Sony KDL-46W4100 vertical lines
  • tibimakai
    • Jan 2012
    • 3680
    I have just picked up this TV, which is in like new condition, but it has these vertical lines.
    Service shop diagnosed it through the phone and they said that it's the mainboard.
    To me it looks like T-Con board issue, am I right?
  • capkid
    • Oct 2010
    • 1339
    Re: Sony KDL-46W4100 vertical lines
    It looks like a main board issue to me. I would have expected lines in your third picture if it were just the T-CON. Also, everything onscreen in the first picture appears to be superimposed over the lines.
    LG Plasma Mal-Discharge Correction Service
      I am going to say main board as well. The T-con is unlikely; unless, it is a TV with motion interpolation and it turns off the motion interpolation when in the menus. Then it could be T-con but main would still be possible.
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        looks very much like main board,can you run a scart lead or hdmi out to another tv?,if the pic is same on other tv,then it would prove main board failiure.
        fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
        please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        • tibimakai
          • Jan 2012
          • 3680
          It's possible to send signal to another TV?
          Tom, do you see, another mainboard issue.
            SCARTing out is only available on some European TVs with bidirectional SCART ports... personally I have never managed to get it to work. Never heard of any TV with HDMI out.
            If you had a TV with the same or similar panel, you could put them back to back and connect the LVDS from one TV to the other. This has been done before with success by one member.
            I am more suspect of the main board but would appreciate a picture of the T-con to confirm if it has the motion interpolation (100/120/200/240/400/480Hz or Sony MotionFlow/MotionPro) on it or not.
            • tibimakai
              • Jan 2012
              • 3680
              It seems that it has it:
              http://store.sony.com/p/KDL-46W4100/en/p/KDL46W4100
                I need a picture to know if the T-CON or MAIN BOARD has the motion interpolation on it. (Or perhaps on a third board like older SONY use.) I know this TV has it.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I will have to take it apart. I have just brought it home last night.
                  Here is Memorial day weekend, so I won't work to much today and tomorrow.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Some weird development.
                    I have opened the TV, and I have noticed that the mainboard it looks the same as my other 40" with weird colors.
                    First I have installed both 40" boards(the original and the one from Ebay) and the TV turned on, but didn't show anything on the screen, just the backlight.
                    No error codes, or nothing, LED it was green, when everything it's OK.
                    I thought of installing the 46" mainboard in the 40", and to my amazement, the 40" works great.
                    So I have two bad mainboards for the 40"?
                    This 46" mainboard it seems good if it runs well on the 40"?
                    Picture is taken with my phone.
                      That seems like a good conclusion to make. See, how many dud boards we get. It's crazy, no one bothers to test the boards they pull, it's just "well why would they smash a broken TV... they must be working... no way they could have got angry with it..."
                      The large SONY chip on that board is probably the motionflow processor. It's just a rebranded Samsung processor, I expect. (Basically every Sony TV is a Samsung with better capacitors...) Replacing the T-con is probably the only viable option there.
                      You will probably find that 40" and 46" main board can be exchanged on this model but many Sony LCD are fussy about that.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        What I don't understand, why the 40" board doesn't work on the 46"?
                        The 40" it's a year newer the the 46".
                        What is interesting, that on Ebay everybody sells only broken screen TV's boards.
                        I'm not sure if I will get back my money from that person. He said that the sale is final. I may have to go to Ebay for my money.
                        I can say now for sure, that I have a bad(or two) board on the 40"?
                        • capkid
                          • Oct 2010
                          • 1339
                          Sony main boards are very particular. A lot of times, you have to match up the serial number and/or panel version. I use ShopJimmy to confirm which boards will work.
                            So... let me get this straight, you have:
                            one KDL-40xxxxx main board which works in 40" with bad colours, 46" perfectly?
                            one KDL-40xxxxx main board which does not work in any TVs at all
                            one KDL-46W4100 main board which does not work in 40", and does work on 46"?
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I have a KDL-40V4100 with those two mainboards showing those weird colors.
                              And I have a KDL-46W4100 with vertical lines.
                              The 46" board works in the 40", but none of the 40" boards work in the 46".
                                The T-con probably has an EEPROM on it that the main board reads. Perhaps the 40" main boards are detecting the incompatibility, but the 46" isn't.
                                • cashkennedy
                                  • Aug 2011
                                  • 668
                                  Out of curiosity, what does the motion extrapolation chip on the tcon do? Does it require any additional data from the motherboard that a regular tcon would not need?
                                  Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                                    It can sometimes require extra data.
                                    Basically 120Hz TVs add one extra frame in between each frame at 60Hz. This is supposed to make the motion more fluid. (In reality it tends to make it look fake and artificial, but some people like the effect.)
                                    The motion interpolation is done by a high performance ASIC/DSP. The processor analyses each and every pixel in the image. The search range may be around +/-30 pixels around each pixel. If it calculates a motion change between two objects within this range, it attempts to create an in-between frame which interpolates them. Obviously, this requires a helluva lot of processing. Despite all of this, it has the disadvantage of not interpolating larger changes.
                                    If you try this algorithm on the menu interface etc you'll get weird effects (objects moving to the side of it will drag through it) so there is usually a bit of data transmitted telling the T-con what areas to exclude from the motion interpolation. You can see this on TVs which use transparent menus (e.g. Samsung LE40A656.) The background of the menu appears to judder behind the rest of the screen. I'm not sure how this extra data is sent (mask data), probably somehow encoded into the LVDS or I2C, but it's the only main difference between TVs with interpolation and without it. Perhaps on some TVs the motion interpolation is disabled entirely when a menu pops up, but most I have seen use masks.
                                    • cashkennedy
                                      • Aug 2011
                                      • 668
                                      I figured all the inbetween frames were created by the main board, did not know they were throwing that on the tcon. Makes some sense so they can use mainboards in sets with lower hz panels. Probably makes the tcons super exspensive for factory new replacements, not that ive ever in my life bought a "new board" for a tv.
                                      From what I assume, newer plasmas create a few inbetween frames themselves to fill in the 600hz refresh rate, where are those calculated on a plasma?
                                        ...duplicate post...
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • Stanley1843
                                          Screen Display Vertical Multicolor Lines
                                          by Stanley1843
                                          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                          06-29-2024, 11:54 AM
                                        • noisykid
                                          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                          by noisykid
                                          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                          12-30-2024, 07:15 PM
                                        • dustman1747
                                          Sony XBR-65X900H vertical lines
                                          by dustman1747
                                          I have acquired a Sony XBR-65X900H to try and fix. It probably was a complete no power situation. The main board was replaced and the TV started turning on. I now have start sounds and backlights, but no image. I've replaced the t-con with no improvement. Cables all appear to be ok and seated properly. The TV took a firmware update and hard reset but neither helped.
                                          Using the tape trick I can get both side to display combinations of colored vertical lines. There is no change in the stripes and the pattern always appears the same. If I add additional tape strips I can get the screen...
                                          09-18-2023, 09:05 PM
