Before I toss these on the basis of bad panels...
  • craigc15
    • 53
    I thought I'd post some pix here to get some feedback.
    The Toshiba 52" seems to be a common problem. I replaced the t-con w/no success.
    I replaced the main/t-con board on the Samsung 32" with no success.
    I also replaced the main and t-con boards on the RCA with no success. The distorted video moves with the "No Signal" box.
    I haven't replaced anything on the Samsung Monitor yet.
    Has anyone had success repairing display driver boards?
    Thank you!
    Craig
    Re: Before I toss these on the basis of bad panels...
    Panel, Panel, Panel/Main, Panel/Main/PSU (bad caps if SyncMaster T24x series)
    You cannot replace the driver boards and besides there's little to no point. They only serve to connect the T-con to the tab bonds. Just like a connection block.
    • craigc15
      • 53
      The monitor is a SyncMaster T240HD.
      What capacitor(s) are problematic?
      Thanks!
        All of them. Crappy Samwha or Capxon usually bulge.
        • craigc15
          • 53
          On the PS, or main board, or both?
          Thanks!
          • bmadbob
            • Nov 2011
            • 18
            Craig, I have been playing with some of these Toshiba's. What I have been finding is the tab to screen bonding is not making a good connection sometimes. I have taken like a wide paint scraper, set it on the tab and put it up against the LCD screen so it doesn't get to hot, take hot air solder gun and run it over a few times, hold down on the scraper while it cools. Sometimes it's the small IC in the middle of the tab that has to be resolder. I had some that stayed working and some lasted a couple of months. Just a thought if you wanted to try something.
            • craigc15
              • 53
              Thanks for the reply.
              I noticed on the ribbon cable going to the portion of the screen that is not working has a "damaged" trace. I considered attempting to repair it with a piece of wire, but my experience is that those ribbon cables can not handle being soldered.
              • craigc15
                • 53
                I checked the PS and Main boards for Samwha or Capxon caps and there aren't any.
                The PS has Sam Young caps, none are bulging. The PS voltages are good and there is no unusual AC ripple on any of them.
                The main board has all SMD caps with no manufacturer printed on them. None of them are bulging either. I checked the ESR on all and they seem fine.
                Anything else, or is it a bad panel?
                I'll check the continuity of the LVDS cable tomorrow.
                It would be a real shame to have to toss this monitor. It is in like new condition.
                • cashkennedy
                  • Aug 2011
                  • 668
                  One lady drove a broken t240hd to me at her cost and gave it to me for free after I responded to her craigslist listing for it / apparently she wanted it gone now!. I took it apart and the LVDS was loose that was all > best monitor ive ever spend 0 money for. For me though the upper 2/3 of the screen would go black and the lower 1/3 would freeze... but either way shows the lvds cable is a pretty weak point on these / probably related to the fact that Samsung uses no screws in these / everything taped / notched together...
                  Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                  • bmadbob
                    • Nov 2011
                    • 18
                    Craig, I guess I shouldn't use the term re-solder. All I did was heat them up again so they would reseat themselves, like a bad solder joint. Sorry not the greatest at explaining things.
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • eccerr0r
                      Sell or Shim Solar panels?
                      by eccerr0r
                      Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                      However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                      So now what to do with these small panels?
                      I could sell them...
                      Or I could shim them....
                      03-29-2025, 01:07 AM
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
                    • netgearnetgear
                      TCL 43S423 TCON OR PANEL FAULTY???
                      by netgearnetgear
                      Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                      08-20-2025, 06:04 PM
