Curtis LCDVD244A
+ More Options
Posts
  • landyboy
    • Apr 2013
    • 443
    Curtis LCDVD244A
    Got another freebie and I think i have diagnosed the basic problem. The power board appears to test good. Symptoms are Power light comes on red and will go green when unit powers up but there is no picture. After checking the back light inverter I found the feed is as follows:
    VCC 12.10
    VCC 12.10
    EA 4.767
    Adj 0
    Ground 0 ohms
    Ground 0 Ohms
    There is no voltage at the inverter plugs feeding the back lights. I checked F1 and it is 0 ohms.
    I think I have a bad inverter board thoughts?
  • landyboy
    • Apr 2013
    • 443
    Re: Curtis LCDVD244A
    Do these voltages look correct? What is the "ADJ" a reference to and does it look correct? Thanks
      ADJ (Adjust)= Backlights brightness control. 0V = Min brightness
      EA (Enable) = BL_ON = Backlights on control .
      • landyboy
        • Apr 2013
        • 443
        Would the 0v indicate a problem?
        • martyparish
          • Dec 2012
          • 313
          Is there a voltage at F1 when set is on?
          • landyboy
            • Apr 2013
            • 443
            yes 12.10vdc
            • landyboy
              • Apr 2013
              • 443
              I assume you mean the F1 on the inverter
                If you get 12v at both ends of the fuse, then try this, disconnect the ADJ line from the connector, then use 1K~2K resistor to feed 5V into the ADJ pin of the inverter board and see if you will get backlights.
                • landyboy
                  • Apr 2013
                  • 443
                  Ok tried that but no change. I do now notice when I power on it will flash white for a split second. Also if I shine a flashlight on the screen I see images and the menu when I press the menu button.
                  • Clydeuk
                    • Jan 2012
                    • 193
                    Try the resistor trick mentioned (remove the adj wire out of the connector first). If it doesn't fire up the backlights I'd say inverter has failed. Don't try to measure the outputs, they are high voltage high frequency (around 1KV ish, more to start the lamps).
                    • landyboy
                      • Apr 2013
                      • 443
                      Did that with no change. Leaning towards a bad inverter...
                      • Clydeuk
                        • Jan 2012
                        • 193
                        You can get a 4 lamp universal inverter cheap, I keep one for testing, most are virtually the same, even ones that are built in to the power supply can be isolated and one of the cheapo's fitted, the trickiest part is usually mounting the board inside somewhere.
                        • Clydeuk
                          • Jan 2012
                          • 193
                          I've also pulled a couple of simple single lamp inverters out of old scanners, not used them but could be useful to test individual lamps in an assembly. Does the backlights even light for a second before going off? That could suggest a bad CCFL tube or connection (I've had both on these cheap sets)
                          • landyboy
                            • Apr 2013
                            • 443
                            The back lights seem to flash for a split second. I
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              https://www.badcaps.net/forum/showth...er+testing+cfl
                              http://www.ebay.com/itm/1pc-4-Lamp-B...item2ec1122f4b
                              both of these help me a lot in this situation to fault find.
                              • Clydeuk
                                • Jan 2012
                                • 193
                                Common faults on these cheap sets, capacitor failure, transformer failure, bad tube (broken), arcing connection between tube and metal shield (probably poor heatshrinking). These are some I've had anyway. If you can get a tube (from old screen, monitor, laptop etc) you can use to test each output. The inverter will need all 4 connected to stay running so do one at a time. If it's a tube fault you will know pretty quickly as with the bad one substituted it will fire up and stay on, with your loose tube lit as well. Then you have the nice part of taking the lcd assembly apart and trying to source a tube cheap enough to make repair worthwhile.
                                • landyboy
                                  • Apr 2013
                                  • 443
                                  Ok I may order an inverter or just put this on on the back-burner for now.
                                  • Clydeuk
                                    • Jan 2012
                                    • 193
                                    That will be a quick fix if it has failed, you may have to rearrange the input connector to match, though I've been lucky and one I got had the same pinouts. It's probably your best way at the moment unless you can get a working tube to test each output, since any failure in a lamp or connection to it will shut the drive off, pretty quickly.
                                    • landyboy
                                      • Apr 2013
                                      • 443
                                      Ok got the cheap inverter and replaced it now set works fine. The pins on the generic board were exactly the same as the original board.
                                      • Chickadee
                                        • Nov 2013
                                        • 3
                                        • united states
                                        Hi Conduit just wanted to know where I can get a inverter board from
                                        I have the same model with the same problem.
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • sarry86
                                          Hp Elitebook 1030 G1 power issue
                                          by sarry86
                                          Hello, I have this Hp pavilion 1030 G1 that starts with a single light on caps lock then it turns off, measurements at the coils, meter in resistance mode (not continuity mode) are as follows: The problem started just after it fell from a desk to the ground. I can't find a boardview or a schematic diagram anywhere, please help me 🙏
                                          1. 13k ohms
                                          2. 0.00 ohms
                                          3. 6.7 ohms
                                          4. 8.9 ohms
                                          5. 18.2 ohms
                                          6. 83.5 ohms
                                          7. 99.4 ohms
                                          8. 10.7k ohms
                                          9. 68.5 ohms
                                          04-26-2024, 05:54 AM
                                        • eccerr0r
                                          A modified sine wave inverter + a grid tie inverter?
                                          by eccerr0r
                                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                          08-31-2023, 09:14 PM
                                        • JM1010
                                          MACBOOK: Basic safety question before injecting voltage
                                          by JM1010
                                          A1707 PPBUS has a partial short to ground @ 50 ohms.
                                          VCORE to ground is 4 ohms.
                                          Between PPBUS and VCORE I get 50 ohms as well.
                                          Is it safe to inject 1-2 volt into PPBUS?
                                          I remember piernov on Logiwiki stating that if PPBUS ohms to ground is LOWER than VCORE ohms to ground it is probably safe to inject small voltage into PPBUS. If it's the same resistance to ground it is not. But what about when PPBUS resistance to ground equals resistance between PPBUS and VCORE eg 50 ohms AND VCORE resistance to ground is lower eg 4 ohms? Is it safe to inject voltage into P...
                                          12-20-2021, 11:19 AM
