LG 42pq3000 just backlight
  • steve2k34
    • 36
    Hi can anyone help me at all ive got a lg 42pq3000 plasma tv here when i switch it on i get no picture its just glowing as you can see in the picture i get like a snowy sound like a hissing i no its sound as if i press mute it dissapears please can anyone help me diagnose this problem at all many thanks
    Re: LG 42pq3000 just backlight
    OK, this is a plasma. It does not use a backlight. Each cell emits its own light. But that means the panel, sustain boards and power supply are probably working. Probably.
    Let's rule out the plasma panel, sustain boards and the power supply: Do you see the points marked "EXT_AUTO_GEN" on the control board?
    • Turn TV off.
    • Disconnect LVDS cable from control board (this is the top most black tape connector in this picture: https://www.badcaps.net/forum/attach...2&d=1359559144.)
    • Take a 100 ohm resistor and jumper between the auto gen holes.
    • Turn TV on.
    • The panel should show test patterns - does it?
      Oh and service manual if you need it
      http://www.tgohome.com/ServiceManual...&Search=Submit
      • steve2k34
        • 36
        i dont have an resistors to test that so looks like im srtuck for the moment
          Maplin Electronics sell resistors.
          Or you can jumper across it with a wire, but I do not want you to damage the board in case this is not OK.
          • steve2k34
            • 36
            right i will have to pop to maplins in the morn which holes exactly do i need to stick this resistor into
              Here
              • steve2k34
                • 36
                right thank you, just making sure as dont want to mess it up further. Thanks for your help much apreciated, i will look into this further tomorrow.
                • steve2k34
                  • 36
                  ive put the 100 ohm resitor in and i get all the test patterns show up now
                    Great, in which case, replace the main board (unless you want to repair it.)
                    • steve2k34
                      • 36
                      the main board with the hdmi sockets etc?
                      is there any chance you would no how to repair the main board, as whats there to loose apart from having to buy a new one many thanks
                        Yeah, that's the main board.
                        See Retiredcaps thread on testing voltage regulators:
                        https://www.badcaps.net/forum/showthread.php?p=300999
                        BTW, I notice a 50" main board on eBay. That probably won't work as the 50" panel is 1366x768 and the 42" is 1024x768, but it might be possible to change the settings in firmware.
                        • steve2k34
                          • 36
                          Thank gonna have to buy me self a multimeter looks quite hard to do but will have a go at it
                            Maplin Electronics sell multimeters for £5 each. Or eBay.
                            • steve2k34
                              • 36
                              yes ive been lloking around for one and seen there about £5.00 is there a certain one you would sugest to me on ebay? and also when i find what regulator is wrongt are they easy to source as sometimes maplin dont stock stuff
                                You can order the regulators on eBay or Farnell.
                                Maplin's basic meter is fine.
                                http://www.maplin.co.uk/domestic-multimeter-37279
                                The DT830B is also a good meter for basic usage, and it's probably made by the same company as the Maplin meter.
                                • steve2k34
                                  • 36
                                  got my multi meter
                                  this may sound like a daft question but im just being cautious do i have the board fully connected up to the tv ?
                                  do i have the tv plugged in if so in standby or switched on for my readings?
                                    Yes, you need to have it powered on, with the fault showing on the display.
                                    • steve2k34
                                      • 36
                                      right if ive done this right here is my readings im trying to do them of the data sheet but a bit confused with it at the mo
                                      ic1107
                                      az1085s
                                      adje1
                                      832j73
                                      1- 0.60
                                      2- 1.85
                                      3- 4.85
                                      ic1102
                                      az1085s
                                      adje1
                                      832j73
                                      1- 0.03
                                      2- 1.28
                                      3- 3.29
                                      ic1104
                                      az117d
                                      1.8e1
                                      838j25
                                      1- 0
                                      2- 1.81
                                      3- 3.3
                                      ic1103
                                      az117d
                                      -3.3e1
                                      853k18
                                      1- 0
                                      2- 3.3
                                      3- 5.05
                                      ic1106
                                      az1085s
                                      -3.3e1
                                      903j80
                                      1- 0
                                      2- 3.3
                                      3- 4.84
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        Those results are spot on.
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • canadaboy25
                                          LG Flatron 24EN33TA No Backlight When Cold
                                          by canadaboy25
                                          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                          03-07-2023, 12:23 AM
