Sony KDL-46W4100 vertical lines
    Re: Sony KDL-46W4100 vertical lines
    Eh... the motion processor's probably about $10... there's a lot you can get done with commodity high-performance DSPs these days. There's a little more expense in making the LCD panel 120Hz capable, but not much more. N.B. I have seen some recent Toshiba, Vizio and Samsung with motion interpolation on the main board, but it's most often on the T-con, and sometimes on a separate in-between board on the older models.
    600Hz plasma means 12 subfields at 50Hz, for 12-bit colour, the image is only 50Hz. Only a few plasmas have true frame creation, older Panasonic PZ82 and G10, but they dropped it later, because it really doesn't improve picture quality and is a sales gimmick.
    • cashkennedy
      • Aug 2011
      • 668
      Oh so I can finally not only laugh at all my friends who brag their plasma has 600hz, but also prove to them they are total retards?
      Though the fact that theres no pixel switch time(gtg refresh rate) on plasma tends to make the motion look smoother then when you have ghosting.
      Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
        Well, yeah, 600Hz plasma == 50Hz LCD if the LCD had zero blur. A real LCD has about 5ms ghosting. A real plasma has sub millisecond ghosting (0.1 msec to 0.5 msec.) Below 1 msec the eye cannot usually see the difference.
        Then again the plasma panel does flash the image 600 times a second. A 240Hz LCD is just a 120Hz LCD with backlight blinking, the image flashes 240 times a second but the frames only change 120 times a second. And it's the same business for a 480Hz LCD. No difference at all. So in that way 600Hz plasma is similar to 600Hz LCD, if one existed.
        Now Panasonic has some crazy 3000Hz subfield drive in their latest plasmas, I have NO idea how that works. I need to set up a highspeed camera in front of it. And I'm watching an older Panasonic PDP with a "mere" 480Hz panel. Oh no, I'm not sure how I'll live without another meaningless specification.
        • cashkennedy
          • Aug 2011
          • 668
          at 5ms an lcd panel could change the pixel 200 times per second. if it is 5ms it spends 1/4 of its time changing basically, and 3/4 displaying the correct color. Old lcds when they first came out were 25-8 depending on the colors and so on. for the last few years most panels have been in the 16-5 range depending on the color, which is good enough that you wont see ghosting on moving text / or pretty much anything other then maybe golf / hockey. so regardless of the 120hz / motion extrapolation , a modern basic 60hz will be "good enough" for pretty much everyone
            Exactly.
            The problem TV manufacturers have is they are getting so close to the ideal image that there won't be any way to improve it.
            Frankly, when (if) OLED comes out, I predict a stagnation of TV tech. Infinite contrast ratio. Zero response time. High energy efficiency. Excellent colour accuracy. 4K capable in small screen sizes. Zero 3D crosstalk. It'll just be like CRTs.
            I mean, how do you improve on that? The only way you can is to tack on silly gimmicks, and we're only seeing the start of it. The silly gimmicks make it harder to sell used TVs for me, I try to pick up 100Hz TVs as often as possible but they're fairly new when they die so I don't usually see them for good prices.
            70 years of OLED/other tech like FED/SED until holographic 3D?
            • tibimakai
              • Jan 2012
              • 3680
              So the TV didn't run much. When I came home it was blinking an error code #12.
              But at least while it ran it had a beautiful picture.
              This still proves, that the T-con is the faulty one?
                Well, it proves that the T-con and some other board is at fault. Haven't checked what #12 is but sounds like backlight error from memory.
                • tibimakai
                  • Jan 2012
                  • 3680
                  There is only one T-con board on the Ebay, do you think that the T-con is the issue with the original mainboard?
                    Yes.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I have received the "new" T-con board and the result it's not good.
                      To me it seems like the "new" boards is defective as well.
                      What do you think?
                      • Sevenqi
                        • Jul 2011
                        • 292
                        #31
                        Please try to disable the DRC: picture --Adjustment --DRC to 'off'.
                        if the vertical lines disappear, you have to do this to all inputs with each picture modes.
                          I'm going to agree with you Tibi if those noise patterns weren't there before. I have received dud T-con with similar fault though affecting only the green. What was that about "WORKING AND TESTED"?
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I showed both pictures to the Ebay seller and he is saying that I have a bad tab bonding issue.
                            It is possible?
                            He is saying, that he is sure that the board it's good.
                              No. Tab bonds would not cause that. You did not see the noise image on the original with the bars, right? Both boards are faulty in different ways, he did not test his. He is bullshitting you.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I'm not sure which one is that, but I have pictures in the first post.
                                  You are seeing two separate faults right?
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Post #1 is original T-con fault and post #30 is the Ebay T-con. Both show different problem.
                                      Yes.
                                      So basic troubleshooting 101.......
                                      You had symptom #1 with original part. You changed part. You know have symptom #2.
                                      • If you had the SAME symptom, you may presume the board was not the fault.
                                      • If the symptom disappeared, you would have fixed the TV, so that board was likely the cause.
                                      • If the symptom changed it's obvious you've had some effect, but the board isn't 100% functional. Now, if you did not notice this fault with the original board, you have now introduced a new fault with a new board.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        You are right.
                                        Some other TVs uses this board and I have read that these T-con boards fail a lot.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          I have sent back the board, but something doesn't seem right.
                                          These guys are a repair shop(there name indicates, that they are more a laptop repair shop then TV) and they have a 100% feedback with a 1093 score.
                                          http://myworld.ebay.com/i-trader05?_...p2047675.l2559
                                          Do you guys think, that I should take apart the panel and check it out, before I order another board?
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • gpo23
                                            Sony KDL-40V3000 - Vertical lines
                                            by gpo23
                                            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                            With the new t-con the color are good but there are vertical lines on all the screen :
                                            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                            Is there a way to fix the vertical lines on the new t-con ?
                                            Thank you for your help
                                            gpo23...
                                            10-04-2023, 09:11 AM
                                          • Stanley1843
                                            Screen Display Vertical Multicolor Lines
                                            by Stanley1843
                                            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                            06-29-2024, 11:54 AM
                                          • noisykid
                                            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                            by noisykid
                                            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                            12-30-2024, 07:15 PM
                                          • dustman1747
                                            Sony XBR-65X900H vertical lines
                                            by dustman1747
                                            I have acquired a Sony XBR-65X900H to try and fix. It probably was a complete no power situation. The main board was replaced and the TV started turning on. I now have start sounds and backlights, but no image. I've replaced the t-con with no improvement. Cables all appear to be ok and seated properly. The TV took a firmware update and hard reset but neither helped.
                                            Using the tape trick I can get both side to display combinations of colored vertical lines. There is no change in the stripes and the pattern always appears the same. If I add additional tape strips I can get the screen...
                                            09-18-2023, 09:05 PM
