Vizio E460ME 46" LCD Color Bars
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Vizio E460ME 46" LCD Color Bars
    Awesome.
    • mdmccool
      • Feb 2013
      • 28
      Hey Guys-
      I'm placing an order with Allied Electronics for some other things and I figured I'd pick-up a few resistors to fix this set. Since modern electronics are fairly new to me I'm not sure what I should order. Anyone have any idea what wattage these tiny resistors are? Are they considered "thick-film" type?
      Thanks,
      Matt
        82 ohm 0402 or 0603 size. Watt rating unimportant: just match size.
        Also get some quality solder wick and flux cleaner/isopropanol alcohol (90%+)
        • mdmccool
          • Feb 2013
          • 28
          Thanks Tom, that helps.
          I would also like to replace the cap above the bad resistor in my photo. It seems OK but I don't like the looks of it. It was said that the value should be 1uf. Any idea what size cap I should order?
          Also, what type of solder is recommended to use?
          Thanks again for all the help,
          Matt
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            That cap looks like an 0805 or 1008. Get one that is rated to at least 25v. You can always take some calipers to it if you aren't sure of the size.
            A working TV? How boring!
            • mdmccool
              • Feb 2013
              • 28
              Finally had some time to get to this set. Removed the bad resistor and soldered in a new one. (I am still cross-eyed - that resistor is tiny)! TV works great! Been watching it for a few nights now with no issues! Success!
              Thanks again for everyone's help,
              Matt
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help NeededπŸ™
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • x_orange90_x
                Vizio V585-J01 dancing lines and image doubling
                by x_orange90_x
                I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
                Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
                Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
                I swapped...
                06-12-2024, 07:57 AM
              • ninja_zx11
                Sharp LC-70LE650U vertical black and red bars
                by ninja_zx11
                70" LED TV is Sharp LC-70LE650U.
                Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
                07-07-2023, 11:27 PM
