Vizio vw37l Amber light only will not power on
  • swwww
    • Feb 2013
    • 17
    • usa
    Hi all.
    I am trying to diagnose my visio vw37l
    I have only orange light
    5vdc standby voltage present on output of power supply but no "ps on" signal present at power supply when power button pushed.
    I was reading another thread and they suggested unplugging the inverters (the other two output plugs of power supply i'm assuming) with no change.
    anyone have any ideas on what to test to isolate (seems like main pcb maybe?)
    Two fuses i could find on main pcb by the input cable test fine
    I also have my 5vdc control voltage at switch/button board
    thanks
    scott
    Update--- I unhooked all connectors on power supply and hooked 3vdcto "ps on" input pin, the power supply voltages 12vdc and 24vdc are present on output pins of the 3 p/s connectors. so p/s appears to work when it gets the "on" signal..
    any ideas why the "p/s on" is not coming from main pcb?
    Added pics--- Thanks for the reply
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Vizio vw37l Amber light only will not power on
    Post a picture of the set layout of the boards internal. Then post pics of the boards close up, starting with the power board.
      I would check all the voltage regulators on the main board, please see the link below my signature on how to check the regulators.
      • swwww
        • Feb 2013
        • 17
        • usa
        Tested all the v-regs I could find... Aside from u-3 2nd of the largest two risiding on the right side not having any input power ( i am guessing this part of the board is not active in standby) all looks good except u7 which is in the middle upper center just below connector has input but no output. Doe this mean its bad? I was getting readings i that trust/understand trying to test the resistor and cap in the area.. (Differed from other readings (ohms) i tried to sample from caps in circuit next to similar vregs in area )
        Admittedly I am traveling a smidge beyond my experience level so my apologies if i am saying incorrect methods
        thanks for any help
          Can you report all the readings in the format as shown by retiredcap: https://www.badcaps.net/forum/showth...999#post300999
          U33 is usually bad, same for U7.
          • swwww
            • Feb 2013
            • 17
            • usa
            u7
            amc1117
            pin1 -0v
            pin2 -.5v
            pin3 -3.36v
            u33 and all other amc1117's i could find were all the same readings
            amc1117
            pin1 -2.1v
            pin2 -3.36v
            pin3 -5.15v
            u10
            1084
            pin1-1.41v
            pin2-2.66v
            pin3-5.15v
            u3
            az7805t
            pin1-0v
            pin2-ov
            pin3-85mv
            thanks again
            scott
            • retiredcaps
              • Apr 2010
              • 9271
              Originally posted by swwww
              u7
              amc1117
              pin1 -0v
              pin2 -.5v
              pin3 -3.36v
              u3
              7585t
              pin1-0v
              pin2-ov
              pin3-85mv
              U7 pin 2 should be 1.25V DC. Double check your readings.
              Check your part number U3.
              --- begin sig file ---
              --- end sig file ---
              • swwww
                • Feb 2013
                • 17
                • usa
                u7 readings are as reported...
                Correction on u3
                az7805t
                I'm not sure why your are saying it should be 1.25v at pin 2 All the rest of the 1117's are as reported pin 2- 3.36v when tested in the same way, same fixed regulator ( I am grounding meter to chassis ground) When grounding to the regulator ground leg The other 1117's give the 1.25 you are referring to (which is 2.1v different) with the exception of u7 which is as reported(w/meter ground on chassis).. there must be a 2.10v ground difference from chassis ground an the 1117's ground legs.
                Could a u7 failure cause this ground potential difference or are the(1117's) supposed to run w/ ground leg 2.1v off chassis ground? (i am assuming what I am calling pin 1 is the ground leg)
                strange how u7 pin 3 is 2.1v lower than the rest of the 117's pin 3s.
                thanks for all your help
                thanks
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Have another read through the how to test a voltage regulator guide (especially post#1 and post#4).
                  • swwww
                    • Feb 2013
                    • 17
                    • usa
                    I reviewed it
                    did you read all my previous post....
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      looks like U7 has a 3.3V input where the others have a 5V input. Pin 2 of U7 should read right around 1.25V.
                        Yes, output voltage (pin #2) = pin #1 voltage + 1.25V, as long as regulator has more than ~0.8V between desired output and input.
