Samsung LN32B350F1 no video
  • brianr20v
    • Apr 2013
    • 43
    • Trinidad
    #41
    Re: Samsung LN32B350F1 no video
    That could explain why it comes in some times and doesn't at times.
    • brianr20v
      • Apr 2013
      • 43
      • Trinidad
      #42
      Originally posted by budm
      The 312V is very marginal for the inverter circuit to work properly. Do you have capacitor meter to check the capacitance of that large cap since if the PFC not working, I expect the voltage on the cap to be at 230V (your country line voltage) x 1.414 = 325V but with very poor regulation due to failed PFC.
      don't have that a meter that could read that large of a cap at this time but will be getting one soon ordered an ESR meter.
      • brianr20v
        • Apr 2013
        • 43
        • Trinidad
        #43
        and my line voltage is 119vac.
          I know that I've had a similar problem before with failed PFC circuit causing intermittent operation. TV'd work in my room with 245VAC nominal, but it'd fail in a friend's house that was getting 235VAC.
            If your line voltage is at about 120V (I did not know that Trinidad uses 120V in staed of 230V), then the voltage on the cap when it is in standby mode should be about 160V. Something does not make sense here.
            • brianr20v
              • Apr 2013
              • 43
              • Trinidad
              #46
              yes we use both 120v and 230V but most aplinences run at 120v and yes the stanby voltage is around 160V
                That means the PFC must be running (since you are getting about 320V) which still does not make sense since the PFC IC is not getting enough b+ at the VCC pin to run either.
                • brianr20v
                  • Apr 2013
                  • 43
                  • Trinidad
                  #48
                  Well am just as confuse as u
                    There is a chance the PFC diode is bad, which will cause the output to sit at the input voltage. Have you checked all diodes on the HOT/Primary side for shorts?
                    • brianr20v
                      • Apr 2013
                      • 43
                      • Trinidad
                      #50
                      yes i did but all was good
                        Your TV inverter board has about the same design as the one I fixed the bad T-CON board. You can see that the voltage on the cap is about 380V.
                        http://s807.photobucket.com/user/bud...01561477778744
                        • brianr20v
                          • Apr 2013
                          • 43
                          • Trinidad
                          #52
                          Let me ask u something DP805 what is the replacement for that diode because i was getting .43 on the meter can i replace it with one with the same value as DP810 and DP804 which is IN5408?
                            Check the DP805 out off the board using Ohm mode to see if it shows resistance reading in both direction.
                            • brianr20v
                              • Apr 2013
                              • 43
                              • Trinidad
                              #54
                              no its not i pulled all the diodes on the board and and tested all reads fine
                                OK, I searched my archives, this is what I found.
                                • brianr20v
                                  • Apr 2013
                                  • 43
                                  • Trinidad
                                  #56
                                  31GF6 is the same number i have on my diode which reads .43 on the meter what u think replace it ?
                                    The 450V cap could be bad, too.
                                    • brianr20v
                                      • Apr 2013
                                      • 43
                                      • Trinidad
                                      #58
                                      Got a capacitance meter to read the big cap so will do that this afternoon and keep u all posted.
                                      • brianr20v
                                        • Apr 2013
                                        • 43
                                        • Trinidad
                                        #59
                                        ok so the big cap CP815 reads good
                                        • brianr20v
                                          • Apr 2013
                                          • 43
                                          • Trinidad
                                          #60
                                          Ok update i ordered the replacenment BOOSt Diode (31GF6) hope fully i should get it by the 15th of this month will keep u all posted.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • ohren
                                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                            by ohren
                                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                            The models launched in 2018 and 2019 respectively....
                                            09-08-2023, 05:24 PM
                                          • C152Heavy
                                            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                            • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                            • Have read ALL applicable threads
                                            • C1818 and CP820 replaced as low hanging fruit
                                            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                          • alltvrepairs
                                            Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
                                            by alltvrepairs
                                            I have confirmed that I have a mainboard problem.
                                            I have tracked no hardware issued on board so might be a software dump required.
                                            I have searched a bit but wasn't able to find anything for my screen:
                                            Here are some more details:
                                            Panel: cy-nn065hgev1h
                                            Main: BN94-14180M P08F
                                            Your help much appreciated!
                                            05-16-2025, 03:03 AM
