Vizio E371VA lightning surge - no pic or sound
  • sumdumgai
    • Aug 2013
    • 33
    My first actual post and I'm hoping for, and would appreciate, some good help. A nearby lightning hit knocked out our Vizio E371VA TV. The cable box got zapped, too, so I'm thinging that the surge came into the TV through the HDMI cable. The logo at bottom front of the TV lights up when power is on, but there is nothing on the screen and no sound. I don't believe there is any backlight. I replaced the power supply board with one that I bought on eBay, but it did not make any difference. Same symptoms.
    To start what I hope will be a series of diagnostic steps, how do I check the power supply board to see if it is okay? I have a multimeter and have very limited electronic troubleshooting skills. I have replaced resistors and such in the past in other devices but only at someone else's direction.
    Thanks for helping and being patient with me.
  • jose6326
    • May 2013
    • 707
    Re: Vizio E371VA lightning surge - no pic or sound
    make sure to post pictures of the board layout
    it helps the guys on here to help you diagnose your tv problems
    • sumdumgai
      • Aug 2013
      • 33
      I'll take some and post them. Thanks.
      • johnboy1313
        • Nov 2012
        • 1959
        I would suspect the main board. Once we see the pics, someone should be able to guide you through the process of forcing your power supply/backlights on with the main board disconnected. This should verify that the power supply and inverter(s) are working correctly.
        • westom
          • Jul 2010
          • 40
          It's called electricity. If an incoming path exists but no outgoing path, then no electricity exists. Your answer starts by identifying both the incoming and outgoing path. Then something (not everything) in that path may be damaged.
          A multimeter can measure DC voltages to three digits. BTW, a numbers that is near 12 volts can be completely defective. The number is more important than declaring "good or bad".
          Measuring is a good place to start. Since nothing will make sense if a power supply is marginal or defective.
          Now, identify the incoming and outgoing path. If your cable was properly earthed BEFORE entering, then that was not the incoming path.
          A most common path is a direct lightning strike far down the street to utility wires. That current is incoming to every appliance via AC mains. What is damaged? Most appliances are not. What makes a best 'outgoing' path to earth? Incoming to the Vizio on AC mains. Out via its HDMI port. Into the modem. Out to earth ground via the cable.
          First current is everywhere in that path - simultaneously. Much later something fails. Often damaged is the outgoing path - HDMI port.
          That's the easy part. Also easy is to say, "Now, identify the incoming and outgoing path." Much harder is actually doing that. Especially since damage from a lightning strike typically has no visual indication. And Vizio will not share schematics.
          • sumdumgai
            • Aug 2013
            • 33
            Attached are pics of five boards and entire chassis. Thanks for your help.
              Since the power LED is working, the 5vSTBY power supply is working, more likely that the main board is damaged.
              You can force on the backlights by connect 1K resistor btween the PS_ON pin and the 5VSTBY pin, and another 1 K resistor between the BL_ON pin and the 5VSTBY pin to see if the backlights will come on.Notes, you muast disconnect the wires between the main baord and the power supply board to do the force on test.
              • sumdumgai
                • Aug 2013
                • 33
                I'm sorry but you're way ahead of me. Where are the pins you are referring to, and how do I connect this resistor? Please understand I am new at this. Thank you for your help.
                • sumdumgai
                  • Aug 2013
                  • 33
                  OK, I think I found the PS_ON pin (3rd pin) on the power supply board on the connector going to the main board. There are two +5V pins (1st and 2nd pins) next to the PS_ON pin. Are these the 5vSTBY pins? Can I use either as 5vSTBY?
                  Where is the BL_ON pin?
                  Thanks for you help and patience.
                  • sumdumgai
                    • Aug 2013
                    • 33
                    Picture of main board connector on power supply attached. Is the BL_ON pin any of these? Thanks.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Can we get a pic of the other connector on the PSU?
                        on/off = BL_ON
                        May need to have 1K resistor between the DIMM (Backlights Dimming control) and the 5VSTBY if it is an analog control type signal, just do without for now to see if the backlghts will stay on.
                        Check to see if the 24V is present also.
                        Make sure to disconnect the cable between the power supply and the main board.
                        • sumdumgai
                          • Aug 2013
                          • 33
                          Pic of other connector attached.
                          • sumdumgai
                            • Aug 2013
                            • 33
                            So, if I understand you correctly, I am to connect a 1K resistor between the PS_ON pin and a +5V pin on the PSU, and another 1K resistor between the ON/OFF pin and the other +5V pin on the PSU connector that goes to the main board. The cable between the PSU and the Main Board is disconnected. The other cable on the other PSU connector remains connected to the inverter (I think). These connections should force the backlight to come on. I will also measure the voltage on the 24V pins on the PSU connector, with TV off and then on.
                            Please confirm. Thanks.
                              That is correct. You should measure 24V when TV is plugged in with the resistors in place.
                              • sumdumgai
                                • Aug 2013
                                • 33
                                Ran the test with resistors. Backlight came on and the +12V pins read about 12 volts each and +24V pins read about 24 each.
                                What's next? Thanks.
                                  This would point to a defective main board.
                                  • sumdumgai
                                    • Aug 2013
                                    • 33
                                    Can it be diagnosed and repaired? Any ideas on where to buy one if that's the only way? Thanks.
                                      Since the surge took out the main board, it will be real difficult or just about impossible since it may have many damaged sections, you may get one section fix just to find out the other sections do not work. For example, you may be able to fix it so it will send out the correct signals to the power supply board, but then you may find out that the tuner or the HDMI may not be working.
                                      • westom
                                        • Jul 2010
                                        • 40
                                        Descxribed was how a mainboard often is damaged. Identify the incoming and outgoing path. If your cable was properly earthed BEFORE entering, then that was not an incoming path.
                                        A most common path is a current incoming on AC mains. Best 'outgoing' path to earth would be an HDMI port. Current is everywhere, simultaneously, in that path - incoming and outgoing. But often the outgoing path (HDMI) is only damaged.
                                        Its your gamble to replace the mainboard. Since everything you can do to identify the actual defect has been done. I would get a replacement mainboard. Since damage even from lightning is typically only on one part. In your case, that is often electronics that drive the HDMI port - the outgoing path.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • shelby5041
                                          vizio d40f-j09 no pic no sound standby always clear
                                          by shelby5041
                                          hi
                                          anybody have experience with this model tv
                                          07-19-2025, 06:58 AM
