Sony CECH-ZED1U Playstation 3D LED TV - Two Red Flash
  • R_J
    • 9549
    Re: Sony CECH-ZED1U Playstation 3D LED TV - Two Red Flash
    ok it looks like the software is different for each programer, is there a way to select the chip in the tiny software rather then have it detect it?
    Maybe that programer/software does'nt support the MX25L6406EM2I ic.
    its not listed in there supported ic list
    MXIC:
    MX25L512,MX25L1005,MX25L2005,MX25L4005,MX25L8005,MX25L1605,MX25L3205,MX25L6405
    • Mordi
      • Jul 2014
      • 3
      • France
      #302
      i found why software doesn't detects chips: the contacts between chip and the adapter are bad, i have to push on the chip while programming it.So detection ok and programming ok.
      My screen works and i have put a soic8 socket 200mil on motherboard for easy replacing chip,and have 5 chip ready for next "red light blink bug".
      Thank you to this forum and everybody for this thread.
      • Lobotomy
        • 3
        Hello, this is my first post here and I have a few questions.
        1. How compatible are SOIC8 and SOP8? Because the guy above me here appears to put a SOIC8 socket on his motherboard for a... SOP8 chip? Does this mean they are the same standard?
        2. If so, where would I find such a socket for my motherboard? Every time I look for a socket for this thing I end up seeing a bunch of programmer modules that convert SOP8 to DIP8 and whatnot. I don't want that. Am I not looking in the right places?
        • Zerounderone
          Hi Fellas,
          Any idea where I would rewire pin 6 (SCLK) if I picked up the trace :/ ?
          Cheers
          • Zerounderone
            Originally posted by Zerounderone
            Hi Fellas,
            Cheers
            Couldn't edit so I figured I'd quote.
            I ended up soldering pin 6 to the pin 6 trace of the nearby U0401 area. Powers on, shows picture and saves settings!
            Thank you guys!
            • badwhip
              • Jan 2015
              • usa
              #306
              I have a few problems with the monitor I just bought. the screen looks like it's in 3d all the time with a double image but the glasses don't fix the image it's like the screen resolution on a pc when it's not at correct setting. I also noticed that the 3d button doesn't fix it. I have it set on auto 3d detection. finally there is a vertical green line at the very right of the screen that does not go away. any ideas?
              • Dominikin
                • Jan 2015
                • 5
                • usa
                #307
                hello fellas, I'm new here. I've joined the forum to try and find a fix for this display. I'm having the same problem you guys are having. I called SONY and they said they would charge me $70 to fix it. After reading through everything and watching a video on youtube, I decided to give it a go myself without sending it to them. I'm a total noob at soldering and fixing boards so I left it to my uncle who has somewhat experience on boards. I went ahead and bought the pre-programmed eeprom from shop jimmy and gave my uncle the instructions on how to do it. Problem we're having is that I believe he lifted the traces and removed the pads when he took off the old eeprom. Is there a chance I could still recover this project or should I call it quits? I don't see any main board on sale anywhere, just the power boards on ebay. Could I just solder the old eeprom back in and send it to SONY? I read somewhere that they just switch the whole board out when you send it in for repair. Any help would be appreciated. Thanks
                • as1
                  • Apr 2014
                  • 25
                  • Argentina
                  #308
                  Hi Dominikin, follow the paths to some other component in the path and sold a thin cable to it, sold the other end to the eeprom leg. Do it for each leg. Regards
                  • Dominikin
                    • Jan 2015
                    • 5
                    • usa
                    #309
                    hola, estaba siguiendo tu video en youtube. Desafortunadamente, se levantaron los pads cuando removimos el eeprom chip. Soy un novato en esto, podrias subir una foto señalando el componente de cual hablas? Me harias un gran favor. gracias
                    • as1
                      • Apr 2014
                      • 25
                      • Argentina
                      #310
                      Hola Dominikin, por favor subí una foto en alta calidad de como quedo así trato de indicarte como soldarlo. Saludos
                      • Dominikin
                        • Jan 2015
                        • 5
                        • usa
                        #311
                        http://postimg.org/image/ffp3t1ydl
                        @as1, es la mejor foto que pude tomar.
