40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
  • ger10101
    • Sep 2014
    Re: 40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
    Originally posted by tieny
    Hmm, cutting it worked. TV turns on perfectly, no dimming when it gets to the HDMI screen, its just full bright.
    hello, how and where did you cut this wire, i am having the same problem. thank you for your helpe
    • Vhelt
      • Nov 2008
      Back read and u find out what happen....
      • cayers007
        • Dec 2013
        To anyone looking for the Dim Control Wire, I have posted a photo of the wire I had cut which resolved the issue with my EX400 stuck in a power cycle loop and receiving 6 Blinks. Please note that the backlight will run at full brightness when this wire is cut. Good luck!
        • paulstef
          • Dec 2013
          • 724
          Awesome thread, saved me hours of troubleshooting probably.
          THANKS!
          Removed DIM wire and it stays on.
          Btw, the PWM frequency is 150 Hz and the duty cycle is stuck at 5% (350us positive pulse width).
          Funny thing, while re-running the initial setup, the duty cycle increases to the currently adjusted backlight setting. Must be some firmware problem maybe. After the setup has finished it returns back to 5%.
          • jeapel16
            • Mar 2019
            • canada
            #165
            hi
            It too late to answer for this tv but i would like to get expert opinions
            so check mytv.jpg kdl40ex500
            1-If the tv is ok with cut dimmer wire why not try to put
            a manual dimmer control 1v to 3v with a 1k pot or a small
            regulator for low output impedance from the 5v or 12v.
            for all the solutions with a tv (not this one) is it possible to do:
            2-with bl-on cut put a jumper with 100 ohm between power-on and bl-on to force inverter board
            3-with bl-err cut force a good condition err
            • d.vh
              • Dec 2020
              Same issue. I pulled pin 14 from connector CN6402, labeled Dimmer. The Sony kdl-40ex501 came right up. No more 3 reboots; no more 6 blinks ... Awesome. Thx to tieny and budm. I had a great time trying to follow you both, and I understood enough to test the voltages on the board, and get to the solution. Are there any other downsides to disconnecting wire 14, besides dimmer functionality? Since this is part of the Protection system, what have I lost?
              • Dt3s
                • Sep 2025
                I know this is like 10+ years on, but I just wanted to thank you folks for helping me save my beloved 15 year old TV from the landfill. While I'd still love to fix the dimmer, at least the TV is usable again and I couldn't have figured this out on my own so thanks a million!!
                • jason123
                  Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                  by jason123
                  Hi there,
                  I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                  So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                  I see 2 posts that are relevant:
                  https://www.badcaps.net/forum/troubl...j-oled-5-blink
                  https://www.badcaps.net/forum/troubl...g-hardware-dev...
                  Today, 02:01 PM
                • mauda
                  Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                  by mauda
                  I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                  Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                  05-21-2023, 11:56 PM
                • tec3000
                  Sony LED 65X9005A shuts down after few seconds - looking for help
                  by tec3000
                  Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                  I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                  03-20-2024, 07:29 AM
                • matwan
                  Sony XR-55X90J 5 blinks
                  by matwan
                  I have problem with SONY 55X90J. After several check status is as below;
                  1. Running power board as stand alone:
                  TCON_12V =~ 12.6V
                  EVDD V On Max 24V= 19V.
                  2.
                  Running power board with TCON as stand alone:
                  Effect as below, attched.
                  3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                  "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                  Best regards....
                  09-28-2025, 04:26 AM
                • GoodCapDude
                  Sony XBR-75X940E intermittent 6 blinks error code
                  by GoodCapDude
                  Hi everyone. First post on Badcaps!
                  I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                  09-20-2025, 06:07 AM
