Emerson LC39LEM3
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Emerson LC39LEM3
    In post 1 he doesnt say the red/black to the inverter was not connected ,he just says the cables to the main board were disconnected - did you think otherwise?
      OK, I read the post wrong, then yes the PFC may try to kick on or the inverter circuit kicks on and cause the fuse to blow. The MOSFETs for the PFC and for the inverter transformer are connected directly to the mian B+, so some how when the IC being told to drive the Gate, the out put just go HIGH instead of switching ON and OFF at high frequency so it draws lots of current and caused the fuse to blow. We will need all the P/N of the PFC and for the INVERTER drive IC.
      • ny_jets_head
        • Apr 2014
        • 70
        • usa
        Re: Emerson
        I'm working on one of these (LC391LEM3) also a power supply issue.
        It had a blown fuse I check it over replaced the fuse.
        I have 3.3V and 6.8 for the PON 12V
        I suspect the PON 12V is an issue.
        Suggestions?
        Anyone have a print or manual on this?
        • ny_jets_head
          • Apr 2014
          • 70
          • usa
          Re: Emerson
          Originally posted by ny_jets_head
          I'm working on one of these also a power supply issue.
          Suggestions?
          Correction: (LC391EM3)
          • socketa
            Bestec ATX0300F5WA - fast,or slow blow, fuse?
            by socketa
            I bought a dead motherboard, and connected it to this PSU,
            Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
            So now i truly got a bang for my bucks, and something else to try and fix.
            The fuse was blowen, and the top was blowen off of a TNY276PN chip
            The glass fuse didn't have any marking to say if it was fast or slow blow
            So i checked the marking on the PCB thinking that that would tell me,
            but it 's got a T/F8A printed on the board
            So should i get a fast blow fuse, or should...
            05-17-2022, 01:22 AM
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
          • jshhh
            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
            by jshhh
            Hi guys,
            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
            Anybody know how to remove this type of fuse?
            (The fuse is toward the bottom of the image labeled F2)...
            06-17-2025, 01:35 AM
