Samsung model # PN43D450A2D Black Screen Red Light
  • ttt9090
    • Apr 2013
    • 16
    • canada
    I'm attempting to diagnose a 42" Samsung Plasma model # PN43D450A2D with black screen red blinking light.
    When I plug it in, it exhibits the typical relay clicking a few times and nothing on screen, nor any sound.
    Visual inspection shows no signs of bad caps leaks or bulging or any other visual overheat issues.
    If I dis-connect either the x or y board it makes the "samsung" sound and responds to remote turn on / off, but still nothing on screen.
    I checked the single ceramic fuse for ohms with power off and it seems fine.
    I pulled the y board to inspect the back for visual issues and see none.
    I'm fairly new to this tv stuff, so was hoping for someone with the time, to walk me through this in terms of where should i begin to test for voltages etc.
    I can provide pictures along the way if needed and have a couple of basic digital multimeters and a general knowledge of how to use them.
    Thanks for looking and hope to hear from someone soon.
    Cheers,
    TTT
    Re: Samsung model # PN43D450A2D Black Screen Red Light
    You have an X-main failure, very common on this model. Remove the board, check the LJ92-xxxxxx part code, and find one on ShopJimmy/eBay etc.
    • ttt9090
      • Apr 2013
      • 16
      • canada
      Wow that was quick Tom66, thanks.
      Forgot to mention before, that I also followed one of your guides on jumpering the controller board for test patterns and had no luck.
      I pulled & checked the x-main the number on it is LJ41-09478A LJ92-01796A R1.6.
      Found one on ebay for $30 that's the same except LJ41-09478A LJ92-01796A R1.8. I assume that is a revision number of one with better components?
      P.S.
      Just because I'm interested... Can you point me at any values for this boards components that I could reference to do some tests with my MM so I can see what went wrong? I know it's probably not worth the effort to someone being paid for their time, but I have lots to waste and am fascinated with all this stuff and figuring out why it does or doesn't do what it's supposed to.
      Thank you so much for the excellent resources and videos you have provided. I've mostly been into pc repair for a long time and have re-capped a few motherboards over the years and tried my hand and re-flowing some gpu's etc., but this tv stuff, is new ground for me.
      Love the forums and I'll be sure to watch out for anyone with issues I may be able to help with.
      • ttt9090
        • Apr 2013
        • 16
        • canada
        Oops...
        In my original post, I mentioned that "If I dis-connect either the x or y board it makes the "samsung" sound and responds to remote turn on / off, but still nothing on screen."
        I just went through it all again to double check and I realized I was mistaken.
        In fact, it does not make the sound when the Y-main is plugged in, only if the Y-main, or both are dis-connected.
        I don't know if this makes any difference to the diagnosis and I apologize for my error.
        • capkid
          • Oct 2010
          • 1339
          Originally posted by ttt9090
          Oops...
          I'm not sure if this is a surefire way to find the fault, but it seems consistent in the five Samsung-based thin-profile TVs I've worked. Like I mentioned in another thread, I wouldn't tinker too much with this TV, as you could end up damaging other components during testing:
          I'd test the Y-main's and X-main's through-hole transistors on the heat sink and the fuses with a multimeter. Usually when one of the "mains" is damaged, one or more of the through-hole transistors on the heat sink is bad. Remove the boards from the TV to perform the tests:
          - If any of the Y-main's through-hole transistors on the heat sink or the fuse are bad, replace the Y-main and Y-buffer AS A SET.
          - If any of the X-main's transistors on the heat sink or the fuse are bad, replace the X-main. Some of these thin-profile TVs also have an X-buffer; if the X-main is bad in this case, replace the X-main and X-buffer AS A SET.
          When your replacement board arrives, repeat the transistor and fuse test on the replacement "main" board, connect EVERYTHING up in the TV AT ONCE, then power it on.
          LG Plasma Mal-Discharge Correction Service
          • ttt9090
            • Apr 2013
            • 16
            • canada
            Thanks Capkid,
            I'll see what happens.
              If you find that disconnecting the Y-main works only, then the Y-main AND/OR the X-main are bad, due to the power chaining scheme.
              There are very few through hole devices on these boards. It's mostly done SMD. The only through hole devices are the energy recovery (ERC) fet and diode. However the testing method is the same.
              If the Y-main is replaced, the Y-buffer should also be replaced on these models.
              • ttt9090
                • Apr 2013
                • 16
                • canada
                Thanks Tom66,
                I have advised my friend (tv owner), that I'm a bit leary of spending his money to buy parts unless I can be 99% certain that I have found the culprit component.
                Will keep you all updated though when we decide on course of action so as to help others.