                        • swwww
                          • Feb 2013
                          • 17
                          • usa
                          Is it just coincidence that the input of u7 is 2.1 v lower than it should be ( which is the same voltage that the other similar 1117s ground legs are reading--2.1v....
                          And why would it be low.. Is that a u7 failure or a indication of associated circuitry failure.
                          Could u7 be shorting 2.1v of its input to ground causing the 2.1v on the other 1117's gound leg?
                          Or as asked in a previous post, is the ground leg supposed to be off zero on these 1117s...
                          thanks
                            Yes. The regulator can be configured to output any voltage and this is determined by the voltage on that pin. All the main regulators put out 3.3V (2.1V + 1.25V), but there's also a 1.25V regulator (U7: 0V + 1.25V), and the failure is with that.
                            Nobody knows why Vizio have this problem so often, perhaps an instance of "sort by lowest price" on the manufacturer's catalogue, or by accidentally (or deliberately..) buying counterfeit parts. Also, they often run very hot due to being used near their maximum power rating. I have also encountered failed regulators on Samsung and Haier/Bush TVs.
                            No, each regulator is independent.
                            It can be any voltage you like. A 1117 can output anywhere from 1.25V to around 18V, depending on the requirements of the circuit different voltages are used.
                            Replacing U7 should be all that is necessary.
                              U7 gets the input voltage from the output of U33. U7 is bad.
                              As shown in post 6, U33 output is 3.36v, THE INPUT OF THE u7 IS 3.36V. If you check out the connection between the output of U33, it will be connected to U7 input pin. Pin 1 (ADJ/ or GND (for fixed regulator) and pin 2 (output pin) will ALWAYS BE 1.25V due to the 1.25V Vref of the regulator.
                              Pin 1 will be grounded for 1117 Fixed regulator, or will have voltage on pin 1 due to resistor network for setting the output voltage for the Adjustable 1117 series.
                              • swwww
                                • Feb 2013
                                • 17
                                • usa
                                Thank you much for all the info . I really appreciate you taking the time to help clear that up
                                Do you think that my assumption of why u-3(the 2nd of the largest two regulators, residing on the upper right corner of board)does not have power input is a correct one?
                                (see my first post) ( i am thinking this part of the board is not active while in standby or is it due to the failure upstream?)
                                thanks much
                                  Yes, that regulator is correctly functioning (as it receives essentially no input, it gives no output.)
                                  • swwww
                                    • Feb 2013
                                    • 17
                                    • usa
                                    Ill give u7 a try and see what develops.
                                    not sure i get what you mean
                                    (as it receives essentially no input, it gives no output.) (u3)
                                    so are you are saying no input should not be expected for the conditions ( because of tv not being on) or are you just stating the obvious (no input no output)
                                    Also...
                                    I do not have an air tool... Are the methods I have read regarding hot iron techniques (heating the tab/globing the legs, ect.) viable methods or does anyone have any good methods/links?
                                    thanks
                                      The best way to get it off is not using hot air. Glob solder across the three main pins, then heat up the tab and those pins alternately. You'll shortly be able to push it off. This video describes it well.
                                      https://www.youtube.com/watch?v=cNFzBJELFoU&t=8m40s
                                        I use the same method as Tom, your iron should be 40watts or more with big tip.
                                        • huzo
                                          HP 470 G5 blinking amber light no power
                                          by huzo
                                          The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                          So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                          I've tried flashing the bios...
                                          interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                          06-08-2023, 04:08 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • x_orange90_x
                                          Vizio E550i-A0 no power, no standby light
                                          by x_orange90_x
                                          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                          11-20-2023, 09:49 AM
                                        • What?
                                          Vizio SV422XVT blinking amber/white power light
                                          by What?
                                          Good day, hope all are healthy and cozy. I could use some help with my malfunctioning Vizio with a blinking power light. I have narrowed the problem to the main board but not sure what to do next. I guess it would be good to start with what I have done.
                                          Problem:
                                          I have no image, no sound, blinking power light. (left it plugged in overnight and it was still blinking the following morning). I tried the Vizio recommendations (hold power button for 30 seconds, press reset button, check the outlet is live)
                                          Power Board:
                                          I am getting 5v only. I have unplugged...
                                          04-27-2020, 06:21 PM
                                        • zwect
                                          Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                                          by zwect
                                          I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                                          Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                                          Here is the original BIOS dump from the 25R256JVEN chip.
                                          09-11-2024, 05:54 PM
