Panasonic TC-P50s2 7 blink problem
+ More Options
Posts
  • Gies40
    • Aug 2013
    • 29
    Re: Panasonic TC-P50s2 7 blink problem
    p.s :
    What's the training guide?
    • Gies40
      • Aug 2013
      • 29
      p.s.: What's the training guide?
      Last edited by Gies40; 08-28-2013, 04:46 PM. Reason: it is a duplicate. I didn't think the 1st post o training guide went.
      • tw2005
        • Oct 2011
        • 6458
        You've already tested the SC with that jumper and isolation procedure. It's faulty, I'm just interested what evidence it presents at those connection points. The 5105 is very similar to my 5081 in cct design.
        ebay, probably won't be cheap and hopefully you don't get a dud.
        There's not an exact guide for this one or mine but generically you can get some good testing tips which can be applied across 2009/10 models.
        http://www.ebay.com.au/itm/YSUS-BOAR...item417522f79c
        • Gies40
          • Aug 2013
          • 29
          TW,
          I took the SC board resistance . .
          SC2(VSUS) + polarity 273K - polarity 22M @VSUS
          P5V 17M 22M @ SD46 SORRY, that was at pin #2
          SD 46 Pin #1 was o.o both directions
          P15V 4.2K 1.58K @ TP82
          How does that look?
          Let me know if any other SC readings would help.
          • Gies40
            • Aug 2013
            • 29
            TW, would that board on ebay satisfy my SC board? My SC board P/N is TNPA5105-AB? and the TV is TC-P50S2
            • tw2005
              • Oct 2011
              • 6458
              P5V is pin 35 at SC20 or TP16,17 - gnd or across c561. Expect 5.6K
              P15V I'd expect 1.3 - 1.4K looks ok, not shorted
              SC2 i think maybe 300k the first time but if you take off the probe and go back usually goes into a few M ohms.
              Nothing obviously shorted, was expecting either Sc2 or 15v to show bad.
              A repair kit on Ebay for 7 blink on this has these, Q421/Q422/Q451/Q401/Q402/Q661/D482/R551/R451/IC16521
              Sd46 Pin 1, is gnd so O is correct for gnd-gnd
              pin 2 is not P5V so result is not relevant.
              • tw2005
                • Oct 2011
                • 6458
                These all use the same SC,
                PANASONIC
                TC-P50S2, TC-P50U2, TC-P50C2 ,TX-P50U20B, TX-P50S20B
                you'd have to confirm with the seller yourself as he does not give revision.
                • Gies40
                  • Aug 2013
                  • 29
                  I'll check the PV5 again. I couldn't find TP16 or 17 on my board so let me try again.
                  • tw2005
                    • Oct 2011
                    • 6458
                    probably on underside, Just probe across the capacitor.
                    I'm wondering if it is at all possible for 7 blink on bad SS?
                    SC is very common, I hate being wrong, I never take it for granted the onboard SOS is a 100% , I prefer to see if I can confirm something failed on the SC.
                    • Gies40
                      • Aug 2013
                      • 29
                      P5V at SC20, pin 35 was 5.56K as expected.
                      SC2 did as you predicted.
                      Have you found the repair kits on Ebay reliable? How about the confidence factor in the kit doing the job? I haven't gotten into Ebay purchases yet but I guess it might be time to start. It has to be much less expensive that the boards.
                      • Gies40
                        • Aug 2013
                        • 29
                        I called Panasonic to get a comparable price for the SC and the clerk couldn't find the SC board number in their system. Tat was a real surprise. No wonder the SC is so hard to find.
                        • tw2005
                          • Oct 2011
                          • 6458
                          never sourced the kit, I can generally work most things out and have sourced from china some bits. OEM is procey and if it does not fix it or there are other issues good chance they'll blow.
                          The list of parts is what we could use though as a "Guide".
                          Check out those bits and see if shorted or open resistorss, burnt etc.
                          Only advice for eBAY, always use paypal just in case you get ripped off or faulty. Can be handy as you can lodge a dispute through them if need be and it has helped me in a couple of faulty boards because they reverse the transaction but suspend payment.
                          That generally gets the seller hopping.
                          • tw2005
                            • Oct 2011
                            • 6458
                            Try another enquiry using TXNSC1LQUU, I would expect if you gave them the model of TV they should be able to cross reference the parts that way, but getting the right person on the end of the phone who uses their initiative can be a challenge.
                            • Gies40
                              • Aug 2013
                              • 29
                              Help me understand the part numbers being different but the boards being interchangeable. I gave the clerk the TV model no. as well as the board I.D. but no luck. Most likely, as you said, the right person on the phone is necessary. I'll give them a call again today.
                              My household is getting impatient with my repair so I think if I can get an SC board from Panasonic I'll probably go for it even though I would like to go with the repair kit at some point to repair the existing board. I'm looking for the kit on line also, it will help me personally.
                              BTW, I keep hearing clerks in the stores talk about the Plasma TV being pushed out of the way by LCD, what's your take on that?
                              Thanks for all the help,
                              • Gies40
                                • Aug 2013
                                • 29
                                TW, I'm looking at the board you found on Ebay. Does the revision letter matter on the board? I would think that if it did matter they would change the P/N not just the revision letter.
                                Thanks,
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Not sure what you're getting at. The ebay item if it is out of the TV they state then it will work , i gave you a list of some models with the same boards.
                                  TNPA5105 is a PCB number i.e. the same bare PCB is used for a number of revisions / TV sizes.
                                  AB 50"
                                  look here and you might get an idea. 3 different rev, 3 Tv sizes 42, 46, 55"
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    definitely Plasma appears to be on the way out. Not much on the shop floors here
                                      Yeah plasma is dying, slowly, to LED-LCD, which is a shame, because it is being replaced by inferior technology. Hopefully OLED comes soon, pay £50 for a 42" FHD OLED stuck in standby.... :P
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        AB 50"
                                        whoops. Here: http://www.shopjimmy.com/catalogsear...lt/?q=tnpa5105
                                        • Gies40
                                          • Aug 2013
                                          • 29
                                          Thanks, I have a link with shopjimmy now so that when they get an SC board they automatically let me know via e-mail. I just hope it doesn't take toooo long.
                                          I didn't find the component repair kits on line - the ones with resistors and transistors, etc. - Even if I get a SC from shopjimmy or elsewhere I might try and repair the old SC just to see that I can and have it as a spare since they are sooooo hard to come by.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
                                          • tiku
                                            Panasonic TH-L32C30D P-Board (1 Blink-Backlight_SOS)
                                            by tiku
                                            Hello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
                                            I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...
                                            09-05-2021, 05:02 AM
                                          • dajoker
                                            Panasonic th-p50s10d - blinky red, SC board go boom
                                            by dajoker
                                            My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
                                            I chased my way through the PSU, and a board, with no results.
                                            Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
                                            I only have the right half of the picture.
                                            Left half is completely blank.
                                            now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
                                            all the other voltage rails...
                                            09-24-2024, 04:39 AM
