samsung UN22D5010 no power
  • capkid
    • Oct 2010
    • 1339
    Re: samsung UN22D5010 no power
    I'm no expert when it comes to PSUs, and I would defer to Bud. In general, you should test the components yourself to confirm whether they're functioning correctly.
    LG Plasma Mal-Discharge Correction Service
    • jose6326
      • May 2013
      • 707
      You are right Capkid I should have asked you how to test it.
      I am no where near you guys level in electronics
      So how do you test it?
      • capkid
        • Oct 2010
        • 1339
        I learned quite a bit about fixing TVs and testing components from John Preher - still learning:
        http://preher-tech.com/documents/optoisolators
        Someone may have an alternate method for testing these. For most components, you can do a search online to pull up info on how to test. If you're unsure about the component's type, just pull up a data sheet.
        • jose6326
          • May 2013
          • 707
          Thanks for the info
          Only problem is that I dont have an analog meter
          In method 2 it instructs you to use both dmm and anolog meter to test
          I will test it at work
          • jose6326
            • May 2013
            • 707
            i did a search on PC801S and i just kept getting data sheets that led me to other electronic components i dont need
            i went on digikey to see if i can find it
            there are numbers on the opto but i dont know which one is the part number
            here is what it looks like
            1104
            817B
            there is what looks like the letter L before the numbers 1104 but i think it is the logo of the manufacturer
            i typed in the numbers in different ways and the closest i found was this on digikey
            http://www.digikey.com/product-searc...rt=LTV-817B-ND
            there is no pdf on the lite-on opto only for the fairchild one
            the difference between the two is the fairchild opto has a 70V output compared to the 35V output on the lite-on opto
            i think the lite-on opto is the original one i need since it is out of stock and everything i have been needed has been out of stock
            i attached the pdf of the fairchild opto
            budm please let me know if this is an equivalent replacement
            thanks
              It is a PC817.
              http://www.digikey.com/product-searc...=0&pageSize=25
              • jose6326
                • May 2013
                • 707
                im guessing any of the first 4 will do?
                thanks tom
                • jose6326
                  • May 2013
                  • 707
                  are these optoisolators common on most different brand of tv's?
                  i seen this opto on the polaroid psu and the samsung psu
                  i was thinking of ordering extras thats why i ask
                    They're reasonably common industry standard devices.
                    • jose6326
                      • May 2013
                      • 707
                      Ok I replaced the opto, all the caps and the really small chip on the back side and still nothing
                      I am getting the 120 line voltage
                      I checked voltage at the large cap 171.1v
                      and medium cap .595
                      I also checked voltages at both connectors
                      White connector is 0.000 at every pin
                      Black connector is .6 at every pin
                      So im guessing there is something else that is defective and not letting the power come thru
                      What else should I test?
                      Not sure how to test rectifier
                      • capkid
                        • Oct 2010
                        • 1339
                        Testing bridge rectifier: http://www.youtube.com/watch?v=dqkT6hF0O3E
                        FYI: You can Google most components to find tests for them.
                        I'd cut bait on this TV. IMHO, it's just not worth the time.
                        • jose6326
                          • May 2013
                          • 707
                          Thanks capkid
                          I tested rectifier and it is good
                          • jose6326
                            • May 2013
                            • 707
                            I would toss this tv but its a good way to learn
                            I wanted it to connect my phone to it and use it as a monitor
                            • jose6326
                              • May 2013
                              • 707
                              i forgot to ask
                              when i installed the opto does it matter the postion i install it?
                              i figured i would install it the way the original was installed but it may be pinned differently
                              also i tested the diodes on the board and the ones in green tested good
                              i got readings one way and not the other
                              but im not sure about the components in the red boxes
                              are these diodes?
                              i tested all of these and i was getting readings both ways
                              i will retest again
                                Yes, the Opto has the LED emitting side and the Photo transistor side.
                                Those are Diodes.
                                • jose6326
                                  • May 2013
                                  • 707
                                  ok i will remove the opto and switch it around
                                  hopefully that is why it did not power on
                                  i will retest diodes again
                                  thanks
                                  • jose6326
                                    • May 2013
                                    • 707
                                    retested the diodes according to the youtube video
                                    http://www.youtube.com/watch?v=_3G8t-cV1d8
                                    All 3 diodes in the red box read 0.000 whether i change the leads positive to negative or vice versa
                                    The other 4 diodes in the red box I get 2 readings
                                    If I put the negative probe on the leg of the diode with the silver line I get 0.132
                                    And thats for all 4 diodes
                                    When I put the positive probe on the leg of the diode with silver line I get 1.435 and it continues to go up to 1.644 and slows down but still continues to go up
                                    This is for all 4 diodes
                                    Are all of these diodes defective?
                                    https://www.badcaps.net/forum/attach...&d=1377709100I
                                    • jose6326
                                      • May 2013
                                      • 707
                                      I also tested the mosfet off the board
                                      Here are the readings
                                      Starting with positive probe
                                      1-2: OFL (open)
                                      2-3: 0.000
                                      1-3: OFL (open)
                                      Starting with negative probe
                                      1-2: OFL
                                      2-3: 0.486
                                      1-3: OFL
                                      Not sure if defective or not
                                      • capkid
                                        • Oct 2010
                                        • 1339
                                        Originally posted by jose6326
                                        I retested the diodes according to the youtube video
                                        You might have to remove them from the board to get accurate readings.
                                        • jose6326
                                          • May 2013
                                          • 707
                                          I was planning on doing that
                                          I will post udated readings tonight
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • mrtek
                                            Samsung UN43NU6950FXZA No power
                                            by mrtek
                                            Hi
                                            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                            Main fuse = OK
                                            Back light LED = OK. Power them with aux power source
                                            LED output = OK 156V
                                            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                            07-20-2025, 08:06 PM
                                          • hill01
                                            Samsung UE75MU7009TXZG Endless Power Cycle
                                            by hill01
                                            Hi everyone and thanks in advance for any help I might get here
                                            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                            Since a few days, the TV won't turn...
                                            11-17-2021, 02:52 PM
                                          • Journey11
                                            Samsung TV won't turn on ... keeps cycling the power relay on & off
                                            by Journey11
                                            Hi All,
                                            First time posting here ... my name is Kevin but my friends call me Journey.
                                            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                            07-04-2024, 02:44 PM
