Vizio GV52L washed out picture
+ More Options
Posts
  • waltemus
    • Aug 2013
    I have a Vizio GV52L FHDTV10A that I've been working on for some time now. The picture looks like the brightness is cranked all the way up even when the setting is all the way down. No matter which inputs I use, the picture looks the same. The menu screen looks washed out too.
    The change happened suddenly while I was watching it so nobody changed any of the factory defaults without me knowing.
    A few photos of the screen:
    http://i138.photobucket.com/albums/q...814_224340.jpg
    http://i138.photobucket.com/albums/q...814_224452.jpg
    http://i138.photobucket.com/albums/q...814_224327.jpg
    Any tips or ideas would be greatly appreciated!
    Re: Vizio GV52L washed out picture
    It is more likely to have failed GAMMA Voltage reference circuit, the IC such as AS15 on the T-CON board.
    For example:
    https://www.badcaps.net/forum/showth...mma#post304275
    • waltemus
      • Aug 2013
      I disassembled the TV to where I could access the T-Con board and gave it a good inspection. I discovered a trim pot with the following characteristics:
      For connections A, B, and C...
      A -> B = 0 ohms
      B -> C = A -> C
      This holds true no matter how I rotate the pot. (I did mark its original position first)
      Sounds to me like its shorted and needs to be replaced...but I don't know for sure what the maximum resistance is supposed to be.
      The T-Con board is a Phillips 6870C-0175C
      • waltemus
        • Aug 2013
        The trim pot actually is acting like the red line is an open, not a short.
        • csmith
          Vizio D50u-D1 Powers up no picture
          by csmith
          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
          issue. Set will power up with remote but not power off....
          07-11-2025, 11:52 AM
        • mecha1166
          Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
          by mecha1166
          I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
          07-03-2024, 05:03 PM
        • gavric
          Vizio M70-C3 Half picture is bad, main board on its last leg?
          by gavric
          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
          When tv powers on vizio V logo shows nice on whole screen. picture 1
          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
          When i click video to start playing picture goes black(like when you change...
          09-02-2021, 08:55 PM
        • ggil44
          Vizio M65-E0 No Picture, No Sound
          by ggil44
          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
          09-03-2024, 08:30 PM
        • maricm
          Vizio m65-c1 picture flashing on and off on the screen
          by maricm
          HI all,
          hope someone point to the possible issue before I start buying replacement parts.
          Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
          Backlight stays on all the time,
          Sound works fine.
          screen keeps changing form black to full picture in about 1sec intervals.
          Picture looks fine with no visible artifacts.
          I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
          Disconnecting left and right ribbons on...
          11-25-2023, 06:32 PM
