Hi can anyone help me at all ive got a lg 42pq3000 plasma tv here when i switch it on i get no picture its just glowing as you can see in the picture i get like a snowy sound like a hissing i no its sound as if i press mute it dissapears please can anyone help me diagnose this problem at all many thanks
LG 42pq3000 just backlight
Re: LG 42pq3000 just backlight
OK, this is a plasma. It does not use a backlight. Each cell emits its own light. But that means the panel, sustain boards and power supply are probably working. Probably.
Let's rule out the plasma panel, sustain boards and the power supply: Do you see the points marked "EXT_AUTO_GEN" on the control board?
- Turn TV off.
- Disconnect LVDS cable from control board (this is the top most black tape connector in this picture: https://www.badcaps.net/forum/attach...2&d=1359559144.)
- Take a 100 ohm resistor and jumper between the auto gen holes.
- Turn TV on.
- The panel should show test patterns - does it?
Last edited by tom66; 01-30-2013, 10:09 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. - Turn TV off.
Oh and service manual if you need it
http://www.tgohome.com/ServiceManual...&Search=SubmitPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Maplin Electronics sell resistors.
Or you can jumper across it with a wire, but I do not want you to damage the board in case this is not OK.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
HereAttached Filesif you find these attachements useful please consider making a small donation to the site
Great, in which case, replace the main board (unless you want to repair it.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yeah, that's the main board.
See Retiredcaps thread on testing voltage regulators:
https://www.badcaps.net/forum/showthread.php?p=300999
BTW, I notice a 50" main board on eBay. That probably won't work as the 50" panel is 1366x768 and the 42" is 1024x768, but it might be possible to change the settings in firmware.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Maplin Electronics sell multimeters for £5 each. Or eBay.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
yes ive been lloking around for one and seen there about £5.00 is there a certain one you would sugest to me on ebay? and also when i find what regulator is wrongt are they easy to source as sometimes maplin dont stock stuffComment
You can order the regulators on eBay or Farnell.
Maplin's basic meter is fine.
http://www.maplin.co.uk/domestic-multimeter-37279
The DT830B is also a good meter for basic usage, and it's probably made by the same company as the Maplin meter.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yes, you need to have it powered on, with the fault showing on the display.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
right if ive done this right here is my readings im trying to do them of the data sheet but a bit confused with it at the mo
ic1107
az1085s
adje1
832j73
1- 0.60
2- 1.85
3- 4.85
ic1102
az1085s
adje1
832j73
1- 0.03
2- 1.28
3- 3.29
ic1104
az117d
1.8e1
838j25
1- 0
2- 1.81
3- 3.3
ic1103
az117d
-3.3e1
853k18
1- 0
2- 3.3
3- 5.05
ic1106
az1085s
-3.3e1
903j80
1- 0
2- 3.3
3- 4.84Last edited by steve2k34; 02-02-2013, 09:19 AM.Comment
Those results are spot on.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by Comp_ProHello all,
Am trying to figure out this backlight issue with this A1990 Macbook Pro.
Tests performed:
There is no backlight even with a good screen.
Backlight IC is receiving the correct support voltages.
Fuse F8400 ok
Current sense resistor R8400 ok
Backlight IC is receiving 3.3V on enable pin.
Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
Backlight IC receiving 5V from PP5V_G3S
Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
I2C_BKLT_SCL and I2C_BKLT_SDA both measure... -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... -
by canadaboy25Hi all,
I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...-
- Loading...
