Panasonic TC-P50s2 7 blink problem
  • Gies40
    • Aug 2013
    • 29
    Hi, this site is great, the help I see provided here is much more than I ever expected. Thanks for being here. I'm new to the thin TV repair work, including plasmas.
    My tv shut down completely and I noticed on trying to restart that the indicator light blinked 7 times. I found on line that it was supposed to be the power supply board, bought a new one on-line, installed it but had the same problem. I disconnected the SS board and had the same 7 blink problem, re connected SS and disconnecting the SC board and saw the same 7 blink problem.
    I'm currently only capable to service at the board level (not board components except maybe caps) but don't know where the problem is therefore which board(s) to replace. I have looked at the caps and found none that looked puffed up.
  • Gies40
    • Aug 2013
    • 29
    Re: Panasonic TC-P50s2 7 blink problem
    Any ideas on what the problem might be?
    • tw2005
      • Oct 2011
      • 6458
      SC boards fail a bit on these but also could be SU, SD or worst case panel.
      Could try this.
      Remove the 4 VF_GND screws on the SU,SD boards
      Unplug connectors SC41, SC46, and SC42 on the SC board.
      Jumper pins 1 and 2 of connector SC50 on the SC board.
      Then plug in the TV and turn it on.
      Note: Do not allow the TV to stay on for more than 30 seconds
      Is the TV still shutting down with 7 blinks?
      No: faulty buffer boards ( TV will actually power up normally with no error blink if SC is good)
      yes, Disconnect SC20. Plug in the TV and turn it on
      Did the number of blinks change to 6 blinks?
      Yes : faulty SC
      No: A board
      If SC is faulty, good practice to also check buffer board resistance as they too could be faulty or shorted.
      The steps above I copied from a flow chart.
      • Gies40
        • Aug 2013
        • 29
        Thanks tw2005, I'll try it as you say.
        • Gies40
          • Aug 2013
          • 29
          I ended up with 6 blinks after disconnecting SC20 so based on the flow chart you referenced I have a faulty SC board.
          You also said to check the resistance of the buffer boards.
          Considering that I'm new at this how exactly would one do that?
          Thanks in advance.
          • tw2005
            • Oct 2011
            • 6458
            So I take it with the jumper at SC50 you still had 7 blinks then?
            • tw2005
              • Oct 2011
              • 6458
              see if you can make sense of post 58
              https://www.badcaps.net/forum/showth...t=26322&page=3
              you have same buffers as mine except i believe you have no heatsinks.
              I'd measure in both polarities with the probes and see if they get close, meter will need to be able to read 5-6 M ohms although as long as it can read to 2 Mohms that should give a reasonable idea.
              Don't want greatly lower or shorted. Gnd to all buffer output pins should show nothing in diode test from memory.
              If you feel like it , on the SC measure resistance across SC2, and the P5V , P15V in relative to gnd at SC20.
              Download the service manual for guidance where those points.
              List the readings for everything you get.
              This one has 10 blink, also bad SC and buffers appear to be bad too from what's been said.
              https://www.badcaps.net/forum/showthread.php?t=30375
              • Gies40
                • Aug 2013
                • 29
                Yes, 7 blinks with SC50 jumped.
                O.K., I'll take a look as you suggest.
                Thanks,
                • tw2005
                  • Oct 2011
                  • 6458
                  Did a few edits , not sure if you saw everything.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Another 10 blinker, but SC reported bad too.
                    https://www.badcaps.net/forum/showth...light=tc-p50s2
                    • Gies40
                      • Aug 2013
                      • 29
                      Yes, thanks TW, getting the service manual now and looking for my multimeter - I haven't used it for a few months.
                      • Gies40
                        • Aug 2013
                        • 29
                        TW, I'm having trouble finding the test pads on the boards. I did go to the service manual SC boards layouts but didn't find "VFO", "VSCN-F" (I did find VSCN but no "F" with it. ), the "5V_F" etc., from your charts. I guess that could be just any 5V test pad?
                        I can measure them if I can find them but so far, no luck. Is there a place that explains the codes?
                        Thanks again,
                        • tw2005
                          • Oct 2011
                          • 6458
                          Thanks again,
                          The SD and SU buffer boards are what you're testing next.
                          Try the block diagram 4/4 maybe and connectors are SU41 SD42 on the buffer boards.
