Vizio E460ME 46" LCD Color Bars
  • mdmccool
    • Feb 2013
    • 28
    Hi Guys-
    New to the forum and modern TV repair in general. I am looking for a little help on a Vizio TV I have. My main interest is in repairing antique radios and TV's, all vacuum tube based stuff so I am a little out of my element messing around with this modern stuff.
    I have a Vizio E460ME 46" LCD tv that is suffering from large vertical bars of color on the right side of the display, exactly half. Unfortunately this model has two separate T-Con boards that are directly connected through ribbon cables to the display - can't replace the board without replacing the entire display. I've gently played with the ribbon cables that are glued to the display, unseated and reseated cables that go from the main video board to the T-Con and nothing seems to help. From everything I have read it seems that the diagnosis for most line problems, vertical or horizontal are diagnosed as ribbon cable problems or "replace LCD" display.
    I know many of these circuit boards are basically unrepairable unless you have surface mount equipment - many of the components need a magnifying glass to be seen!
    I am thinking a good first step is to measure voltages to see the health of the power supply. No obvious failed caps. The video/tuner board also has quite a few electrolytics - wondering if one of these could cause the problem but I am not sure how these circuits work.
    The video board is connected to the main T-Con via a cable of about 30 or so wires. Then there are two small ribbon cables that connect one T-con to the 2nd T-Con. (I have re-seated these with no improvement) I am assuming each T-Con is responsible for half the screen - so I am assuming the T-Con responsible for the right screen has failed, hence my problem.
    Not sure how the signals are processed and was wondering if maybe I have a bad cap or to on the video board.
    Thanks for any help,
    Matt
  • mdmccool
    • Feb 2013
    • 28
    Re: Vizio E460ME 46" LCD Color Bars
    I was able to check the various power supply voltages and all seems well - the 24 volt supply measures a tad high at about 24.6 but I would assume that is within tolerance.
    I cleaned all ribbon cables/connectors with deoxit and no change.
    If I disconnect the ribbon cable that drives the right half of the screen, that half goes completely white - an indication that the panel is OK?
    Is it possible that this could be a main video board problem and not the T-Con? There is a cap I noticed that *might* look slightly bloated.
    Any ideas?
    • mdmccool
      • Feb 2013
      • 28
      Here are some photos. Just wondering if there is any chance this could be a main board problem. Any help would be appreciated.
        It's very rare for a main board to cause a regional defect.
        A t-con can cause it in rare situations.
        Often times it is the panel itself though.
        • Dgtech
          E. Technician
          • Apr 2009
          • 1462
          • Steeler
          I have a good question about this set cause I'm working on a similar set. These Vizios are seeming like the T-Con section is built into the main board as seen above. Is this true? I see that they combined the power and inverter section in mine E420VO.
            On this model the T-con is in the panel itself.
            I say that but it's not really a T-con any more. It's just differential LVDS lines driving the LCD chip on flex directly instead of going through a T-con.
            • mdmccool
              • Feb 2013
              • 28
              Thanks for your reply Tom, much appreciated. Was wondering if it was worth checking caps, etc on the main board or not (been looking for an excuse to get an esr meter). I assumed if it was a main board problem the entire screen would show the defect, not half.
              If the TCon is built into the screen, what are the two small boards called at the top of the screen? (Still new at this).
              I have three sets here that have various "line" problems...hopefully I can get one going...
              Thanks again,
              Matt
                Those are panel driver boards, I am not sure if they have a name as they are not replaceable.
                • mdmccool
                  • Feb 2013
                  • 28
                  OK - thanks again.
                  • mdmccool
                    • Feb 2013
                    • 28
                    I messed around with this set again last night. I thought it would be worth a try to gently heat things up with a heat gun to see if I could get any response. I started with the left panel driver board (the side with the screen defect). After about 30 seconds the vertical bars disappeared and the set played perfectly!!! I let things cool and expected the problem to reappear but it never did. I let the set play for about two hours, cycled it on and off a few times. Let it sit overnight and tried it again this morning and still good.
                    I don't expect this to be a permanent repair but so far so good.
                      You probably have bad tab bonds then.
                      • mdmccool
                        • Feb 2013
                        • 28
                        I've finally localized the problem with this set. It has a bad (open) tiny resistor on the right side driver board. If I bridge the resistor with a low value resistor (100 ohm +/-) the TV works fine. I would like to replace it with the correct value resistor and I can't find a service manual or schematic to ID it.
                        I need to identify RX21 and also CD17.
                        Anyone have info for an E460ME?
                        Thanks,
                        Matt
                        • mdmccool
                          • Feb 2013
                          • 28
                          Here's a photo of the board and component:
                            It's plausible that the same resistor could be found on the other side of the panel, or on another tab bond.
                            • ecking767
                              • Oct 2009
                              • 492
                              excellent troubleshooting !!!
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                All the resistors on there will be the exact same value. So just measure its neighbors. The capacitor is likely to be 1uF ceramic judging by its size.
                                A working TV? How boring!
                                • mdmccool
                                  • Feb 2013
                                  • 28
                                  I thought the same thing, but the left driver board is quite different and I didn't want to assume anything.
                                  Thanks! Wish they all worked out this way...
                                  Really? All the same value - that's easy. How can you tell? It's not that I don't believe you, I'm just curious.
                                  • ecking767
                                    • Oct 2009
                                    • 492
                                    your in luck, this panel is found in a Westinghouse LD-4655VX I have it on my work bench now, All resistors are 82ohm
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      Look up how the LVDS protocol works and you'll understand. The signals are driven in differential pairs, so resistors in series with LVDS lines will at least be in pairs as well... In practice, due to both economic reasons and interface design, all resistors will be the same value. Same is generally true for any data bus. It makes sense - easier, cheaper and less confusing. The resistors are there to present a fixed impedance.
                                      • mdmccool
                                        • Feb 2013
                                        • 28
                                        Thanks for the info! I checked mine and they are all indeed 82ohm.
                                        Thanks for the explanation - makes sense. Much appreciated.
                                        ...Now lets see if I can actually replace this tiny little bugger...
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • x_orange90_x
                                          Vizio V585-J01 dancing lines and image doubling
                                          by x_orange90_x
                                          I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
                                          Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
                                          Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
                                          I swapped...
                                          06-12-2024, 07:57 AM