                        • Dominikin
                          • Jan 2015
                          • 5
                          • usa
                          #312
                          http://postimg.org/image/fy2ftoa75/
                          • bobby8850
                            • Jul 2014
                            • Hong Kong
                            #313
                            Have repair my TV by replacing the eeprom few months back. but this week the TV seen to have the same problem again, but this time even i replace another eeprom still showing 2 blink of red light. Anyone here have the same problem?
                            Regards,
                            • as1
                              • Apr 2014
                              • 25
                              • Argentina
                              #314
                              Hola, acá te deja la imagen con las indicaciones, fijate que hay una pata que no se conecta. Lo que te recomiendo es que uses alguna plaquita como la de los adaptadores de SOP8 a DIP para hacer las conexiones. Saludos
                              • Dominikin
                                • Jan 2015
                                • 5
                                • usa
                                #315
                                muchas gracias @as1. Lo intentare. Cual es el proposito del adaptador? Tengo que soldar el eeprom a el adaptador y adaptar las patitas del adaptador a donde me indicas?
                                • as1
                                  • Apr 2014
                                  • 25
                                  • Argentina
                                  #316
                                  Hola, claro, soldas la eeprom en el adaptador, y luego usas cables bien finos para unir los puntos que te indique en la imagen mas fácilmente. Avisame por favor después como te fue. Saludos
                                  • deegii11
                                    • Feb 2014
                                    • 4
                                    • Mongolia
                                    #317
                                    This post now has 16 pages, so for the sake of our laziness, could someone please write a wrap-up repair guide step up here? In English of course. I would smuggle & send pretty woman to a guy who will do this.
                                    • Lobotomy
                                      • 3
                                      Alright, I'm having a real fuckin hard time finding a MX25L6408E SOP8. There are a bunch of fake sellers on ebay right now selling the SOP16 chips as SOP8, and the one chinese source wants $100 for shipping. Can I use the MX25L6406E?
                                      • R_J
                                        • 9549
                                        use a MX25L6406E which is an 8 pin ic, the mx25l6408e is a 16 pin ic, order it from Digikey
                                        • as1
                                          • Apr 2014
                                          • 25
                                          • Argentina
                                          #320
                                          http://www.ebay.com/itm/10pcs-MXIC-M...52459571&rt=nc
                                          • Ihandyrepair
                                            4 red flash led 65X950G boot Sony and android logo but then black
                                            by Ihandyrepair
                                            HI guys
                                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                            here is the issue
                                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                            but then I get black screen and 4 red flash light at the front LED
                                            but I get 3 led flash on the LED driver board.
                                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                            so I tried...
                                            07-11-2024, 01:45 AM
                                          • ekozeko333
                                            [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                            by ekozeko333
                                            I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                            🔥 The Problem Started After Suspected ESD/PD Fault
                                            I experienced a power issue or ESD event through a USB-C charger
                                            After that, the NX20P5090 power switch was visibly burned and was replaced
                                            Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                            🧠 What I’ve Done So Far
                                            Flashed...
                                            06-21-2025, 02:48 AM
                                          • corrize
                                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                                            by corrize
                                            Hello, I'm stuck in troubleshooting…
                                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                            10-01-2022, 10:02 AM
                                          • protonusr22
                                            Sony 49XH9505 four flash of death
                                            by protonusr22
                                            I own a Sony 49XH9505 123.2cm Smart Android 4k quite new bough brand new in 2021. Just after the warranty has expired it had died on me.
                                            The symptoms are the following: right after turning on backlight turns on and this loading screen appears, than the display turns off and the red led flashes four times.
                                            Any idea how to fix it or if it at least fixable? Does this sign related maybe some SoC/DSP and its circuits or just some simple power supply issues somewhere ?
                                            Many thanks in advance,
                                            02-07-2024, 08:10 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
