VIZIO VT420M morning..what would cause this? see pic thanks
  • davewilson61
    • 110
    • usa
    stuck on logo screen
    cant find firmware update for usb...may not be one?
    any other thoughts....
    tv will turn off and on with the remote
    thanks dave
  • selldoor
    Slow Learner
    • 7870
    Re: VIZIO VT420M morning..what would cause this? see pic thanks
    tried it with different sources -
    tried the button board
    no other buttons work
    sound?
    please tell us all the tests you have done
    cant waste time dragging it out of you
    • tw2005
      • Oct 2011
      • 6458
      I'd be thinking corrupted firmware at a guess. Will it go into service menu?
        Needs EEPROM/flash probably
        • davewilson61
          • 110
          • usa
          just power button on side works cant get into service mode...unless im doing the wrong sevice mode....can i ground out the eprom?....how would i do a flash?...nothing plugged into tv just stuck on screen
          thanks
            Nope, you will need to replace the EEPROM, many sellers have them $15~$25 each. (Rip off price, but nothing you can do about it... yet.)
            • davewilson61
              • 110
              • usa
              then i have to get one programed...and install on the main board..
              • davewilson61
                • 110
                • usa
                i had a eeprom programer many years ago when i did pinball repair..copied chips..but must have a good one...so can i buy a pre programed eeprom for this model?..where would i get it?
                  shopjimmy.com is selling eeprom now, try contacting them.
                  • SS454
                    vizio e650i-a2 backlight flashes then turns off
                    by SS454
                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                    panel: au optronics T650HVN05.4
                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                    08-20-2020, 03:57 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
                  • howardc64
                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                    by howardc64
                    Failure Symptom
                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                    Where is the short?
                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                    05-27-2025, 02:56 PM
                  • howardc64
                    Vizio SmartCast TV software bug that looks like hardware
                    by howardc64
                    Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                    It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                    11-16-2024, 05:17 PM