                • capkid
                  • Oct 2010
                  • 1339
                  In your experience, have you found that one or more of the through-hole components on the heat sink is shorted when the Y-main or X-main fails in these thin Samsung TVs?
                    Usually just the SMD fets. However, I have only done one of the D-series plasmas which use almost entirely SMD fets.
                    • ttt9090
                      • Apr 2013
                      • 16
                      • canada
                      Hi again,
                      My friend put the new y board in and it has stopped clicking, it only clicks a couple of times when he first plugs it in and pauses and clicks a couple more times then stops, red standby lights stay on and no clicks after that.
                      Where to look next?
                      Thanks for the help
                      • dh3292
                        • Jan 2014
                        I have the same fault as the original thread question but my standby light remains red when relay clicking. I removed the back tested fuse and measured 220v @ fuse. I also have a green led flashing on the small board at the bottom.
                        Help much appreciated
                        • lcdman
                          TinkerTech
                          • Nov 2010
                          • 232
                          • U.S.A.
                          Hello All
                          I have this same model tv. I was removing one of the four fets that are part of this tv's x main board common failure. In the process I had a resistor pop off the board. Its board location is r4022. Its so small that I can't locate it. Perhaps someone here knows the value of the this missing resistor?
                          Thanks In Advance,
                          lcdman
                          • R_J
                            • 9624
                            It should be the same as the one next to it, (150) 15 ohm. You need to do a better job removing those transistors, you ripped the traces under them. that can effect their heat transfer during operation. Try adding flux and more heat next time
                            • lcdman
                              TinkerTech
                              • Nov 2010
                              • 232
                              • U.S.A.
                              Hello RJ
                              I wondered if it had the same value as the one next to it. (150) 15 ohm. What
                              rating/tolerance would you guess it is? Size type? 1206 as an example. This was my first repair attempt using a hot air gun. I will take your advice though for next time.
                              Thanks,
                              lcdman
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                The way to remove the surface mount fets is:
                                1. Add fresh leaded solder to both legs. If you have a thin tip, go behind the legs and heat the pad and pry up. You can use a pick also, just make sure solder is molten.
                                2. Then add some solder to the main pad and heat the crap out of it. Dont use a heat gun, you will only f#%@ things up. It will lift right off when hot enough.
                                3. To replace the fets, put some fresh solder on the main pad, and when molten, place new fet in place, using tweezers. Flow some solder over the tab, then solder down the legs. This way you shouldnt rip off traces.
                                • lcdman
                                  TinkerTech
                                  • Nov 2010
                                  • 232
                                  • U.S.A.
                                  Hello Again,
                                  (150) 15 ohm. What rating/tolerance would you guess it is? Size type? 1206 as an example. I just want to be sure before trying to source a replacement resistor.
                                  Take Care,
                                  lcdman
                                  • R_J
                                    • 9624
                                    You would have to measure the size, I can't, I'm sure 1/4 watt or 1/2 watt would be fine
                                      It's 1206, I've repaired a few of these now
                                      If the resistor popped off the board it might be bad, so check its cousin is not open circuit
                                      If that's open circuit you'll almost certainly have to replace the driver IC for them. In fact I'd generally recommend it anyway unless you can be sure its OK as it might just pop the new IGBTs again.
                                      • KYBOSH
                                        Trying To Fix: Samsung UN50TU7000 - Weird Fading Screen then Red blinking light
                                        by KYBOSH
                                        Picked this up to resurrect.
                                        When I plugged it in it comes on for about 1 minute... after a minute the screen blacks out and I gets blinking red lights on the power button.
                                        I read that a common issue with this model is a failed BGA so I ordered a replacement on eBay.
                                        Sometimes the TV would produce an expanding blob on the screen before going black.
                                        See Video here
                                        I ordered a replacement board off of eBay and installed it tonight and got the same behavior.
                                        Did I get another defective board or is there an issue with...
                                        09-16-2024, 07:48 PM
                                      • JunkmanJimbo
                                        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                        by JunkmanJimbo
                                        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                        No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                        Please help. Thanks in advance!
                                        08-12-2025, 11:45 AM
                                      • Kiberge
                                        Samsung LH82QENELGC/EN Help needed - Static line on screen
                                        by Kiberge
                                        HI guys!
                                        I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                        I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                        the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                        This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                        04-22-2024, 11:28 AM
                                      • Ryan.man
                                        by Ryan.man
                                        02-04-2025, 12:23 PM
                                      • Samunggg
                                        Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
                                        by Samunggg
                                        I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
                                        I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
                                        09-06-2023, 06:39 PM
