My First Oscilloscope
Re: My First Oscilloscope
My oscilloscope came today!!!! I'm still waiting on my probes though. I wanted to try and test the oscilloscope. I have something I bought when I was a kid called a function generator (HP 3310B). I want to hook it up to the oscilloscope. Can I use a 6 Foot RG-58 BNC-to-BNC 50 Ohm cable assembly from Radio Shack? The item number is: 2103481. The function generator's output impedance is 50 ohm...-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
Yes.
The amplitude will be 2X larger than the signal generator is set to, because the function generator expects the output to be terminated with 50 ohms. However, this does not indicate a fault with the oscilloscope.
Almost every scope also has a "probe compensation" output which can be used to check functionality. It typically produces a 1kHz, 2Vp-p square wave.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Almost every scope also has a "probe compensation" output which can be used to check functionality. It typically produces a 1kHz, 2Vp-p square wave.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
You will need a probe to connect to probe compensation, hence the name. It's intended for setting the compensation (filter network) of the probe correctly; refer to the documentation which comes with your probe. In the meantime, a wire between the central pin of the BNC and probe comp could do the job.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I think I have a problem with my oscilloscope. I've been reading the manual and there's an up/down lever on my scope called the Selector level. It says in the manual "Move the SELECTOR lever upward and downward to illuminate the desired function lamp. Then adjust the VARIABLE control. The options I'm supposed to be able to select are SINGLE, A/B SEP, DELAY, HOLDOFF, TIME, H POS, MEASURE, Delta Symbol V, Delta T, 1/Delta T, and FREQ. I cannot get it to move off of H POS. Am I doing something wrong or is my scope broken? I just want to calibrate the probes right now. Thanks-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
What trigger mode is it set to? Perhaps try cleaning the control, it could be dirty and not making good contact.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostWhat trigger mode is it set to? Perhaps try cleaning the control, it could be dirty and not making good contact.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
Yeah, it does sound like that control may be faulty which sucks. You might have to send the scope back. Perhaps the control is replaceable, but that would involve tearing into the scope to find a part #.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostYeah, it does sound like that control may be faulty which sucks. You might have to send the scope back. Perhaps the control is replaceable, but that would involve tearing into the scope to find a part #.
S1603 Lever - (Hitachi part number) SSL0076 (real part number) AL2S-2M (WITH NOBAZ4004) (description?) I could not find anything with those numbers on the net. I found something that involved genomes. That's not what I'm looking for though.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
Sorry to say yes I also think you have problem with your selector switch on you Scope.
That switch is a rocker type switch with center position,so with normal operation your selector switch should be in center position then you can move upward or downward 1-click at time with selector switch returning to center position which allows you to step through your measurement settings,I would contact seller and advise of issue and seek his return policy,that feature not working on the scope would be in my opinion a valuable feature not functioning.Ron Driver,BSEE,CET,ISCET,NESDA
Thanks Ron CET. I agree. I had an idea of how it was supposed to work. I've been in touch with the seller and I really don't want to send it back. I'd love to be able to get it working and everything, being my first scope and everything. There's ones on E-bay now, same model and everything for around 300$. This was 115$. I explained everything to him and he found the part I need in his warehouse and is sending it to me. He said he's shipping it out today. Do you guys think this would be an easy repair? I'd have to take the unit apart. The function generator is broke. I think it's the step-down transformer inside. I'm getting 0V on every wire. It was a pain to take a part. Would this be similar? All I have to do is remove the front cover. The service manual shows a diagram of it apart but it's hard for me to follow. If I remember correctly, the quality isn't the greatest. Any ideas? Thanks for the help!
Spork-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
I know this conversation has long since been dead, but I did eventually get the part I needed. The guy I bought it off of went back to the warehouse, found another one, ripped it apart and send me the whole front board (with the selector switch). Thanks.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
