Samsung LN32B350F1 no video
  • XmouseX
    • Aug 2011
    • 158
    • US
    #61
    Re: Samsung LN32B350F1 no video
    Any update?
    • fvillaverde
      • Jan 2015
      • Panama
      #62
      I got a Samsung LN32B350F1 (Model LN32B350F1XZP) with no video, just flashing the screen for less than a second when turning it on. Somewhere else I have read it is a T-CON card trouble, but since there are some issues with outlet the TV was connected to (no ground, inverse wiring, surges), I think the trouble origin is somewhere else. The caps looks good, and surely it is not about burnt fuse because there is a screen flashing when TV is just turning on. Should I get a replacement for the T-CON card, or not? Any ideas?
      • selldoor
        Slow Learner
        • 7870
        #63
        Unlikely to be the Tcon - test and post the secondary winding resistances on the inverter transformers
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • ohren
          by ohren
          09-08-2023, 05:24 PM
        • C152Heavy
          by C152Heavy
          Summary for TL-DR readers:
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
        • alltvrepairs
          Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
          by alltvrepairs
          I have confirmed that I have a mainboard problem.
          I have tracked no hardware issued on board so might be a software dump required.
          I have searched a bit but wasn't able to find anything for my screen:
          Here are some more details:
          Panel: cy-nn065hgev1h
          Main: BN94-14180M P08F
          Your help much appreciated!
          05-16-2025, 03:03 AM
