734
                I'll have to google using an isolation transformer for HOT or live chassis because I have no idea what an isolation transformer is or what a HOT is. I've seen it written on a couple motherboards for the TVs I've worked on. Thanks for the help everyone! I'm a bit behind on this and I appreciate everyones help. I haven't had a chance to watch the video yet but I will either tonight or tomorrow. Had a bit of running to do today. I will try and order the HP probes off E-bay now.
                Real quick like, any good books to read on how electronics work? DC electronics? Easy to understand. Like a for dummies type book. I took a digital electronics course back in around 99 or so. I can replace broken parts but I cannot understand how they work. I'd love to get into making some of my own circuitry. I've made some before but it was always following schematics.
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  Hey, I found an HP 10071A 10:1 150MHz oscilloscope passive probe, however, it says it's 150MHz. Would that work? My oscilloscope will be 100MHz. If that works, when I order the 100:1 one, could I use any MHz probe? Or does it need to be at least 100MHz?
                  What does passive mean? Is that the one I want? Thanks for the manual and the link to the video guys!
                  • Caleb
                    Smokin IC's
                    • Feb 2013
                    • 645
                    Yes you can use higher frequency probes on a low frequency scope, the rating is based on the limitation of frequencies that the probe can pass. If you put a lower frequency probe on the scope it will only be able to see the frequencies the probe can pass. Higher is better but also more expensive. Buy at least 100mhz as that is how high your scope can go. Passive means the probe is not powered but only sees the voltage from the end of the test lead.
                    Good starter book on basic electronics is "Electronic circuits for the Evil Genius" Fun to read and easy to understand.
                    • RON_CET
                      • 217
                      Basically, to answer your last question (this applies to passive probes), probes are generally manufacture specific as the probe, if it's an attenuating probe like the standard 10:1, need to be compensated by adjusting a small screw inside the probe that is adjusting a cap. This is done by connecting the scope to a 1 KHz square-wave signal at 300mV to 1V Pk-Pk and there is a small access hole in the side of the probe to insert a tuning tool. You adjust it for maximum squareness of the waveform. When you turn the screw one way, the sides of the wave peak-up and when yo turn it the other way the sides have a smooth curve.
                      Active probes are generally only needed for circuits that have an impedance higher than about 1 meg ohm. The passive probes (10:1) generally have a 10 Meg Ohm resistive input an between about 7 to 15 pf input capacitance depending on the scope brand. This is why the probes are generally scope brand and model dependent. The problem you get into is that the probe will not compensate as I described it above. You can use another brand or model of 10X passive probe so long as it will compensate to your scope with a nice square (both sides & top & bottom) square wave. Since the 10X probes are generally 10 Meg Ohm, they will not load down a 1 Meg Ohm Circuit much and your measurement accuracy will remain fairly high with about a 10% error on voltage readings on the low side due to the voltage divider effect of the 1 meg ohm ckt with the 10 meg ohm probe. If the circuit impedance is below 1 meg ohm, your accuracy will be even better.
                      My recommendation would be use a passive probe and use a TP6100 for your Hitachi V-1065A, hope this helps
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        Thank you. There's 2 100:1 probes I found. One is a 2KV one at 100MHz, one is a 4KV one at 100MHz. The 2KV should be fine for TVs, right? Would I ever find a need for the 4KV one?
                        26.41$ for the 2KV, 46.91$ for the 4KV one...
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          Originally posted by RON_CET
                          ... My recommendation would be use a passive probe and use a TP6100 for your Hitachi V-1065A, hope this helps
                          Thanks for the reply. I found a couple P6100's on E-bay. Was the TP6100 a typo?
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            I think I found a pair! http://www.ebay.com/itm/Two-x1-x10-1...item2580c95723
                            Now for the 100:1 one, what make / model should I go for?
                            • RON_CET
                              • 217
                              here's photo
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                here's photo
                                Okay, those are the ones I just bought. They look identical, minus the rings. It comes with rings but they're not on and the ground is hooked up on the picture of the two I bought, everything else is good though.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  Any one have any idea on what 100:1 one I should purchase?
                                  • RON_CET
                                    • 217
                                    go ebay search for theses two item numbers ( 221004910206) and (281121905213)
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      I think the 2KV one will be enough. Any voltages higher than this in a CRT TV are DC which have no need to be checked with an oscilloscope if at all. These voltages are usually measured with a multimeter and 1000:1 probe. Best to avoid these areas for now.
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        Thank you. I'm going to go for the 221004910206 I think. The 281121905213 had a few things different. The Input Capacitance was a smaller number (6pF vs 14.5-17.5pF) and the compensation range was 10-35pF vs 15-35 pF. Do those differences matter much?
                                        • irnard
                                          Micro SMD probe tip for Rigol oscilloscope ?
                                          by irnard
                                          Any advice where can I find micro SMD probe tip for Rigol oscilloscope ? Can't find anything online and factory one is just too fat to fit in some tight spaces on logic board. Thx
                                          02-09-2023, 09:22 AM
                                        • Tarot Superstars
                                          How not to Damage an Oscilloscope
                                          by Tarot Superstars
                                          Hello.
                                          I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
                                          I want to learn how not to damage it, and I found instructions on the internet obscure.
                                          They talk about ground, earth, floating ground, this, that....
                                          But they don't actually say anything anything useful so far.
                                          I want to know:
                                          Don't connect exactly this to exactly there or it blows up.
                                          For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
                                          I want to know what not to connect...
                                          08-29-2023, 02:27 PM
                                        • SolomonMan
                                          Vintage BK Precision 1403 Oscilloscope....
                                          by SolomonMan
                                          All,
                                          Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                                          Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                                          I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                                          12-03-2023, 10:39 PM
                                        • JimBanville
                                          MOSFET mystery
                                          by JimBanville
                                          N channel mosfets testing as P type?
                                          Working on a smps.
                                          Using Fluke 115. Red probe in red socket. Black probe in black/common socket. Meter set to diode mode.
                                          Removed a pair of mosfets marked 1L02AB FDP
                                          26N40 from the circuit.
                                          The pair of Mosfets are still screwed to the single heatsink. Mosfet printing facing me.
                                          I did the test where I short the left and center pins. I put black probe on right pin and red probe on center pin. I get OL. While keeping black probe on right pin, I put red probe on left pin and get OL. After a few seconds I move red...
                                          09-14-2023, 04:22 PM
                                        • Evets
                                          Dynamco analogue oscilloscope
                                          by Evets
                                          I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
                                          08-30-2024, 06:54 AM
