compatible t-con
  • freecom
    • Nov 2011
    • 18
    • greece
    compatible t-con
    hello
    let me know please
    i have to replace t-con
    V400H1-C03 (from panel CHI-MEI V400H1 L03)
    is compatible with t-con
    V400H1-C05
    or
    V400H1-C01 (is more cheap)
    thanks
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: compatible t-con
    I dont know but would guess not. Board C03 goes with panel L03
    C05 with Panel L05 and C01 with panel L01
      Different revisions can be using different voltage to operate, it can be 5V or 12V, same thing for the pinouts. You need to find the spec sheet of the panel that uses that particular T-CON board.
      • freecom
        • Nov 2011
        • 18
        • greece
        first thank you for your time
        all version of chi-mei 40' panel type V400H1
        L01...L02....L03...L05.... is same volt 12v
        so.....can i use one t-com from other version ?
        • randtek
          • Oct 2011
          • 280
          • US
          Probably not. There is no way to guess what changes a manufacturer makes between versions, as they don't seem to release schematics of panels and TCons. Sometimes the changes are minor, other times not. Sometimes the change will involve different LVDS connectors. If you can afford to risk damaging panels or boards, you can try it. Personally, I wouldn't risk it.
          • kevinm34232
            • May 2012
            • 1884
            You need to look at the #'s on the white sticker for the correct part #, not just the board #..
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help NeededπŸ™
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • alltvrepairs
              Lg TCon test pins for screen test
              by alltvrepairs
              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
              Appreciate your help....
              06-13-2025, 06:33 AM
