Panasonic TC-P42S2
+ More Options
Posts
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Panasonic TC-P42S2
    service manual and training guide links if you need them.
    • tw2005
      • Oct 2011
      • 6458
      Originally posted by kcblack
      Hello, New Here
      Have 2010 Panasonic TC-P42S2 plasma with the 10 blinking lights. Cannot bring up a menu from the TV or HD digital cable box. When first turning the set on it clicks like normal and then after a few seconds clicks again. Black screen with blinking power light.
      Took off back panel and disconnected the board on the left side. Turned the power on and now have 6 blinking lights. This suggests the SC board is bad. Is there a chance it could be the SS board and how do i test to see if the board is malfunctioning?
      Thanks for you assistance,
      K
      Check Q661 on the SC TNPA5105 board and see if it is dead short across the legs. It's on the heatsink with two transistors right next to the SD connector.
      http://www.ptselectronicsinc.com/txnsc1lhuu/
      • kcblack
        • Nov 2016
        Picture of back of TC-P42S2 Panasonic plasma TV
          After all of...
          07-13-2024, 08:14 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • H34TO
          ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
          by H34TO
          Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
          06-17-2025, 07:17 AM
        • boosti45
          Macbook pro logic board replacement parts quesion
          by boosti45
          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
          08-21-2024, 05:23 AM
        • Cvrado
          Led TV Board Replacement, same part number and model, different size
          by Cvrado
          Hello my friends!
          I have a question that I think you can answer and help me with!
          I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
          So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
          My concern is that the board won't draw enough voltage to the bac...
          03-02-2024, 05:05 PM
