Need some help with an Insignia LCD
    Hi, I was given a broken Insignia ns-l32q-10a, hoping it would be an easy fix.
    The problem is quite erratic, but the main issue it the TV messes up after about 45 minutes to 2 hours. Sometimes it will do one of the following:
    -Power indicator turns off (no led on at all) or red, no sound, but screen is still on playing video, and it won't respond to any button presses.
    -Power indicator turns red, no sound, screen randomly turns on and off with scrambled video, again will not respond to button presses.
    -Power indicator stays blue, but the tv says no signal, and I have to switch the input source back and forth to get it to see the signal again.
    I have thoroughly inspected both the mainboard and the power supply, and there are no caps that look dead visually. I replaced all but one of the caps on the cold side of the power supply, to no avail. (all but one because radioshack(ugh) didn't have the last one.)
    Any idea what could be the issue, and if it is even fixable?
    I can get some pictures if needed.
    Re: Need some help with an Insignia LCD
    The caps you buy at radio shack are no good in this application. You need 105C low ESR caps such as the panasonic FC and FM series
      I'm starting to wonder if the issue isn't heat related. On a hunch I left the back cover off the tv and set up a fan pointed to blow across the back of the tv and it's been working for about 4 hours without issue. Oddly enough it looks like the cpu on the main board has a heat sink on it, but the chip and heat sink are enclosed in a metal box.
        I would get a can of frez and when it goes off spray the chip and see if it comes back up if so i would replace it. If not try spraying other things. To see if it comes back up if so replace that part.
          It looks like the heatsink is slipping off the CPU chip, it is on crooked. The thermal interface pad may be not holding the heatsink in place very well.
            The heatsink is actually still firmly attached, just mounted slightly crooked. Though it looks like it is off and resting on the metal cage in the pic. I ended up mounting an 80mm case fan on the back casing right above the heatsink, tapping power off one of the 12vdc lines coming off the power supply. I then used an adjustable voltage regulator set to roughly 8vdc to lower the fan speed to a level where it didn't make any noise.
              Nice fix, but if the processor is failing (e.g. solder balls - BGA failure), this is probably not going to last any more than a few months.
                Eh, it was almost free (wasted money on non-needed caps), so better than nothing. Plus there's always the good old heatgun reflow .