                          all you have to do is find the connector (there's only 3 between SC,SD,SU), identify which pins are 1,2,3 ...etc..9, measure between the gnd plate and each pin as I have in that post and write it down.
                          Boards disconnected from SC, and disconnect the little ribbon between.
                          see how you go with that.
                          • Gies40
                            • Aug 2013
                            • 29
                            Yes, I see that we're testing the SD and SU boards but the terms under the "SD42" column in the chart confused me.
                            So am I to understand that the terms under SD42 in your chart are the names of those pins, not some test pad that I bridge to? O.K., if that's it I'll go right to it. I'm just a little slow getting up to speed. Thanks,
                            • tw2005
                              • Oct 2011
                              • 6458
                              Yeah, if you find that block diag, that's where I got the labels from, find the pins 1 -9 and measure to gnd. I don't understand fully those labels either, that's just what they have called them.
                              • Gies40
                                • Aug 2013
                                • 29
                                Should the 4 VF_GND screws and the SC20 ribbon cable to the A board be reinstalled and the jumper be removed prior to measuring the resistance? In other words the only thing disconnected would be SC 41, 42 and 46 and use those GND screws as ground?
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  I'd normally take the boards out and do it but should be able to get an idea at the connectors but you won't be able to test the output to gnd if the panel is connected to it.
                                  • Gies40
                                    • Aug 2013
                                    • 29
                                    I removed the SU and SD boards and measured the pins with both polarities.
                                    I thought I got some crazy readings like 38M on some pins under one polarity measurement but when switching they were more reasonable.
                                    The results follow:
                                    SD Board:
                                    + Polarity - polarity Target
                                    pin # 1 6.49M 30M 1.86M
                                    #2 218K 218K 220K
                                    #3 OL
                                    #4 Ol
                                    #5 38M 6.6M 5.3M
                                    #6 38M 6.6M 5.1M
                                    #7 OL
                                    #8 38M 1.14M 5M
                                    #9 OL
                                    SU Board:
                                    #1 OL
                                    #2 6.36M 26M 1.9M
                                    #3 OL
                                    #4 218K 218K 220K
                                    #5 OL
                                    #6 OL
                                    #7 Ol
                                    #8 38M 7.7M 6.3M
                                    #9 OL
                                    I don't know how far off the resistance needs to be to cause a failure but pins 2, 5,6 and 8 on the SD seem to be out of range too far as do pins 2 and 8 on the SU. My inexperienced judgment would say that SC, SU and SD boards need to be replaced. Would the bad SD and SU boards make the SC board look bad while it may be functioning properly or is it good judgment to replace all three. Comments please.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      The results follow:
                                      SD Board:
                                      #2 218K 218K 220K
                                      #3 OL
                                      #4 Ol
                                      #5 38M 6.6M 5.3M
                                      #6 38M 6.6M 5.1M
                                      #7 OL
                                      #8 38M 1.14M 5M
                                      #9 OL
                                      SU Board:
                                      #1 OL
                                      #2 6.36M 26M 1.9M
                                      #3 OL
                                      #4 218K 218K 220K
                                      #5 OL
                                      #6 OL
                                      #7 Ol
                                      #8 38M 7.7M 6.3M
                                      #9 OL
                                      I would say they're ok, nothing obviously shorted and the results from each board are similar. Can't explain why, but the ones in bold are what they get you to test in the training guide.
                                      I would give them a go again, finding a SC will be the hard part for this,
                                      How did you go with the SC board at the SC2(Vsus), 5v & 15V lines
                                      • Gies40
                                        • Aug 2013
                                        • 29
                                        O.K. Yes, getting the SC board doesn't look good. I tried shopjimmy but it's out of stock.
                                        I'm sure Panasonic's $$ would be much higher. Any other ideas?
                                        I didn't get to the SC board test yet. That's the plan for tomorrow. If that tests fine where do we go from there? The screen itself?
                                        What's the training guide?
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • tiku
                                          Panasonic TH-L32C30D P-Board (1 Blink-Backlight_SOS)
                                          by tiku
                                          Hello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
                                          I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...
                                          09-05-2021, 05:02 AM
                                        • dajoker
                                          Panasonic th-p50s10d - blinky red, SC board go boom
                                          by dajoker
                                          My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
                                          I chased my way through the PSU, and a board, with no results.
                                          Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
                                          I only have the right half of the picture.
                                          Left half is completely blank.
                                          now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
                                          all the other voltage rails...
                                          09-24-2024, 04:39 AM
