Vizio VW42L problems
  • chopsawkev
    • Feb 2013
    • 24
    Re: Vizio VW42L problems
    im seeing 0 ohms between the positive and negative pads on the board with or without the caps solder to the board.
    here is 4 pan shots of the board, from right to left. let me know if you need better ones. thanks again.
    also I apologize for my poor soldering skills, I've got a cheap gun at home that i fried last night. ill grab my good one from the garage today.
    • selldoor
      Slow Learner
      • 7870
      #42
      Clean up the Cap pads with isopropyl alcohol to remove the flux -may as well replace the caps if they were new.
      Perhaps start by testing the 4 mosfets.
      • chopsawkev
        • Feb 2013
        • 24
        why should I replace them? how do I go about testing? Sorry, im not really sure how to use that PDF.
        • MisterD
          • Oct 2012
          • 668
          A picture of the bottom side of the slave inverter board directly below where you soldered in the 2 new capacitors so we can see if there are any solder runs or shorts. I think selldoor is saying that you might as well reinstall (not replace) the caps if they were new.
          • selldoor
            Slow Learner
            • 7870
            #45
            Hahaha - Yes that is what I meant Thanks MisterD
              OK, Please check the TVS Diode (you will have to remove it) to see if it is shorted out. This TVS is in parallel with the caps.
              The 4 MOSFETs are set up as a full bridge drive, so the each pair is connected in series, so both of them have to shorted out which very unlikely but possible, but it is easier to remove that TVS Diode to see if the short will go away.
              I hope you do have good 40Watts soldering iron.
              By the way, the caps are not mounted with through hole mounting so the legs do not go through the board. They are mounted like SMD device.
              To remove the Diode, you will ADD more solder to both end which will keep the solder hot, you will be moving the soldering tip back and forth between the two ends of the Diode then you can use the tweezer to remove it from the board
              • kalilinux25
                Lenovo Thinkpad T410 no power
                by kalilinux25
                DEVICE: Laptop
                Model: lenovo thiinkpad t410
                Board Id: 09A33-3 48.4FZ09.031
                NZM1H-8
                ISSUE: NO POWER
                From the first mosfet 20v is not passing through, pin 4 has 19.5v and the first mosfet is a P-CHANNEL mosfet (SI7121DN) i think the pin 4 should be lower to active the 1st mosfet to allow the 20v to pass to second mosfet ive check all for shorting in the board , i did;nt find in rails, so ive check the schematic and im suspecting that, my Q61 is faulty due to its pin 1 is 0.47ohms? im not pretty sure, hope someone can help me figure out this issue.
                07-13-2025, 07:56 AM
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • mrtek
                Vizio M65-C1
                by mrtek
                Hi.
                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                Yesterday, 07:28 PM
              • rabsonnjala
                LENOVO IDEAPAD 100 works only on bench power supply
                by rabsonnjala
                Hie I have a Lenovo laptop
                Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                below are my readings
                with the original charger only
                JBATT1
                PIN1 0.22V
                PIN2 0.22V
                PIN3 0.45V
                PIN4 0.45V
                PIN5 O.43V
                PIN6 0V
                PIN7 GND
                PIN8...
                11-20-2021, 08:32 AM
