vizio vp50
  • heavymachines
    • Mar 2011
    • 1028
    Re: vizio vp50
    Originally posted by tom66
    Check all board fuses.
    Inspect the Va transformer area (third from top.)
    Consider replacement of TL431 feedback IC.
    i spent good amount of time trying to find this TL431 no avail only thing marked T at all is the transformers themselves..when you say IC you mean the chips with legs correct? Is there anyway to test this IC before i go buying one?
    All fuses are good one of first things i did when i opened the set up also want to note to you i found a bad capacitor hiding under the frame and heat sink of the y-sustin
    C5709
    i changed that, of course changes nothing yet...(yes it name brand from digikey panasonic fm series had laying around)...
    Also looking up best way to test the buffers with dmm....if you know a good way please do tell.... anyhow i found this
    http://blog.coppelltvrepair.com/2010...er-boards.html and my buffer model numbers almost match but not quite and it looks practically identical except there is no heat sink on the buffer IC....
    from what i can gather it don't look good for me, i will recheck when i am more awake but it looks i may have 2 buffers that is shorted, maybe i should take pic's of me testing them? and you can confirm?
      Re: vizio vp50
      Buffers don't cause lack of Va.
      Va is the horizontal electrode voltage, not used by Y-sustain or Z-sustain (just passes through) basically, it writes the data to the screen (the video image) using the COF chips on the bottom of the panel. In very rare cases these can short but this would cause 0V for Va not the odd voltage.
      On this chassis it might be a KIA431 IC. I understand that those particular ICs have lots of problems with dropping their reference voltage over time.
      • heavymachines
        • Mar 2011
        • 1028
        Re: vizio vp50
        just wondering if you seen post #20? what you think of those resistors?
          Re: vizio vp50
          They look a little toasty. What do they measure?
          • heavymachines
            • Mar 2011
            • 1028
            Re: vizio vp50
            Ahh good to know thanks....anyhow lol i can't find KIA431...
            here is what i can find.....that has KIA in it...
            U973----KIA358P.....735..has 8 pins
            U971----KIA339P.....731..has14pins
            U112----KIA7812A...PI 743...has 3 pins think it terminal voltage regulator
            U111----same as U112 right next to each other
            Seems to be all i can find on this power board that has KIA in it rest is either KA or Fairchild or ON Semiconductor and a couple i have no clue but don't think it has anything to do with what we are trying to solve....
            Thanks for the help on this beast....
              Re: vizio vp50
              OK, anything at all with 431?
              Looks like this:
              • heavymachines
                • Mar 2011
                • 1028
                Re: vizio vp50
                in circuit both measures 05.5 ohms in dmm set to 200ohm range
                out of circuit measures 10.9 both measure same
                • heavymachines
                  • Mar 2011
                  • 1028
                  Re: vizio vp50
                  Looks like this:
                  U451...KA431AZ...H42 closest i got the rest is different numbers and some others look close but has flat backsides instead of half moon shape "er round backsides"....sorry bout that
                    Re: vizio vp50
                    KA431 is good. Near the Va section? Between pins 1 and 3 you should measure approx 2.5V if it is working.
                    Since both of those resistors measure the same, it's very unlikely they've failed equally. They are probably 10 ohm resistors, two in parallel to make 5 ohms. The dark colouring is probably just the body colour.
                    • heavymachines
                      • Mar 2011
                      • 1028
                      Re: vizio vp50
                      here where it located can't see in image but behind the transformer.....
                        Re: vizio vp50
                        That is most likely for Vs, especially if Vs adjustment is near there.
                        See attachment.
                        • heavymachines
                          • Mar 2011
                          • 1028
                          Re: vizio vp50
                          Its VA pot, the VS is almost at top on left side of board
                            Re: vizio vp50
                            We need to be looking for KA431 near Va pot.
                            Vs is good as far as you have measured.
                            • heavymachines
                              • Mar 2011
                              • 1028
                              Re: vizio vp50
                              okay i found another one same exact part number and it near va pot will measure stay tuned
                                Re: vizio vp50
                                That may be for the main/standby supply.
                                • heavymachines
                                  • Mar 2011
                                  • 1028
                                  Re: vizio vp50
                                  okay the one behind transformer at top by VS pot measures 8.7 volts
                                  the one by the VA pot measures 1.3 volts....think we are getting somewhere..
                                    Re: vizio vp50
                                    Bottom of board pic necessary to determine if it is for Va or not.
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      Re: vizio vp50
                                      Here it is
                                      • heavymachines
                                        • Mar 2011
                                        • 1028
                                        Re: vizio vp50
                                        my bad here is more
                                        • heavymachines
                                          • Mar 2011
                                          • 1028
                                          Re: vizio vp50
                                          more
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • supermattch
                                            HP 15dy-2021nr wont power on mystery volts
                                            by supermattch
                                            Hi everyone.
                                            I am diagnosing my personal laptop, because it wont power on and no leds light up.
                                            At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                                            Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                                            09-23-2025, 12:13 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
                                          • Mcfeetroy
                                            Fishing bite alarm drains battery
                                            by Mcfeetroy
                                            Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                            08-01-2025, 03:52 AM
