Sharp LC32D44E-BK Stuck in standby mode
  • ron77
    • Dec 2012
    • 63
    • united kingdom
    #81
    Re: Sharp LC32D44E-BK Stuck in standby mode
    Yes Tom, but he did mention that he keeps tv running by shorting c7558, indicating a fault condition. The most difficult of the 3 sets I repaired starts off white, now. Shorting c7558 was a good tip, didn't use it because when backlights went off, knew I still had a fault. Still own two of those tv's, one in a spare room, one we use as a loan. My main point was similar fault, think backlight problem in panel. Ron.
    • lalunatech
      • Sep 2010
      #82
      Originally posted by ron77
      ...All 3 turned out to be faulty panel only. One of them came on exactly as yours, pink to start, then white. Had spare psu and main boards, didn't need them.Also had spare tv I bought for 50 pounds. That came in usefull, had cracked screen, hence the price. Before you start spending money, check connetions etc. in the panel. The one with fault like yours was well used and dirty inside the panel. One tip, I ran chassis upside down with lamps exposed until I had nailed it. All 3 are now running, no backlight problems. .....
      Thanks for the help. Do you mean all 3 were faulty LCD panel and were fixed just by cleaning contacts on the tubes. I don't think mine has one faulty tube because the brightness is very uniform. If I have to replace the lot, the tubes alone would cost £22 * 10 = £220!
      • lalunatech
        • Sep 2010
        #83
        Originally posted by tom66
        The bulbs on these TVs normally run pink on start. They are very low mercury bulbs, due to environmental restrictions, but as such, have a shorter life. If the TV isn't flickering and there are no dim bars, I would leave it as is.
        Cheers for the useful info. It is not flickering and looks good when warmed up but it is a repair for a customer so I can't send it back with C7558 shorted out to disable the fault detection, it may set fire to his house!
        • Jahson
          • May 2012
          • 245
          Try changing the CCFL's around, see if you notice any changes.
          • ron77
            • Dec 2012
            • 63
            • united kingdom
            #85
            I will explain as simply as I can. Had 3 sharp tv's to repair. Two I owned, one was a repair for somebody else. All 3 going to standby. The tv I bought, screen damaged, but backlights came on perfectly. So fitted backlight assembly, that was ok, to tv had for repair. Worked perfectly, job done. I gathered, without doubt, important info, knew where fault was. Also knew, had 3 faulty backlight assemblies on my hands. I needed to repair 2 of them. I did so, but no dim bars on either assembly. Had 10 spare lamps. Started next set. Tried changing lamps, but no real cure. So went for connections, and resoldered the 2 small boards in backlight assembly. After a lot of elbow grease did effect a permanent cure. At one point, thought of soldering lamp connections but thought better of it. Having gone over this work, reckon you might get away with just improving connections. Have been a professional engineer for over 4 decades. Am not a beginner, and I have told you how I proceeded. I would like to be more precise, but what I can say is all 3 sets are working perfectly. I will help more if you need it. Ron77
            • Jahson
              • May 2012
              • 245
              How about this for parts and a few CCFL :> http://www.ebay.co.uk/itm/Sharp-LC-3...item2c6d21096d
              Wish this was on last week
              • ron77
                • Dec 2012
                • 63
                • united kingdom
                #87
                Jahson.
                As long as lcd panel not taken apart you will have spare CCFL's. If screen ok, could go for more than a couple of pounds. Communicate with seller. You know what you want, as long as you get it, at right price,then ok. That service mode is on screen tells you a lot. The set I bought had accidental screen damage, and otherwise in good condition. I still have 10 ccfl's, if you get stuck, I can help you out with a couple. Ron 77.
                • Jahson
                  • May 2012
                  • 245
                  Ron77 my tv is fixed, i replaced 1 ccfl, problem solved.
                  Im just saying if this was on sell last week, sure it would of been a cheaper option than £34.04 i paid for the 1 ccfl.
                  But i thinking ive got that tv here, so i can test all i need to test. Think it will go for a few pounds.
                  If i did get it then i know i can ask you for a few bits if needed then?
                  • ron77
                    • Dec 2012
                    • 63
                    • united kingdom
                    #89
                    Understand, didn't read thread thoroughly. Only looked at last page to start with. Saw dan's post and knew had similar problem. I will help if you need it. So you actually paid that much for a ccfl. Would have sent you a couple for nothing. Ron.
                    • titaniva
                      • Dec 2013
                      • 7
                      • England
                      #90
                      Hi, I have the same problem i want to buy a C7558 0.47uF SMD cap on eBay. what is the voltage (V) of that. Thanks
                        You don't need to replace that cap, but if you really insist, any rating above 16V ought to work.
                        • titaniva
                          • Dec 2013
                          • 7
                          • England
                          #92
                          Thanks a lot, What can I do? Bridge
                            It is a possible fix but doesn't work for all sets. After doing it you need to do a service lamp reset.
                            • titaniva
                              • Dec 2013
                              • 7
                              • England
                              #94
                              thanks i will check
                              • titaniva
                                • Dec 2013
                                • 7
                                • England
                                #95
                                what is the reason of these pictures
                                • titaniva
                                  • Dec 2013
                                  • 7
                                  • England
                                  #96
                                  How much is that the lamp? and where can i buy?
                                  thanks
                                    Looks like the lamp wasn't making good contact with the connector, does the lamp appear undamaged? Also possible that the frame touched the board and caused an arc.
                                    • titaniva
                                      • Dec 2013
                                      • 7
                                      • England
                                      #98
                                      what is the solution? that part was a little darker than others the tv works but the smell is not good.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #99
                                        is there a part number on that lamp cicuit board?
                                        • titaniva
                                          • Dec 2013
                                          • 7
                                          • England
                                          #100
                                          runtk3923tpzz
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • YellowJacket
                                            SHARP LC-32CHF5111K - stuck at color test mode
                                            by YellowJacket
                                            Hi friends,
                                            TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
                                            So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
                                            02-04-2023, 03:11 AM
                                          • modtool
                                            HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
                                            by modtool
                                            Dear colleagues,
                                            I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
                                            The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
                                            Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
                                            05-07-2025, 06:10 AM
                                          • The_Memory_Guy
                                            Dell T7820 stuck in Bios Recovery Mode
                                            by The_Memory_Guy
                                            HI,
                                            I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
                                            What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
                                            All of them say to download the latest bios from the dell website which is a .exe file. I have done that
                                            https://www.dell.com/support/product...BUT090/drivers
                                            Some...
                                            07-07-2025, 06:52 AM
