westinghouse vr3215
  • lookimback
    • Aug 2013
    • 1489
    Re: westinghouse vr3215
    Yes, I'm going to remember this one myself as well. It never occurred to me that someone else might have tried to fix it themselves and made it worse. The electrolytic did test bad so maybe that was the original problem. Thanks for all the help with this one. Honestly, if not for your help I would probably still be messing with the power board. I learned a lot from this one.
    ------------signature starts here------------
    • Dr. Bogger
      • Sep 2012
      • 3
      Originally posted by johnz
      ok here are somre readings i got
      +12v = 0
      +12v = 0
      GND
      GND
      GND
      +5v =5.2
      +5v =5.2
      +5VSB =5.2
      STB =3.5
      +5V =5.2
      +5v = 5.2
      GND
      GND
      NO 24v all 0
      I am having the same voltages as above.
      I seem to have lost 12v and 24v supply.
      I want to see if I can figure out the issue before I spend the money on a new power supply.
      I have tested the voltage on the large cap, and I get about 393v.
      I have tested all the diodes, and all seems good, except one is acting like a zener diode, and I'm not sure if it is a zener diode or not. Location: JM8
      I haven't tested any of the caps yet, but I have a feeling it's not a cap issue. Plus my ESR meter is a cheapo.
      What do you suggest I check next?
      • Dr. Bogger
        • Sep 2012
        • 3
        UPDATE:
        The transformer that supplies both 12v and 24v has no output, and also no input.
        The other transformer has a 390v Input, so I'm assuming this one should be getting the same???
        Any help would be great!
          Good clear straight shot pictures of your board top and bottom side will help.
          • Louis82
            • Feb 2012
            • 240
            I have same issue. No 12v, 24v. Big cap reads 391v. Using 1k resistor between STB and 5vSB.
            I have checked diodes D500 and D501 and there is no input voltage. Ordering a board is an option but I'm very curious on finding what's wrong with this power board.
            I will appreaciate any help. Pics are attached.
              The pictures are cutout and do not show the whole board.
              • Louis82
                • Feb 2012
                • 240
                Hope these pictures look better.
                Thank you
                • Louis82
                  • Feb 2012
                  • 240
                  Better pics from Shopjimmy.
                    OK, the 12V and the 24V are generated by the same power transformer T1 which is driven by the power MASFET Q103. Q103 is driven by the SMPS IC U301.
                    The 12V/24V power supply section is turned on by the PS_ON (STBY) signal and we know that the signal is OK otherwise you will not have the PFC Boosted Voltage.
                    You need to find out the P/N of the SMPS IC U301 to see if it is geTting the VCC to run the IC.
                    Also check the Source resistor that is connected to the Source pin of the Q103, it should be < 1 Ohms.
                    • Louis82
                      • Feb 2012
                      • 240
                      IC U301 P/n : 63b26
                      R309 (on the board) reads <1 Ohm
                        I see people selling them but I cannot find the spec sheet.
                        http://www.iccfl.com/product_info.php?products_id=23550
                        Resistor is OK.
                        • Louis82
                          • Feb 2012
                          • 240
                          Hi Budm. Do you have any experience about buying stuff from this website? (iccfl.com) Can't find this IC anywhere else and I'm curious of finding the fix.
                            Sorry, no.
                            • alro7779
                              Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
                              by alro7779
                              Hello, guys!
                              I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
                              Alex....
                              10-03-2025, 05:49 PM
                            • Nicktronic
                              Westinghouse W55UW4620 No Video
                              by Nicktronic
                              Ok, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
                              So, backlights, no video, go! 🙂...
                              06-03-2024, 03:21 PM
                            • EBW
                              Help Request - Westinghouse 32" Smart TV (Model: WD32HBR105)
                              by EBW
                              Westinghouse 32" Smart TV (Model: WD32HBR105) . Originally stuck on logo with no response from remote and no firmware file available to flash via USB. Westinghouse Support stated it would require service but that wasn't a cost effective option. I used dental floss to remove the motherboard processor heatsink to identify what make it was (Mstar). Unfortunately that knowledge didn't help with a solution. After the heatsink removal it only displayed a completely white screen. I then decided to replace the motherboard with a universal 3-in-1 board but the white screen problem continued. This...
                              10-27-2022, 06:32 PM
                            • Seville
                              Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
                              by Seville
                              Hello all!
                              Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
                              I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
                              10-10-2022, 07:31 AM
                            • JayPoorJay
                              Westinghouse Roku WR58UX4019.To be or not TV,,, That is the Question
                              by JayPoorJay
                              Hi All... Me again. Begging for help. The guy who now believes it's possible to fix a TV (one of the millions) one can find on the streets of NYC. I hate hate hate waste...
                              Thanks to y'all's help I fixed and am happily watching a 70inch Sharp Aquos. Perfect. Learned a lot, replaced LEDs. Pulled screen/panel. Proud.
                              This is a newer set. It's a Westinghouse Roku WR58UX4019. It was RIGHT outside my place literally, and I couldn't resist. 58in. 500$ new, but I'm not a rich man. So, I want to try.
                              There is sound. It turns off and on. Screen is black. I can...
                              03-17-2022, 05:27 PM
