Emerson LC39LEM3
  • marlboroa
    • Jul 2012
    • 59
    Emerson LC39LEM3
    I have a 39" emerson that blows the fuse as soon as its pluged in. IF I unplug the digital board that connects to the power supply then the fuse will not blow. I unpluged everything from the digital board and pluged it back into the power supply and it will blow the fuse again.
    So where can i start testing on that board to find out what is doing it?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Emerson LC39LEM3
    can you post some pictures up?
    • selldoor
      Slow Learner
      • 7870
      Re: Emerson LC391EM3
      you have got the model number wrong - not a good start
      Emerson LC391EM3
      • marlboroa
        • Jul 2012
        • 59
        pics not the best but you get the idea. I can leave the black/red wires on the power supply connected and the fuse will not blow.
        • selldoor
          Slow Learner
          • 7870
          What is the part numbers of the 4 x 8 leg components near the connector from main to power. Have you checked the cable/socket for shorts bent pins
          • selldoor
            Slow Learner
            • 7870
            In order to stop wasting fuses, can you get a lampholder and a 60watt filament lamp.
            Solder that across the fuse and if there is a short the bulb will light and stay bright if no short it will light then start to dim.
            I ask because I want you to disconnect the black and red wire socket and try with the main board and power board connected.
            If my thought is wrong then you will blow another fuse.
            I believe the Black and red carry the voltgage to another board - not pictured - the inverter board. It is possible that the main board is ok but when it sends the signal to switch on the voltage for the backlight, if there is a problem/short on the inverter board it is causing the fuse to blow.
            I would like to see a pic of the inverter board before trying to check out the main board.
            • marlboroa
              • Jul 2012
              • 59
              I tried what you said and had everything connected but the black and red wires that go to the inverter. Still blew the fuse as soon as it was pluged in.
                The fuse should be removed before putting the bulb across it.
                • marlboroa
                  • Jul 2012
                  • 59
                  i know, i dont have a lamp socket handy. ill have to pick one up later but i do have more fuses and a resetable fuse. kinda like a circuit breaker.
                  • selldoor
                    Slow Learner
                    • 7870
                    Ok well it looks like its almost certainly the mainboard unless you have been testing it with the boards touching the frame or a conductive surface.
                    Really could do with a good clear picture of the board front and back.
                    Good light without flash is the key.
                    • selldoor
                      Slow Learner
                      • 7870
                      Sorry double post
                      Oh yes and the part numbers of the 8 legged components
                      see post5
                        Not so fast... an issue with how the PSU works could be causing it to fail when the PSU switches on under command from the main board.
                        • marlboroa
                          • Jul 2012
                          • 59
                          Ok heres some pics. If these are the parts you wanted then 3 are the same M2305sds and the one right in front of the connector is the one that starts with 001cow. the connectors are all good and the boards have not been touching the frame.
                          • MisterD
                            • Oct 2012
                            • 668
                            In your pictures I can see that the Main Board has no mounting screws and is slid over to the right shorting it out to the chassis.
                            • marlboroa
                              • Jul 2012
                              • 59
                              yea i just took those out right before the pic. I was going to take a pic of the backside but got distracted by the kids. The screws were in it for testing.
                              • selldoor
                                Slow Learner
                                • 7870
                                Cant find much info on those components.
                                Tom seems to think it may still be a power supply problem, I guess along similar lines to what I was thinking with the inverter. It starts off ok then
                                when the main board signals to start higher voltage it goes bad.
                                There are quite a few diodes on there perhaps start by checking them for shorts.
                                This guide by retiredcapshas quite a lot of component tests most without power to the board start at post19
                                https://www.badcaps.net/forum/showthread.php?t=10419
                                  When the Main send out the PS_ON and Inverter ON command to the power supply board, the PFC circuits will kick on (there are two MOSFETs and two inductors on the top edge of the board as shown in the picture). The large transformer close to the bottom right is an inverter transformer that driven by the MOSFET to step up the voltage (not at CCFL voltage level) to drive the primary side of a bunch of smaller inverter transformers which drives the lamps.
                                  So you need to see what kind of board is which is not shown in your pictures. That is the big load big enough to blow the fuse.
                                  Shopjimmy does not have any pictures of the sub inverter board either.
                                  http://www.shopjimmy.com/catalogsear...erson+LC391EM3
                                  • MisterD
                                    • Oct 2012
                                    • 668
                                    http://www.ebay.com/itm/I390HJ-08A-I...item27cfd23b61
                                    Here's the Hidden Inverter Board.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      The fuse blows even when the inverter board is disconnected? Post6/7
                                      Does that suggest a problem on the PFC circuit?
                                        So on post 1 if no black/red wire connected it did not blow the fuse, now in post 7, it will blow the fuse without having the red/black wires connected. It sounds like it had more damage components now since then, this can be due to too much load was on the inverter circuits that try to drive shorted load. The PFC must have been OK in the beginning since it did not blow the fuse in post1. At this point he needs to check all the components mounted on the heatsink to start with.
                                        • socketa
                                          Bestec ATX0300F5WA - fast,or slow blow, fuse?
                                          by socketa
                                          I bought a dead motherboard, and connected it to this PSU,
                                          Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
                                          So now i truly got a bang for my bucks, and something else to try and fix.
                                          The fuse was blowen, and the top was blowen off of a TNY276PN chip
                                          The glass fuse didn't have any marking to say if it was fast or slow blow
                                          So i checked the marking on the PCB thinking that that would tell me,
                                          but it 's got a T/F8A printed on the board
                                          So should i get a fast blow fuse, or should...
                                          05-17-2022, 01:22 AM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • jshhh
                                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                          by jshhh
                                          Hi guys,
                                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                          Anybody know how to remove this type of fuse?
                                          (The fuse is toward the bottom of the image labeled F2)...
                                          06-17-2025, 01:35 AM
